jamie247 542 Posted August 15, 2022 Hi guys, for those running roller rockers can u post the tappet cover on ya xflows , want an idea of what ppl have done Share this post Link to post Share on other sites
deankxf 20,294 Posted August 15, 2022 6 minutes ago, jamie247 said: Hi guys, for those running roller rockers can u post the tappet cover on ya xflows , want an idea of what ppl have done aussiespeed make a spacer if that's what you need to lift the rocker cover up (alloy one or i guess for the steel also if it's needed) used to hear people using 2 gaskets back before that if it's needed. probably be other answers on the way if there's anything else out there. Share this post Link to post Share on other sites
jamie247 542 Posted August 15, 2022 Just now, deankdx said: aussiespeed make a spacer if that's what you need to lift the rocker cover up (alloy one or i guess for the steel also if it's needed) used to hear people using 2 gaskets back before that if it's needed. probably be other answers on the way if there's anything else out there. Probably going to need a new cover as well looks like mine has had a wrecking ball dropped on it lol Share this post Link to post Share on other sites
deankxf 20,294 Posted August 15, 2022 4 minutes ago, jamie247 said: Probably going to need a new cover as well looks like mine has had a wrecking ball dropped on it lol are you going to use the EFI one? that will need a spacer from memory. i thought the steel ones didn't need a spacer. Aussiespeed also make a rocker cover that probably doesn't need a spacer. https://www.aussiespeedshop.com/page/3/?s=crossflow Share this post Link to post Share on other sites
jamie247 542 Posted August 16, 2022 18 hours ago, deankdx said: are you going to use the EFI one? that will need a spacer from memory. i thought the steel ones didn't need a spacer. Aussiespeed also make a rocker cover that probably doesn't need a spacer. https://www.aussiespeedshop.com/page/3/?s=crossflow Stupid question how the fark do u do an oil change no oil cap on those ones im just curious Share this post Link to post Share on other sites
deankxf 20,294 Posted August 16, 2022 23 minutes ago, jamie247 said: Stupid question how the fark do u do an oil change no oil cap on those ones im just curious guess you use those breather holes to put oil in? Share this post Link to post Share on other sites
jamie247 542 Posted August 16, 2022 1 hour ago, deankdx said: guess you use those breather holes to put oil in? Yeah i thought that was the case, might try and case a good original one down and ad spacer 1 deankxf reacted to this Share this post Link to post Share on other sites
Slow250XC 1,517 Posted August 22, 2022 Steel cover and roller rockers. No tappy tappy. Only .55 lift though. 1 1 SPArKy_Dave and Fingers reacted to this Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted August 28, 2022 Yes use the breather hole to fill with oil on the Aussiespeed rocker cover, I have one on my XF ute, 1 deankxf reacted to this Share this post Link to post Share on other sites
jamie247 542 Posted October 19, 2022 On 8/28/2022 at 2:41 PM, FORD_MAN said: Yes use the breather hole to fill with oil on the Aussiespeed rocker cover, I have one on my XF ute, Do u rate them good mate Share this post Link to post Share on other sites
pioneerxf 31 Posted October 21, 2022 Theres a dude on facebook with a stack of chrome cain ones for cheap priceSent from my iPhone using Tapatalk 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
jamie247 542 Posted October 22, 2022 On 10/21/2022 at 1:18 PM, pioneerxf said: Theres a dude on facebook with a stack of chrome cain ones for cheap price Sent from my iPhone using Tapatalk Cheers mate ill run a spacer to clear roller rockers, i bought 2 of them Share this post Link to post Share on other sites
