SPArKy_Dave 8,929 Posted December 1, 2015 sell daves he won't use it lol Cortina for life What about one of Daves 100 million BTR boxes? Just tape a bunch of those together, and call it a built C4. It'd weigh about the same. 3 dougie77, Nath and PRO250 reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,929 Posted December 1, 2015 I'd like to know what in particular fails in high power BW40 boxes. ie, is it a consistent failure across many boxes? I have the BW40 in my XE wagon adjusted so gear changes are super fast and sharp on WOT. It really snaps the 1-2 gear changes. And there's room for further refinement IMO. I got to drive Dave's XF Ghia sedan last Thurs, and I found the C4 box to be a bit harsh compared to my BW40. It was marginally quicker than my wags, but harsher. Be nice if the dash speedo worked though - luckily I noticed the GPS readout speedo. 1 dougie77 reacted to this Share this post Link to post Share on other sites
PRO250 1,506 Posted December 1, 2015 A bit harsh? you mean a bit stuffed? I think that box has been to the end of the world and backwe are lost to why he wants to boost his ute that or his corty would be much better suited to boost 2 SPArKy_Dave and dougie77 reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted December 2, 2015 I run a 24/26 spline c4 in my grey v8 corty that thing lifts the front wheels off the deck and ive never hurt it in 500+ passes its a stock box with a hard input shaft (changed it when i went to a 4k convertor to be a 24 26 spline box is just the input shaft if you run a 26 spline convertor you can just change it it just pulls out Have you got any photos of this beast in action? As you know I am playing with a TD atm and I'm loving the light weight of them. They are an awesome little beast. Can't believe it has taken me this long to own one. Share this post Link to post Share on other sites
PRO250 1,506 Posted December 2, 2015 Some old pics form calder id drive down run some numbers and drive home was a good car over serviced real bad but never done any real work to it a real basic engine with not bad manners that runs 11s on 91 fuelId like to try toytoys engine in it as it runs 2mph less in a car thats almost 400kg heaver that was on street rubber [/url]">http:// [/url]">http:// 3 dougie77, ricktewagon and Nath reacted to this Share this post Link to post Share on other sites
Nath 1,975 Posted December 3, 2015 What donk was it running? 1 PRO250 reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted December 3, 2015 Some nice squat on the rear there. Looks similar to mine but mine has 80's pumped rear guards. Similar scoop as yours. 1 PRO250 reacted to this Share this post Link to post Share on other sites
PRO250 1,506 Posted December 8, 2015 Has a washed up stock clevo with a cam and tidy valve trainpics of yours ando? oww I got that manifold to cheers 1 Nath reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted December 8, 2015 The day I picked her up after 12 years of sitting up in the dry country on the tablelands. Ran at Townsville many many years ago and by all accounts was very fast. Triple weber crossflow power and toploader - true 80's cool and yes those rear guards are pumped. 4 Nath, dougie77, Ants and 1 other reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,372 Posted December 8, 2015 looks mean Share this post Link to post Share on other sites
ando76 4,354 Posted December 8, 2015 Cheers mate - she is far from pretty but I like her. Full drag spec so no interior, no headlights the works. Changed the fuel pump and line and the triples fired into lift like it had never stopped. 2 steve mcqueen and Nath reacted to this Share this post Link to post Share on other sites
PRO250 1,506 Posted December 9, 2015 looks ok is it good?still got the triple carby engine in it? how fast? Share this post Link to post Share on other sites
wagoon 2,429 Posted December 9, 2015 Are they crossplys on the front? Share this post Link to post Share on other sites
ando76 4,354 Posted December 9, 2015 Yep. Still triples. High 12's. Yeah Ryan. Cross plys cause it has Full slicks on back. 14" on 12 slotters. It's in ok condition. Bit of rust work to do. Rear floor has been strengthened around top arm mounts. Front rails need love. It's at the right place tho. Share this post Link to post Share on other sites
PRO250 1,506 Posted December 9, 2015 12s in a manual is ok I could never get mine to hook as a manual althow had a few 110ish mph time slips so ok for a manual 6 Share this post Link to post Share on other sites
Grimmy 312 Posted December 9, 2015 I shouldn't have looked in here . Now I'm all hard for a tc/d to put my xflow in haha Share this post Link to post Share on other sites
ando76 4,354 Posted December 9, 2015 yes - they are pretty cool things to play with. Share this post Link to post Share on other sites
CHESTNUTXE 7,372 Posted December 9, 2015 By today's standard's ,would the triple's have any advantage over the large 4 barrel manifold and carby set up,or is it more for show,i no a lot of car's had triple's back in the day,charger,torana,ect.... Share this post Link to post Share on other sites
slydog 7,873 Posted December 10, 2015 By today's standard's ,would the triple's have any advantage over the large 4 barrel manifold and carby set up,or is it more for show,i no a lot of car's had triple's back in the day,charger,torana,ect.... LOL well Mossy's Cortina went 11.38 with a 4 barrel now it goes 11.0 with a 3x50mm webers. Yeah they work... 1 Nath reacted to this Share this post Link to post Share on other sites
bear351c 10,277 Posted December 10, 2015 4 bbl manifold has extremely long runners to get fuel to No 1 and 6. and triples look waaaay cooler...... 1 Razorback reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,372 Posted December 10, 2015 yeah thats why i was asking Share this post Link to post Share on other sites
ando76 4,354 Posted December 10, 2015 Big H racing made some solid numbers with a Aussiespeed 4 barrel manifold on the engine dyno and that car ran solid numbers at the track. Jason Murphy in Toowoomba has just made 270rwhp with the same 4 barrel manifold. I made 260 odd with a head that only flowed 196cfm with the exact same manifold. All that is nothing to be sneezed at. Having said that - THERE IS NOT SUBSTITUTE FOR AN INDIVIDUAL RUNNER setup. Pure and simple.Sly has highlighted it clearly in the above example. Here is my experience. THOR (my roller cam head) was ported to suit a non-individual runner style manifold. It flowed very very well (over 235cfm) in that form. Cam just 're-ported' it to suit the weber manifold and we picked up 10cfm. That is a huge gain. Mind you I am chasing some serious numbers with this engine, so I am prepared to spend the serious dollars it takes to achieve them. Would I go individual runner for a tough streeter/ sometimes drag car. Nope. Share this post Link to post Share on other sites
CHESTNUTXE 7,372 Posted December 10, 2015 Big H racing made some solid numbers with a Aussiespeed 4 barrel manifold on the engine dyno and that car ran solid numbers at the track. Jason Murphy in Toowoomba has just made 270rwhp with the same 4 barrel manifold. I made 260 odd with a head that only flowed 196cfm with the exact same manifold. All that is nothing to be sneezed at. Having said that - THERE IS NOT SUBSTITUTE FOR AN INDIVIDUAL RUNNER setup. Pure and simple.Sly has highlighted it clearly in the above example. Here is my experience. THOR (my roller cam head) was ported to suit a non-individual runner style manifold. It flowed very very well (over 235cfm) in that form. Cam just 're-ported' it to suit the weber manifold and we picked up 10cfm. That is a huge gain. Mind you I am chasing some serious numbers with this engine, so I am prepared to spend the serious dollars it takes to achieve them. Would I go individual runner for a tough streeter/ sometimes drag car. Nope. Share this post Link to post Share on other sites
CHESTNUTXE 7,372 Posted December 10, 2015 What sort of cfm are these webbers ? 200?each Share this post Link to post Share on other sites
PRO250 1,506 Posted December 10, 2015 I remember when I want to webers I got told there a waste of time after trying everything carby manifold wise on mine I remember glen telling me there shit as well, you know a person that had not run themJims was going to go to webers but it something there going to do later now, but a real 400hp real street car that thing still has everything fitted I real credit to harry and his love for 6cyl clevos Share this post Link to post Share on other sites
