Panko 2,482 Posted June 24, 2014 Hi guys, Im about to remove the LPG from my injected XF, and take it back to petrol. Obviously when the lpg was installed it had the wiring modified for the fuel system, so both the petrol side of it and gas side of run through the 1 single relay. When i remove the LPG, what wiring will i need to do, to assure that once ive removed the LPG switch and solenoid, the car will still run on petrol? Share this post Link to post Share on other sites
Anthony Pllu 262 Posted June 25, 2014 when i removed mine on the efi250 for a clevo conversion i pretty much just unplugged a few things at a time and kept checking that i had 12v to the pump. after taking everything out i still have 12v to the pump wiring, but no pump now im carbie. so should be the same for you but all gas systems are different and makes it anoying Share this post Link to post Share on other sites
Stevemack 122 Posted June 25, 2014 Follow all the wiring back till you find where they originally cut the loom, and rejoin it. should be pretty easy. 2 Ants and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
hendrixhc 10,921 Posted June 25, 2014 Cut Cut cut and insulate! 1 Ando81 reacted to this Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted June 25, 2014 and polish. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted June 25, 2014 Pretty sure my Ghia just had it disconnected, would have to ask Nova to be sure. But it still had switches to change from petrol to LPG, was a great immobilizer/killswitch. 2 XTREME KARTS XF and Lord_fahrquhar reacted to this Share this post Link to post Share on other sites
Panko 2,482 Posted June 25, 2014 Pretty sure my Ghia just had it disconnected, would have to ask Nova to be sure.But it still had switches to change from petrol to LPG, was a great immobilizer/killswitch. Yeah see thats what has me worried chris. When i flick the fuel switch to gas, the fuel pump continues to run, but all it does it switch the injectors off (they tick when they are running, so i hear them shut off) but the fuel pressure is kept up. So i need to find the wiring to the injectors, and fix it up there, not so much about keep the fuel pump running. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted June 25, 2014 Must be wired differently to how my wagon was then, flicking the switch killed the high pressure pump in mine. Share this post Link to post Share on other sites
Ants 6,370 Posted June 25, 2014 Follow all the wiring back till you find where they originally cut the loom, and rejoin it. should be pretty easy. Says it all really,trace every wire,rejoin any that are cut. Not that hard mate. 2 Stevemack and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Panko 2,482 Posted June 26, 2014 Yeah i guess so. It will be under the bonnet, because there is a solenoid bolted to the strut tower thats for the LPG. Share this post Link to post Share on other sites
Stevemack 122 Posted June 26, 2014 There will be wiring going back into the cabin, which is where they put the changeover relay usually, Just follow it back, you will see the difference between the original and the gas wiring pretty easily. Rejoin where it's spliced into the loom, you'll be fine! 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
