CHESTNUTXE 7,318 Posted December 29, 2015 Hey how the hell does this hex bolt or screw come out ? is it a reverse thread ? i cant budge it,any idear's,i have put penetrene . Share this post Link to post Share on other sites
gerg 10,871 Posted December 29, 2015 That's the pump shaft, the pulley presses onto it. You need a power steer pump puller to get it all apart. Some shops might do it for 20 bucks. The hex is there I presume as part of the machining process of the shaft. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted December 29, 2015 i knew i should have taken it to the shop,i will tomorrow,cheer's. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
scottly 475 Posted December 29, 2015 Make sure your pulley is straight and the pressure of the clamps didn't bend it, my Xd ute had a slightly warped pulley and it use to throw the belt off over 4000rpm 1 Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted December 29, 2015 only wimpy clamps ,i will leave it up to the pro's,i cant get it off,i just spoke to another member he has the tool ! 1 Outback Jack reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted December 29, 2015 Yeah it's a specific tool for Saginaw pumps, has a pair of collars that go around the groove on the snout. Using a jaw puller either on the groove or around the pulley will fuck it really good. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted December 29, 2015 It's c2 ford pump,6cyl ,i didnt try to force it,just left it for a mate with the correct tool to take them off. 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted January 4, 2016 YEP MY MATE DID IT IN 3 MINUTES WITH THE CORRECT TOOL ! 2 gerg and bear351c reacted to this Share this post Link to post Share on other sites
winton 399 Posted April 12, 2016 Haha that picture needs to be turned into a meme 1 MNTL.XD reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted April 12, 2016 Lol, wait till you have a VS commodore 304 V8 pulley - they don't have the collar to grab onto. Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted April 12, 2016 silly thing is there is no screw on the pump ,its just pressed on ! 1 winton reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted April 12, 2016 There's a thread in the center hex shaped hole. That's what's used to pull/press the pulley off and on. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted April 13, 2016 Dave i was convinced i need a big allen key so i went and bought a set ,and after all that it didnt need them to take it off,old mate up the road took it off with the pully puller. Share this post Link to post Share on other sites
