fotz 20 Posted October 29, 2021 4 minutes ago, deankdx said: i am certain CRS Bell housing for clevo(also windsor) for the 6cyl box exists, i recall it also being drilled or available for single rail/top loader actually., 5second google found it https://www.rodshop.com.au/bellhousing-for-ford-t5-6-cyl-gearboxes-to-windsor @deankdx pretty sure this is the way to go… but… means that the v8 e series box won’t fit behind a windsor in an x series unless you shorten the input shaft and use this same CRS bellhousing. I am getting pretty confident on this now. I’ll find out for sure and let you know. Malwood and CRS will know for sure, but I think we have solved it Interested to see what people did with the clutch pedal. This one got me by surprise. Have not read about this anywhere… Share this post Link to post Share on other sites
deankxf 20,288 Posted October 29, 2021 2 minutes ago, fotz said: Interested to see what people did with the clutch pedal. This one got me by surprise. Have not read about this anywhere… the CRS one is hydraulic, however the 6cyl (for 6cyl 250 etc ) bell housing for T5 they had cast for either cable or hydraulic(fits XA hydraulic to XF cable for eg) they have different pedals/pedal boxes. if that's what's meant. i don't think there's a cable option for the V8 unless they've changed the casting. I haven't kept up with the new owners of CRS, but seeing XD/XE are extinct basically, they may have accommodated for XF/XG by now or have a solution.. especially seeing the barra uses hydraulic i think Share this post Link to post Share on other sites
fotz 20 Posted October 29, 2021 43 minutes ago, deankdx said: the CRS one is hydraulic, however the 6cyl (for 6cyl 250 etc ) bell housing for T5 they had cast for either cable or hydraulic(fits XA hydraulic to XF cable for eg) they have different pedals/pedal boxes. if that's what's meant. Nah CRS is cable not hydraulic. Share this post Link to post Share on other sites
deankxf 20,288 Posted October 29, 2021 2 minutes ago, fotz said: Nah CRS is cable not hydraulic. yeah i'd still ask what they'd do. 1 fotz reacted to this Share this post Link to post Share on other sites
jca25 1,034 Posted October 29, 2021 Is there a reason u want to use clable over hydraulic or have I missed read something Sent from my SM-A125F using Tapatalk Share this post Link to post Share on other sites
fotz 20 Posted October 29, 2021 14 minutes ago, jca25 said: Is there a reason u want to use clable over hydraulic or have I missed read something Sent from my SM-A125F using Tapatalk It’s currently cable now. Not sure there is a proper hydraulic conversion for this setup to be honest either. Share this post Link to post Share on other sites
jca25 1,034 Posted October 29, 2021 It’s currently cable now. Not sure there is a proper hydraulic conversion for this setup to be honest either.Just looked at the fork they say suit it is a hydraulic fork so if are to go down the path of this bell just mod the firewall to take the master Sent from my SM-A125F using Tapatalk Share this post Link to post Share on other sites
deankxf 20,288 Posted October 29, 2021 10 minutes ago, fotz said: It’s currently cable now. Not sure there is a proper hydraulic conversion for this setup to be honest either. if you can find one, the XA to XE hydraulic pedal box is a bolt in. you then need to mount a master to the firewall which is more of a pain in an XF. 1 fotz reacted to this Share this post Link to post Share on other sites
jca25 1,034 Posted October 29, 2021 This is said fork they say to use with that bellhousing, now don't the Cleveland and Windsor use the same engine mounts?? So that would make the Windsor sit in the bay as the Cleveland, the crossflow the engine plates to the x member is different so not sure were u are going with measuring it, if need be may need to make ur own up to suit Sent from my SM-A125F using Tapatalk 1 fotz reacted to this Share this post Link to post Share on other sites
fotz 20 Posted October 29, 2021 I did consider something like this to be honest… was going to speak to malwood to see if something like this could work with the xf https://malwoodauto.com.au/product/ford-falcon-xg-under-dash-hydraulic-clutch-pedal-assembly/ 1 jca25 reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted October 30, 2021 14 hours ago, fotz said: I did consider something like this to be honest… was going to speak to malwood to see if something like this could work with the xf https://malwoodauto.com.au/product/ford-falcon-xg-under-dash-hydraulic-clutch-pedal-assembly/ XG is basically an XF in regards to the dash, so if it has the right bore to suit the clutch slave cyl it should be perfect. Share this post Link to post Share on other sites
BGDAV 1,873 Posted November 4, 2021 would not buy from dellow again, look at quicktime metal ones alot better 2 deankxf and fotz reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted November 4, 2021 would not buy from dellow again, look at quicktime metal ones alot better Yep I've heard things about that mob on more than one occasionSent from my CPH1920 using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
jca25 1,034 Posted November 4, 2021 would not buy from dellow again, look at quicktime metal ones alot better I never had a problem with mine or them it turned up great fitted correctly and they were helpful as ever so must of got them on a good day lolSent from my SM-A125F using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
BGDAV 1,873 Posted November 8, 2021 when i contacted them about mine, they said i installed the spigot wrong (i didnt), then they basically get fucked, it wasnt their business to fix their fuck up that cost me 3k, new gearbox rebuild after 600km, and redrill of a bellhousing due to poor machining - so i just tell everyone - cost them more then 3k in lost sales 1 jca25 reacted to this Share this post Link to post Share on other sites
wok 205 Posted November 15, 2021 On 10/19/2021 at 11:10 PM, ashXFute said: Hi yeah I have a windsor motor in my XF. It's a 92 EB GT motor in a 86 XF s-pack. I can measure some stuff if you need? Sent from my SM-N981B using Tapatalk HI, just wondering what they did for the wiring ? is it using the factory computer/ loom ? im not putting my 5.0l in a X series but something alot earlier, im planning to reuse the complete NL fairlane loom but have heard will need to defeat the smart lock crap ? i see yours is the earlier motor so might be different again ? Thanks Warren Share this post Link to post Share on other sites
ashXFute 498 Posted November 15, 2021 HI, just wondering what they did for the wiring ? is it using the factory computer/ loom ? im not putting my 5.0l in a X series but something alot earlier, im planning to reuse the complete NL fairlane loom but have heard will need to defeat the smart lock crap ? i see yours is the earlier motor so might be different again ? Thanks WarrenHey mate.They used the EB engine harness and ECU and kept the XF dash wiring.No smart lock but they did fit a new alarm demobiliserSent from my SM-N981B using Tapatalk 2 1 motoSycho, fotz and wok reacted to this Share this post Link to post Share on other sites
fotz 20 Posted November 15, 2021 4 minutes ago, ashXFute said: Hey mate. They used the EB engine harness and ECU and kept the XF dash wiring. No smart lock but they did fit a new alarm demobiliser Sent from my SM-N981B using Tapatalk I am getting my harness modified. I retrieved a harness and ECU from the AU XR8. As it has smartlock, I will be using a J3 Chip from TI performance. The rodshop have currently got my harness and are modifying it, and will provide step by step instructions on how to install it to the XF. Below are some links for your reference: https://www.rodshop.com.au/wiring-harness-conversion-for-ford-au-v8-engines (I know they are flat out at the moment). I think they have taken wiring looms down from the shop for the time being. https://www.tiperformance.com.au/products/j3-chips-tuning/ - J3 Chip 1 deankxf reacted to this Share this post Link to post Share on other sites
ashXFute 498 Posted November 15, 2021 Would you like a TI chip?I ended up getting mine tuned with a different chip so I have a un used TI chip just sitting in the center consoleSent from my SM-N981B using Tapatalk 1 fotz reacted to this Share this post Link to post Share on other sites
fotz 20 Posted November 15, 2021 Hey @ashXFute - I sent you a PM. Was wondering what you did for headers? I have GTP40P heads, EB would have GT40 heads. So keen to see what you did there. I got my hands on AU XR8 headers. To be honest, not sure if they are going to fit.... But curious to see what you did, or if you had to customise them? Share this post Link to post Share on other sites
fotz 20 Posted November 15, 2021 1 minute ago, ashXFute said: Would you like a TI chip? I ended up getting mine tuned with a different chip so I have a un used TI chip just sitting in the center console Sent from my SM-N981B using Tapatalk Yes mate for sure. Is it Stage 1? Only problem is, ill need to get programmed as a manual Ill PM you sepereately. Share this post Link to post Share on other sites
fotz 20 Posted November 21, 2021 Hey guys - got myself a world class e series t5 box today - 3.25 1st gear ratio waiting on a response from CRS still. Chased them up yesterday. Any ideas on where’s the best place to track clutch, flywheel and sandwich plate? Was thinking malwood could do the lot - including clutch pedal. Lastly - as I have an ef diff, does anyone know which tailshaft will fit the xf. Are all steel tailshafts from e series the same length - auto/manual also wagon/sedan and Ute -XG/XH? 1 gerg reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted November 21, 2021 5 hours ago, fotz said: Hey guys - got myself a world class e series t5 box today - 3.25 1st gear ratio waiting on a response from CRS still. Chased them up yesterday. Any ideas on where’s the best place to track clutch, flywheel and sandwich plate? Was thinking malwood could do the lot - including clutch pedal. Lastly - as I have an ef diff, does anyone know which tailshaft will fit the xf. Are all steel tailshafts from e series the same length - auto/manual also wagon/sedan and Ute -XG/XH? i can only answer the tail shaft confidently. for the EF diff flange, you'll need an EB to EL FALCON sedan shaft (not fairlane/ltd) auto and manual are the same (some manuals had a big balance weight lump of steel on the gearbox end but it's not seemingly to be a standard thing and definitely not needed) .. so in short EB to EL FALCON Sedan tailshaft ***note for the rest of the tailshafts late XF(1991 ish) ute and XH XH are longer, same length as fairlane, LTD and wagons. so not suitable for sedan (XA- EL) 1 fotz reacted to this Share this post Link to post Share on other sites
fotz 20 Posted November 21, 2021 Thanks @deankdx So stick to eb-el sedan auto or manual! thanks mate 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted November 21, 2021 33 minutes ago, fotz said: Thanks @deankdx So stick to eb-el sedan auto or manual! thanks mate correct Share this post Link to post Share on other sites
