XPT 673 Posted July 5, 2015 Got the muffler bodies welded up and installed, decided to add some volume to the centre section of each by welding in a strip between the two halves. Made the mistake of using gal steel and first one welded up like shit. Second one I got the shits and just oxy'd it all up, a bit neater this time round. Yes I did try and grind off the zinc first, but it was still crap.I still need to build the rear section so for now I just have them dumping at the diff. It's pretty loud.Got some BA resonators up front now, hope that will kill some of the boom.Going to 2-1/4" for the last foot or so to mellow it a bit more. Just go 2-1/2 I've got 2 meters of it that I'm not going to use. 1 gerg reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted July 5, 2015 How much weight is in them? And yes we need a sound clips Share this post Link to post Share on other sites
slydog 7,873 Posted July 5, 2015 Bit late I know but if you have argo sheild gas turn it up a touch more and use a push pull push technique to weld it out. The first pass burns the zinc off the pull preps the area the last push welds it out. 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 6, 2015 Good info for all there. I have noticed that once you burn through the Zinc it's ok. Maybe should have hit it with the oxy once i tacked it all just to burn it off before i mig it. Share this post Link to post Share on other sites
wagoon 2,429 Posted July 6, 2015 If you have access to a stick welder you can also use a rod call weldall or known as a maintance rod. These rods also for welding dissimilar metals or unknown metals but will also weld through grease and oil and contaminated steels. 2 gerg and slydog reacted to this Share this post Link to post Share on other sites
XPT 673 Posted July 6, 2015 I use a flapper disc for weld prepping on gal, it's not as harsh. Grind until sparks are coming off, job done. It welds fine 2 slydog and gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 6, 2015 She wasnt warmed up so not too much rpm. Bit smoky too  1 bear351c reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted July 6, 2015 sounds pretty crisp to me, well done mate 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 6, 2015 Shit video though, did it in a rush before starting on the rear section. With a young family, time is more valuable than gold these days 2 wagoon and Outback Jack reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,890 Posted July 6, 2015 She wasnt warmed up so not too much rpm. Bit smoky too   Ahhh, the good old italian tuneup.  Blew those cobwebs right out of there........ 3 Nath, slydog and gerg reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted July 7, 2015 That sounds pretty bloody good bro. I'd be happy to drive around with that noise fo sho 2 Nath and gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 7, 2015 Ok promise to make a proper clip once the rest of it is in and welded. 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 11, 2015 Rear section welded & cold gal'd   Drove it tonight, it's still fricken loud. Note is nice though. 2 wagoon and Thom reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 13, 2015 Â Sounds better on a stereo or headphones though 5 XPT, bear351c, Outback Jack and 2 others reacted to this Share this post Link to post Share on other sites
XPT 673 Posted July 13, 2015 Cover your plates you knob. Sounds good though, you need to do those valve stem seals Share this post Link to post Share on other sites
gerg 10,871 Posted July 13, 2015 Can't cover them from phone... No apps for that  Stem seals.... I was told that modern fuels ruin them in no time. Might be able to do them in the car but engine out would be easier. Share this post Link to post Share on other sites
XPT 673 Posted July 13, 2015 The cardboard and sticky tape app 5 gerg, Ando81, dougie77 and 2 others reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted July 13, 2015 Can't cover them from phone... No apps for that  Stem seals.... I was told that modern fuels ruin them in no time. Might be able to do them in the car but engine out would be easier.  Funny I was only just talking about this to Mossy the other day. Years ago leaded fuels did nothing to ours but made em run good,but were no good for us.Now the modern fuels are better for us but no good for our cars 2 Thom and gerg reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted July 13, 2015 sounds great now - good effort. 1 gerg reacted to this Share this post Link to post Share on other sites
Nath 1,975 Posted July 13, 2015 That sounds unreal! 1 gerg reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted July 14, 2015 Top work mate sounds pretty good to me. 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 14, 2015 Cheers folks, adding a crossover pipe next. Very boomy/droney being a wagon and all. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 21, 2015 Crossover installed   Made fuck-all difference to the drone 1700-2000 rpm. Surprised really. Very happy with the note though.  Might drop the size down to 2-1/4" for the last foot or so. Also some clearance issues with the leaf springs, especially on the passenger side where the fuel filler and lines get in the way. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
XPT 673 Posted July 21, 2015 You'll end up making it sound like a 253 HQ tonner 1 slydog reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 21, 2015 Well that is the pinnacle of V8 sound 1 slydog reacted to this Share this post Link to post Share on other sites
