ltdute 2 Posted May 3, 2014 Sorry if this is a stupid question but can anyone tell me what the funny lookin doodah next to the throttle body is? am looking at cutting up and modifying my inlet manifold to a front facing one and want to know if I can just chop it off? I would upload a picture for reference but I am computer illiterate haha Also the gadget at the back of the rocker cover (firewall end) is that the pcv valve? and do I still need that? bear in mind it is in the process of being boosted. Apologies if I sound stupid but im pretty new to all this efi stuff always had carby v8s so im working it out as I go Share this post Link to post Share on other sites
gerg 10,875 Posted May 4, 2014 Sounds like your idle speed control valve. Yes you need it! Yep sounds like that other thing is your PCV and yes you need that too. If you don't have it, you'll blow seals out when your engine breathes, especially if you boost it. Share this post Link to post Share on other sites
ltdute 2 Posted May 4, 2014 how do the guys with custom plenums get around it? looking at pictures of cars like xf-747 he appears to have blanked it off?? Share this post Link to post Share on other sites
Thom 6,716 Posted May 4, 2014 are talking about a 5.0, a 4.0 or a efi xflow? Share this post Link to post Share on other sites
steve mcqueen 1,797 Posted May 4, 2014 XF 747 (george) runs a xflo in his boosted falcon. Good to see you doing research ltdute before you chop into your machine. Share this post Link to post Share on other sites
adrianphu123 73 Posted May 4, 2014 right next to the throttle body on the plenum is the EGR valve. Just block it off with a plate. Share this post Link to post Share on other sites
Crazy2287 1,889 Posted May 4, 2014 I recommend learning how to post pics as that will remove any confusion an regards to what you are talking about. The idle control is bolted to the rocker cover adn the PCV valve will need to be kept but you'll just vent it to atmos via a catch can. 1 matt_lamb_160 reacted to this Share this post Link to post Share on other sites
ltdute 2 Posted May 4, 2014 Im trying crazy honest . have opened a photobucket acc. but still doesn't seam to work? From more research....(had a mate come and look today) Adrianphu123 seems to be right and its an egr valve so I will continue with cutting it off and see how I go Share this post Link to post Share on other sites
matt_lamb_160 252 Posted May 5, 2014 You better learn how to post pictures so you can show us what you have done! Sounds like an EGR valve to me. It is a cast alloy outlet going off at a 45 pointing towards the brake booster and two bolts to hold the valve in place? If so, cut it off if need be. Share this post Link to post Share on other sites
matt_lamb_160 252 Posted May 5, 2014 http://www.xfalcon.com/forums/index.php?/topic/27961-85-xf-efi-wont-kick-over/ Share this post Link to post Share on other sites
ltdute 2 Posted May 5, 2014 so this is the sort of thing i am trying to achieve sorry Ive ripped someone elses photo hope i dont offend Share this post Link to post Share on other sites
ltdute 2 Posted May 5, 2014 I do realise that its not an ideal inlet manifold but I can make this for nothing and it should run while I sort out a custom plenum, so long as number 6 cylinder doesnt run too lean Share this post Link to post Share on other sites
ltdute 2 Posted May 5, 2014 reason i want to front face it is I have stuck my wastegate right in the way.......... so figure its a good excuse to shorten the intercooler piping sorry for the blurry photo pretty crap lighting in my shed Share this post Link to post Share on other sites
XFGHIA747 76 Posted May 5, 2014 No. 6 wont run lean ol sav as its getting its fuel from the injector will run too rich if anything due to the air not getting back there but being the boost pressure if running/ just na there will be enough air volume in the plenum to fill cylinder. Hope I can help. Cheers jake. Share this post Link to post Share on other sites
ltdute 2 Posted May 5, 2014 good point xfghia747 cheers for your help Share this post Link to post Share on other sites
matt_lamb_160 252 Posted May 5, 2014 I like it. I have seen another one where the guy replace the plenum with a piece of pipe with a slight bend at the end to angle the TB in the desired position. The guy was on xfalcon. Faurly similar result really. Good to see you learnt how to do the pictures. EDIT: See silver Falcon engine bay: http://www.xfalcon.com/forums/index.php?/topic/26582-custom-plenums-250-crossflows-alloy-head/page-2 Share this post Link to post Share on other sites
Mr Polson 10,214 Posted May 5, 2014 I doubt the shape of the plenum would affect the a/f ratio of numbers 5/6 too much, look at FWD 4 cyl injected cars and they have similar intake setups to that. Share this post Link to post Share on other sites
