ltdute 2 Posted February 25, 2014 how have you turbo guys run your oil drain line? as in how did you get it into the sump is it an engine out sump off jobbie?? Share this post Link to post Share on other sites
matt_lamb_160 252 Posted February 25, 2014 Yep. I welded a 5/8" fitting in when I had the engine out to rebuild it. You might be able undo the engine mounts, lift up the engine and drop the sump enough to keep the swarf out. Drop the oil first. I recon engine out would be easier though. Share this post Link to post Share on other sites
gerg 10,871 Posted February 25, 2014 Just a thought, is there a chance of running it to the timing cover? Share this post Link to post Share on other sites
Falcon76 1 Posted February 26, 2014 I know a guy who hammered a piece of pipe cut off on a angle then tigged it in, didn't even drop the oil. Pretty dodge I know, been on for about 8 months now still dosnt leak. +1 for taking the engine out and doing it properly myself. Share this post Link to post Share on other sites
ltdute 2 Posted February 26, 2014 haha falcon76 sounds like something I would try. cant be arsed taking the damn motor out........... any one have any photos or links to photos showing the best location in the sump? apparently you need to watch for the oil pickup?? Share this post Link to post Share on other sites
KRUPTOR 929 Posted February 26, 2014 I done mine in car with bugger all room. Share this post Link to post Share on other sites
PRO250 1,506 Posted February 26, 2014 same i did mine on a hoist bud welded a bung to the top of the sumpdrained the oil then refiled when i was done did not want to wast 2nd had oil 1 KRUPTOR reacted to this Share this post Link to post Share on other sites
KRUPTOR 929 Posted February 26, 2014 I done mine on the ground (on jack stands),flared the sump and tapped a thread sealed my fitting in there and done. Share this post Link to post Share on other sites
ltdute 2 Posted February 26, 2014 cheers guys up on the hoist it shall go! where abouts in the sump is the best location? Share this post Link to post Share on other sites
matt_lamb_160 252 Posted February 27, 2014 same i did mine on a hoist bud welded a bung to the top of the sump drained the oil then refiled when i was done did not want to wast 2nd had oil How did you put the hole in the sump and not fill the sump with swarf? Share this post Link to post Share on other sites
PRO250 1,506 Posted February 27, 2014 How did you put the hole in the sump and not fill the sump with swarf? drill slow and hope for the best its not like it was a nice engine it was a 250.000km dunger Share this post Link to post Share on other sites
matt_lamb_160 252 Posted February 28, 2014 Fair enough. Share this post Link to post Share on other sites
RAWDEAL 222 Posted March 3, 2014 filter will pick it up anyways , in the pickup and the actual oil filter Share this post Link to post Share on other sites
Gravelrash 36 Posted March 3, 2014 Use a tapered punch and work your way up in size until a 1/2" or 3/8" npt hose fitting will fit just inside the tapered hole you made from the punch. Next use a air ratchet or rattle gun to screw the fitting in. No sparks, no heat or swarf using my method. Done that on several engines that are still in the car all with success. 1 nos2 reacted to this Share this post Link to post Share on other sites
ltdute 2 Posted March 3, 2014 now we are talking gravelrash can anyone tell me the best location in the sump to put the drain hole? Share this post Link to post Share on other sites
Gravelrash 36 Posted March 5, 2014 I'll measure it for you when I go down the shed tomorrow night. Share this post Link to post Share on other sites
gerg 10,871 Posted March 16, 2014 Another wacky idea... Use the sump plug as a banjo fitting? I did it on my corty as the block was out of a Falcon and hadn't been drilled for the Corty dipstick, so i made a banjo bolt, my own dipstick and tube. Share this post Link to post Share on other sites
TTXF 13 Posted April 14, 2014 I've heard of people covering a drill bit in grease to catch the swarf, never tried it personally... Share this post Link to post Share on other sites
adrianphu123 73 Posted April 15, 2014 Another wacky idea... Use the sump plug as a banjo fitting? I did it on my corty as the block was out of a Falcon and hadn't been drilled for the Corty dipstick, so i made a banjo bolt, my own dipstick and tube. I dont think an oil drain to the sump plug is a good idea. That port would feel the full weight of all the oil in the sump and prevent oil from freely returning to the sump. What about tapping the fuel block off plate if you're not running a mechanical fuel pump? plus you can remove it to drill. Share this post Link to post Share on other sites
ltdute 2 Posted April 15, 2014 is the mechanical fuel pump on the same side of the motor as the exhaust manifold? Share this post Link to post Share on other sites
ZL. 19 Posted April 15, 2014 No its intake side, has two bolts down near where the dipstick goes in. Share this post Link to post Share on other sites
gerg 10,871 Posted April 16, 2014 I dont think an oil drain to the sump plug is a good idea. That port would feel the full weight of all the oil in the sump and prevent oil from freely returning to the sump. What about tapping the fuel block off plate if you're not running a mechanical fuel pump? plus you can remove it to drill. Yeah fair call, banjos don't flow that well at low pressure, maybe a JIC/UN-O fitting would do it. Fuel pump flange is a good one if not using a mechanical one Share this post Link to post Share on other sites
ltdute 2 Posted April 16, 2014 seems a long way to run the hose round to the other side of the block? Share this post Link to post Share on other sites
adrianphu123 73 Posted April 20, 2014 is there room on the front timing cover to tap a hole for a fitting? Share this post Link to post Share on other sites
ricktewagon 39 Posted April 29, 2014 Mines on the turbo side, just behind alternator bracket up high on the sump. Was done with engine out. Ive been trying to get some pics up for about 45mins but unless I make them tiny they wont upload. even at 200x200 pixels Share this post Link to post Share on other sites
