RM351 148 Posted December 3, 2022 Anyone has one or knows someone who has one?. Thinking of getting one but not sure where's a good place to put the antenna for my ute. The roof would probably be ideal but not like this: Share this post Link to post Share on other sites
hendrixhc 10,920 Posted December 3, 2022 Ive got one but have installed it yet. Im just going to put the aerial under the dash as close as possible to the top. 1 RM351 reacted to this Share this post Link to post Share on other sites
Thom 6,651 Posted December 4, 2022 My dad has one in his model a, the aerial is mounted on the dash in an inconspicuous spot, only time It doesn't have a signal is in big tunnels or underground car parks, his one is a speed hut unit 3 2redrovers, RM351 and deankxf reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted December 5, 2022 Are they legit in all States.? Or do you have to run an original speedo as well.?? Share this post Link to post Share on other sites
RM351 148 Posted December 5, 2022 On 12/4/2022 at 5:34 AM, hendrixhc said: Im just going to put the aerial under the dash as close as possible to the top. Which car you're installing? Would be better under the dash, no need to worry where to conceal the cable. Share this post Link to post Share on other sites
RM351 148 Posted December 5, 2022 16 hours ago, Thom said: only time It doesn't have a signal is in big tunnels or underground car parks, his one is a speed hut unit Yeah that's the downside. Looking at Speedhut gauges as well. Share this post Link to post Share on other sites
RM351 148 Posted December 5, 2022 1 hour ago, bear351c said: Are they legit in all States.? Or do you have to run an original speedo as well.?? No idea, didn't think it would be an issue so long it works. Share this post Link to post Share on other sites
bear351c 10,270 Posted December 5, 2022 Just thinking, GPS can be hit and miss with reception, if you go outback country, ... no speedo.! Share this post Link to post Share on other sites
RM351 148 Posted December 5, 2022 No probs in the outback country unless you're driving through a tunnel. Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted December 6, 2022 My GARMIN brand sat nav GPS unit has built in speedo and no antenna needed. Put it in any car plug it in and Bob's your father's brother. It also tells me where to go if i get lost 1 RM351 reacted to this Share this post Link to post Share on other sites
RM351 148 Posted January 13, 2023 On 12/5/2022 at 11:04 AM, bear351c said: Are they legit in all States.? Or do you have to run an original speedo as well.?? You were right to question that, upon further investigation I've found out it is not legal to have a GPS speedo in Australia. "A speedometer that relies solely on GPS will not be able to meet ADR 18 and therefore will not be legal in Australia for a vehicle with ADR 18 on the conformity plate." ADR 18 came in 2006 so I'm not quite sure if it applies to cars built from 2006 or applies to all cars no matter what year. In the end it's up to the individual if they wan't to install a GPS speedo, I'm sure many have done mods that isn't exactly legal. 2 deankxf and bear351c reacted to this Share this post Link to post Share on other sites
motoSycho 690 Posted January 13, 2023 I had one in my ute. I just stuck the aerial under the dash pad. Always worked perfectly fine, in fact it was always 100% accurate. But I swapped it out for a hard wired unit for engineering as the GPS unit wasn't legal. 2 bear351c and deankxf reacted to this Share this post Link to post Share on other sites
