tpak addict 1,909 Posted June 9, 2015 Aaah yes, the handling characteristics of the humble HQ.........the stuff of legend. Hahaha yeah I remember way back when I was a lad doing donuts in the HK I could get it to do perfect circles on dirt (one front wheel staying in the one spot). HQ just couldnt do that..... I remember a mate having a HQ with a 350 and it would go sideways in a straight line doing a burnout, that was kinda cool tho.... 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Squid 55 Posted June 18, 2015 I think I'll lower the upper control arm And replace the ball joints on the upper arm, any brands to look for? That won't bind with the height it is? Share this post Link to post Share on other sites
broken-wheel 659 Posted June 18, 2015 if you're only doing a 1" drop then any balljoint should be fine, just pop the rubber booth off and have a look and see if it has the notches to allow enough travel, you can probably buy it from http://www.moog-suspension-parts.com/moog-k8142 shoot them an email with size but the 3 bolt should drop straight in 1 Squid reacted to this Share this post Link to post Share on other sites
broken-wheel 659 Posted February 23, 2017 Here is a really low drop done properly with NO binding this low bump stops cut half, has 3" clearance, too low for my liking but does not bind or hit the bump stops with Kmac 650 pound springs, under heavy brake it does not hit the bump stops at this level of low the LCA is not parallel to the ground so you are loosing a little handling hence I'm putting in new springs to raise it to parallel 1 bear351c reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted February 23, 2017 You haven't seen Christo's old barge have you? Still to this day, I dunno how he did it... Nice job btw! Share this post Link to post Share on other sites
deankxf 20,294 Posted February 24, 2017 You haven't seen Christo's old barge have you? Still to this day, I dunno how he did it... Nice job btw! this one? 2 Thom and SPArKy_Dave reacted to this Share this post Link to post Share on other sites
BGDAV 1,873 Posted February 24, 2017 (edited) he had drop spindals didnt he ? cut the tunnel up and fitted mega towers Edited February 24, 2017 by BGDAV Share this post Link to post Share on other sites
