revhead 1,392 Posted July 19, 2013 Ok guys i know theres some lpg pro,s in our ranks ,what im planning is a propper 2v headed 351 on straight gas,i have factory ,heads with the little 2 cast on the corners of the head ,i was thinking imco 425 ,but i want the converter on the motor not on the inner guard, Share this post Link to post Share on other sites
hendrixhc 10,921 Posted July 19, 2013 Im going back to fuel when i can afford it. Share this post Link to post Share on other sites
revhead 1,392 Posted July 19, 2013 Im going back to fuel when i can afford it. im going to lpg bc i cant afford it $1.61 here in n.s.w for fn e10 Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted July 19, 2013 ditch it for a twin gra setup, shits all over the other styles AFAIK. Share this post Link to post Share on other sites
revhead 1,392 Posted July 19, 2013 ditch it for a twin gra setup, shits all over the other styles AFAIK. twin gas research throttle bodies etc 2 bear351c and Thom reacted to this Share this post Link to post Share on other sites
PH351 314 Posted July 19, 2013 Subscribing to sit here and listen. If I put my clevo in my FE I have to run straight LPG. 1 revhead reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted July 19, 2013 like this! 2 Thom and PH351 reacted to this Share this post Link to post Share on other sites
hendrixhc 10,921 Posted July 19, 2013 You can have all the gas shit off my XC! Share this post Link to post Share on other sites
GspecZL 979 Posted July 19, 2013 The only thing is the GRA stuff is pricey. Not saying it isn't worth it. Just costly. 1 revhead reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted July 19, 2013 You can have all the gas shit off my XC! do you have the twin gas reaseah stuff if so  bring them to normanville bro! Share this post Link to post Share on other sites
Thom 6,654 Posted July 19, 2013 One of my mates has the twin gra setup on the 351 in his xd, awesome setup, makes 270 rwkw on straight lpg 1 revhead reacted to this Share this post Link to post Share on other sites
blackxt 699 Posted July 23, 2013 This is something I've been toying with twin impco 300a . Kinda a custom piece to have one mixer go left and one right I would run duel fuel. But with a holley throttle body it would work straight gas. One impco e and yeah. Share this post Link to post Share on other sites
revhead 1,392 Posted July 23, 2013 i did straight gas on my 302w powered L300,i used an eb v8 throttle body on an 8 mill plate facing the throttle body straight up ,and feed the gas in through a top carby set up ,it worked great Share this post Link to post Share on other sites
revhead 1,392 Posted July 23, 2013 it was a ripper ,might do 2x on my 351 but feed the gas through the pcv inlets Share this post Link to post Share on other sites
revhead 1,392 Posted July 23, 2013 see if this works https://www.facebook.com/photo.php?v=10150906200367001&set=vb.520002000&type=3&theater Share this post Link to post Share on other sites
revhead 1,392 Posted July 23, 2013 <iframe src="https://www.facebook.com/video/embed?video_id=10150906200367001" width="720" height="1280" frameborder="0"></iframe> Share this post Link to post Share on other sites
Thom 6,654 Posted July 24, 2013 Not visible due to privacy settings, that's all that came up, you Mat be better off up loading it as a YouTube video and posting the link 1 revhead reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted July 24, 2013 Never tried 'em, but I'm told GRA systems are the best. I used to run twin 425 converters on a Sprintgas system, (basically a thinner aircleaner), even TIG welded 2 of those alloy snorkel's together, so I could run an air cleaner either side of the carby. Would have looked awesome all polished up............never put it on. Share this post Link to post Share on other sites
