RAWDEAL 222 Posted November 5, 2015 What type of fan sensor are you running??? Are they multi speed or single speed. I knew a guy who changed his whole engine due to over heating, only to find it was the high speed fan relay not working. Fans were only operating at low speed & couldn't keep the thing cool. That was in an XH ute. they are just either off , or high. they are AU fans Share this post Link to post Share on other sites
RAWDEAL 222 Posted November 6, 2015 So today i fixed the bottom hose. it has a spring in it now. also i have tested the themostats 72c orignial one that was in it , is fine and opens at around 70 81c high flow i bought today, opens at 81 81 normal flow i bought a while ago, also opens at 81im gonna install the high flow Tridon Themostat, and see how that goes.. i really cbfd taking the themostat housing off again so hopefully this works 2 Outback Jack and gerg reacted to this Share this post Link to post Share on other sites
Stu5766 394 Posted November 12, 2015 Is it fixed now? Share this post Link to post Share on other sites
bear351c 10,271 Posted November 12, 2015 Yeah, yeah, yeah..........do tell.! 1 Stu5766 reacted to this Share this post Link to post Share on other sites
RAWDEAL 222 Posted November 12, 2015 I have not driven it ! lol I will be on saturday so ill update then! Share this post Link to post Share on other sites
RAWDEAL 222 Posted November 15, 2015 took the car for a run. around town it sits on 82-86 on the highway it creeps up to 100 again???? also when idling it cools down? arghh Sent from my GT-I9505 using Tapatalk Share this post Link to post Share on other sites
judgetread 758 Posted November 15, 2015 sounds like water flowing to fast .... thus not giving the water in the radiator enough time to actually cool down. That would explain why it cools down at idle, slower flows giving the coolant time to cool down Are you using a high flow thrmostat? maybe go back to a normal one .. or top pulley wrong size? Share this post Link to post Share on other sites
judgetread 758 Posted November 15, 2015 or a belt slipping at higher rpm? Share this post Link to post Share on other sites
SPArKy_Dave 8,882 Posted November 15, 2015 took the car for a run. around town it sits on 82-86 on the highway it creeps up to 100 again???? also when idling it cools down? arghh Sent from my GT-I9505 using Tapatalk Might be running too lean. The EECV computers have lean cruise for fuel saving. Or a partially blocked radiator will do that too. Share this post Link to post Share on other sites
bear351c 10,271 Posted November 16, 2015 Starting to sound more like a blocked radiator. Any chance you have a spare?? Rad can be 50% blocked and still the water comes out clear when flushing. Share this post Link to post Share on other sites
RAWDEAL 222 Posted November 16, 2015 sounds like water flowing to fast .... thus not giving the water in the radiator enough time to actually cool down. That would explain why it cools down at idle, slower flows giving the coolant time to cool down Are you using a high flow thrmostat? maybe go back to a normal one .. or top pulley wrong size? Its all factory stuff. new water pump new everything now. even the fans and radiator when im on the highway the revs are pretty low... below 2000, not to sure as i dont have a tacho lol so id say the revs would be higher on average when im around town the belt doesnt seem to be slipping Ive just gone from a normal flow to a high flow and the themostats were both tested to work. the high flow helped a bit its on lpg with an impco425 and an msd 6530. I have changed the gas carb and it diddnt help Share this post Link to post Share on other sites
deankxf 20,294 Posted November 16, 2015 what ratio is in the diff and what is the top gear ratio.. i found when i fitted an AOD to MY XE many years ago with 2.92 gears it didnt like driving below 2000rpm on the highway, seemed more throttle required than the C10 without overdrive. i dont recall running hotter, but that could well be the cause, labouring due to being out of even the cams range and ign timing etc Share this post Link to post Share on other sites
RAWDEAL 222 Posted November 16, 2015 what ratio is in the diff and what is the top gear ratio.. i found when i fitted an AOD to MY XE many years ago with 2.92 gears it didnt like driving below 2000rpm on the highway, seemed more throttle required than the C10 without overdrive. i dont recall running hotter, but that could well be the cause, labouring due to being out of even the cams range and ign timing etc At the moment its i think (not 100% sure) a .75 top gear ratio and 2.92 diff is whats in it , because i blew the last one up haha ive tried to drive it in 5th instead of 6th for 5-10 mins.. just makes more noise tbh Share this post Link to post Share on other sites
deankxf 20,294 Posted November 16, 2015 At the moment its i think (not 100% sure) a .75 top gear ratio and 2.92 diff is whats in it , because i blew the last one up haha ive tried to drive it in 5th instead of 6th for 5-10 mins.. just makes more noise tbh is 4th 1 to 1, assuming it will make more noise, does it get hot.. comes back to My original point of labouring outside the range of the cam etc i tried 3.23 with My AOD then went to 3.45 and then the ratios were all wrong for the rest of it..i should have left it C10 auto. Share this post Link to post Share on other sites
RAWDEAL 222 Posted November 16, 2015 At the moment its i think (not 100% sure) a .75 top gear ratio and 2.92 diff is whats in it , because i blew the last one up haha ive tried to drive it in 5th instead of 6th for 5-10 mins.. just makes more noise tbh is 4th 1 to 1, assuming it will make more noise, does it get hot.. comes back to My original point of labouring outside the range of the cam etc i tried 3.23 with My AOD then went to 3.45 and then the ratios were all wrong for the rest of it..i should have left it C10 auto. its a 6 speed manual so 6th is 0.75 i think. unfortunaly dont have a tacho at the moment Sent from my GT-I9505 using Tapatalk Share this post Link to post Share on other sites
SPArKy_Dave 8,882 Posted November 16, 2015 It's a fuelling/timing issue then. look at the injectors, fuel pressure, fuel pump and IAT sensor/CT sensor and dizzy hall effect sensor, plus the TFI module. It will likely be one of those things. My EL V8 wagon has always had the exact same problem. I've done an enormous amount of research, into how the EECV engine management system works. or failing all the above...... it's got a blown head gasket (or gaskets). Share this post Link to post Share on other sites
Banno 479 Posted November 16, 2015 Pretty sure he said that it is lpg with a msd ignition. Could be leaning out at open throttle or a vacuum leak. What converter does it run and has ever been serviced or cleaned? Share this post Link to post Share on other sites
Stu5766 394 Posted November 16, 2015 It's a fuelling/timing issue then. look at the injectors, fuel pressure, fuel pump and IAT sensor/CT sensor and dizzy hall effect sensor, plus the TFI module. It will likely be one of those things. My EL V8 wagon has always had the exact same problem. I've done an enormous amount of research, into how the EECV engine management system works. or failing all the above...... it's got a blown head gasket (or gaskets). He said it's a straight gas mixer with MSD ignition. Where did you purchase the radiator from?? Is it a reputable brand or an eBay Chinese radiator? Share this post Link to post Share on other sites
RAWDEAL 222 Posted November 17, 2015 It's a fuelling/timing issue then. look at the injectors, fuel pressure, fuel pump and IAT sensor/CT sensor and dizzy hall effect sensor, plus the TFI module. It will likely be one of those things. My EL V8 wagon has always had the exact same problem. I've done an enormous amount of research, into how the EECV engine management system works. or failing all the above...... it's got a blown head gasket (or gaskets). there is ZERO EFI gear on this car lol msd 6530 digital programable impco 425 standard dizzy that i had the rotor phased properly not sure where to start Share this post Link to post Share on other sites
RAWDEAL 222 Posted November 17, 2015 He said it's a straight gas mixer with MSD ignition. Where did you purchase the radiator from?? Is it a reputable brand or an eBay Chinese radiator? i think it was orignally a SSS auto parts radiator i know it works because it was 100 degrees untill i got home and idled it for 5 mins and it went back down to 85, this was sunday , in geelong, so it was about 25 degrees outside Share this post Link to post Share on other sites
Stu5766 394 Posted November 17, 2015 How much advance are you running?? Share this post Link to post Share on other sites
SPArKy_Dave 8,882 Posted November 17, 2015 So you're still running the standard dizzy with TFI and hall effect sensor?That's number three on my list. Share this post Link to post Share on other sites
RAWDEAL 222 Posted November 21, 2015 So you're still running the standard dizzy with TFI and hall effect sensor? That's number three on my list. yeah ita on your list but 3/4 of it isnt haha what actually clould go wrong with the dizzy/how can i tell? i think its 10 btdc idle and 35 all in at 3500 but i could be wrong its been ages Sent from my GT-I9505 using Tapatalk Share this post Link to post Share on other sites
