RAWDEAL 222 Posted June 21, 2015 I got offered to buy a Xr6 turbo ute diff to buy. I pulled the rear cover off of it to see weather it was a LSD or not All i see are spider gears ? i am not sure on a 100% way to check wether its an lsd lol I turned one axle and the opposite axle turned the OPPOSITE way ? what is a sure way to know? I know it is the m86 ect . but i want an LSD Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted June 21, 2015 It's a Open diff. LSD is a sealed hemisphere 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
RAWDEAL 222 Posted June 21, 2015 It's a Open diff. LSD is a sealed hemisphere Are you sure, you have opened one of these up yourself? I have some more photos from Chaise 'ILIED' , of his LSD center, it looks like the one above Share this post Link to post Share on other sites
Thom 6,654 Posted June 21, 2015 If the Axle spins the opposite way it's an open center, if it spins the same way it's an lsd 5 tpak addict, Outback Jack, XTREME KARTS XF and 2 others reacted to this Share this post Link to post Share on other sites
tpak addict 1,909 Posted June 21, 2015 Thom is on the money, quickest and easiest way to check..... Not all XR diff's are LSD. It was an option same as all models even the egas..... 1 Thom reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted June 22, 2015 On the older borgie lsd they had 2 rings of bolts on the hemisphere: inner ring for the two halves and the outer for the crownwheel. Open centres use the crown wheel bolts to hold the halves together 1 Thom reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted June 22, 2015 I thought all XR6Ts got LSD? And I wouldn't trust the "spin same way its LSD". My G6E spins both the same way but it's open, if you hold one wheel the other will still spin. My ute has a (stuffed) LSD, both wheels spin the same way but it no longer puts power to the wheel that has more resistance. Share this post Link to post Share on other sites
tpak addict 1,909 Posted June 22, 2015 If anyone would know its Phantom... When it comes to ford stuff he knows, may pay you to send him a PM if you want to know for sure..... Share this post Link to post Share on other sites
Gaz 1,085 Posted June 22, 2015 Don't ever rely on the "spins same way/spins opposite way" theory. Some LSD's only work under the right circumstances i.e. traction/power. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
RAWDEAL 222 Posted June 22, 2015 Interesting info http://www.fordmods.com/gearbox-suspension-brake-driveline-f4/ba-m86-same-as-fg-m86-no-t113675.html 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted June 22, 2015 Yes very interesting..... FG diffs are 1550 mm flange to flange and BAs are 1500. Means you could cure that age-old Falcon trait of the rear wheels sitting in too far by fitting an FG diff and not have to run wideys on the back. Share this post Link to post Share on other sites
RAWDEAL 222 Posted June 23, 2015 Yes very interesting..... FG diffs are 1550 mm flange to flange and BAs are 1500. Means you could cure that age-old Falcon trait of the rear wheels sitting in too far by fitting an FG diff and not have to run wideys on the back. Or do the opposite in a FG with a ba diff , which is what id do with a fg ute lol 1 gerg reacted to this Share this post Link to post Share on other sites
RAWDEAL 222 Posted June 23, 2015 UPDATE: im going around to look at it on thursday anyways . i am going to hold the pinion in place hold one axle see if i can turn the other axle if i cant its an LSD Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted June 23, 2015 Looks like I may be wrong, you can see with this one the clutchs in the back. http://m.ebay.com.au/itm/181430158090?_mwBanner=1 Share this post Link to post Share on other sites
RAWDEAL 222 Posted June 25, 2015 Looks like I may be wrong, you can see with this one the clutchs in the back. http://m.ebay.com.au/itm/181430158090?_mwBanner=1 Cheers for that , ILIED (chaise) sent me a photo of his and it looked just like that . had issues with photobucket, so i couldnt upload them i am going to sus the diff tonight and prolly purchase it Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted June 25, 2015 The smartass answer is install it and pull a burnout My answe is to look for the tag for lsd oil Yeah I know probably as useful and locking the screen door on the submarine to keep the water out 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
RAWDEAL 222 Posted June 26, 2015 The smartass answer is install it and pull a burnout My answe is to look for the tag for lsd oil Yeah I know probably as useful and locking the screen door on the submarine to keep the water out Ill be testing , test number 1 , in the near future lol they are really weird. my friend brian came with me to double check the diff last night ends up it acts as a pegger normally , UNTIL its under LOAD then its like a lsd ill get more pics .. as i am still sorta curious on how it works myself Share this post Link to post Share on other sites
