XTREME KARTS XF 1,212 Posted August 15, 2016 Hey fella's At some stage down the track i want to fit a B&M Megashifter into my XD ute. How hard are they to fit/install?? For those who have a B&M or a similer shifter setup installed, throw up some pics if you like! Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted August 16, 2016 I think it will only fit a c4 or c6 if you have an fmx or 35/40 BW it wont . Share this post Link to post Share on other sites
PRO250 1,506 Posted August 16, 2016 Easy enough to fit took me about 4 hours to fit one in my grey car I have a poxy little B&M one in the ghia it took I fair bit longer as I made a new cover and recessed into the floor so the consol stil fit over it Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted August 16, 2016 Easy enough to fit took me about 4 hours to fit one in my grey car I have a poxy little B&M one in the ghia it took I fair bit longer as I made a new cover and recessed into the floor so the consol stil fit over it I know this is off topic- is this your ghia with the blower? Have you got a build thread on it? Link? Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
MNTL.XD 3,831 Posted August 17, 2016 I think it will only fit a c4 or c6 if you have an fmx or 35/40 BW it wont . Apparently you can make them fit the FMX 'box, here's a link. http://therooseveltexperiment.com/blog/2011/06/21/using-a-bm-cable-shifter-with-a-ford-fmx-transmission/ I have the B&M Mega shifter, it's apart at the moment so easy to get pics of so will put some up soon. 1 bear351c reacted to this Share this post Link to post Share on other sites
MNTL.XD 3,831 Posted August 18, 2016 Hey fella's At some stage down the track i want to fit a B&M Megashifter into my XD ute. How hard are they to fit/install?? For those who have a B&M or a similer shifter setup installed, throw up some pics if you like! Hey dude, they are pretty easy to fit and setup, they're bolted in with 2 bolts at the front and 2 at the back, the factory shifter hole simply gets plated over and sealed. A larger hole in front of the shifter where the cable goes through will need to be drilled and a grommet fitted to seal the cable. Pic from driver side: (the only thing really visible from this side is the wiring for the shiter light) Pic from passenger side: (as part of hiding the engine bay wiring i deleted the ugly wiring that goes across the firewall and to the gearbox, these were pulled back into the cabin and run directly to the gearbox under the carpet, wiring for reverse lights and neutral safety switch are on this side, you can also see the wiring that goes through the floor to the speedo sender. What you can't really see is the cable running through the floor in front of the shifter.) Here if you look closely you can see where the cable comes through the floor, it runs around in a loop, goes through a bracket (supplied) bolted to the side of the 'box, and to the selector lever (also supplied). To fit this you put the 'box in reverse, spin the connector (red) up the threaded rod until it lines up with the selector lever, poke it through and put a washer and splitpin through the other side (i also fitted a nut). Easier than having a shit. 3 Defective, SirkWhyXF and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
bear351c 10,271 Posted August 19, 2016 Nice one mate. No they dont make a kit for FMX, I've looked many times. There are numerous vids on Utoob, and a couple of extra brackets to make. The FMX linkages are on the opposite side to C4, etc. (good to know when you buy a Tbar shifter off ebay). Do B&M make a cover plate with PRND21 on the drivers side, for Aussie Fords.?? Who drive on the right side of the road....... Share this post Link to post Share on other sites
MNTL.XD 3,831 Posted August 19, 2016 Yep, they sure do Bear, this shifter has it... 2 XTREME KARTS XF and bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,271 Posted August 20, 2016 Ooooooooh........there's hope for me humble FMX yet. Share this post Link to post Share on other sites
gregaust 319 Posted August 20, 2016 The FMX linkages are on the opposite side to C4, etc. INCORRECT ... C4 and FMX both on the same side . On the left Share this post Link to post Share on other sites
bear351c 10,271 Posted August 21, 2016 Ooops, thanks mate, My bad. Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted October 11, 2016 Do apoligise for the late reply!! Paull, your setup looks neat, i like it. So it'll be at least a day job to fit an aftermarket shifter? I still plan on going with the Megashifter and keeping it a 3 seater so i have to ether get the bench seat modified or go back to bucket seats with a dicky seat in the middle. Share this post Link to post Share on other sites
