bigpaulo 239 Posted August 13, 2014 Under bonnet superchargers: has anyone done one? Im talking on a carb 250. Ive heard about these castlemaine rod shop bolt on sc kits...but cant find any reviews from anyone whos used them... What is required to set up an under bonnet sc? Intercoolers? A lot of mods? Do you need a special carby? Im not planning on supercharging at this stage, just trying to arm myself with some information. Cheers! Share this post Link to post Share on other sites
PRO250 1,506 Posted August 13, 2014 There are a few m90s off commodores going around. They seem to just fit under the bonnet of a falcon (didnt on my cortina) cause the carby is mounted behind the charger. They seem to work but you cant boost them they just turn into heat pumps. Ive done one they work to about 200hp and then you push them harder to make more and they go the other wayThe little s14s like a rod shop kit i would not bother ive not run this setup but they dont work the money you spend vs gain it would not be worth itIve done 3 blower setups on 250s. The first was a old wade superchager setup it gave good gains over the basic NA engine, it was on 7psi but it was a super heavy charger and the bracket would fail all the time, i sold it and went to a m90 off a commodore. I made a longer snout and made it fit a 4 barrel manifold. It worked yes but as soon as i tryed to push it past 10psi it would make less power i got 210rwhp out of it but the engine was making a 163hp before the blower so not much real gain since it cost about 2500 bucks to setupMy last setup is a B&M roots blower on a custom manifold and on 7psi it flew, At 12 is was very good, at 15 i killed the engine but it would turn the tyres 1st 2nd 3rd and a fair bit of 4th on a boat ancor XF with a 245 tyre. I never dynoed it but its as fast as my ute so at least 300rwhp on a engine that was not even built for boost with a very small cam. I built it to get 400 at the tyres on a built engine and i know it could do it without to much hassle ill ding a few pictures out as they looked cool i dont think i have any of the m90 one as i never had a camera back then the wade one i have a few a mate took while i was making it and just dummyed up in the carthe B&M one in the XF heres a video i took of it a while ago before i smashed the engine LOLedit it will not work ill try again later 5 XPT, xbcool, Thom and 2 others reacted to this Share this post Link to post Share on other sites
bigpaulo 239 Posted August 13, 2014 thats some awesome info thanks for that! so did all your setups fit under the bonnet? i'm keen to see the pics and video! Share this post Link to post Share on other sites
PRO250 1,506 Posted August 13, 2014 7 Hofiveo, clevocortina, bigpaulo and 4 others reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted August 13, 2014 That is cool. looks like engine mounts wouldn't last to long Share this post Link to post Share on other sites
bigpaulo 239 Posted August 13, 2014 hahaha that is monstrous! what an awesome looking setup! wouldnt quite fit under the bonnet tho...haha Share this post Link to post Share on other sites
PRO250 1,506 Posted August 13, 2014 Nar sure dont fit under but its a diffrent thing till aussiespeed finnish copying it Share this post Link to post Share on other sites
Stevemack 122 Posted August 17, 2014 Those little toyota ones that the rod shop do are almost worthless on a falcon. Turbo that sucker! 2 XPT and PRO250 reacted to this Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted August 17, 2014 Those little toyota ones that the rod shop do are almost worthless on a falcon. Turbo that sucker! Local bloke here has one of these on his XE, I think its good for 7psi? He built all the brackets and what not himself. Share this post Link to post Share on other sites
XPT 673 Posted August 18, 2014 Toyota SC14 is off a 2 litre 1ggze by the time they make boost on an engine more than twice the size they would be roasting the air. Blow through turbo would shit on any s/c setup in terms of power and price. Far easier to add an intercooler as well. If you're having it under bonnet then you aren't going for the visual appeal of a blower, so you might as well make power. 1 Stevemack reacted to this Share this post Link to post Share on other sites
