Outback Jack 6,352 Posted March 23, 2021 Hi guys just wondering if anyone knew if the IRS set up out of an AU could be made to work on an XG ute.I'm after IRS as I have a project in mind that runs IRS shafts. Sent from my S21 using Tapatalk Share this post Link to post Share on other sites
jca25 1,034 Posted March 23, 2021 Sounds interesting now Jack, it's not something i have seen or heard of being done myself, but anything can be done with some time and money oh and the will to do it, so can u tell us any more bout this idea now Sent from my SM-G950F using Tapatalk Share this post Link to post Share on other sites
deankxf 20,288 Posted March 23, 2021 i haven't seen any updates on this for YEARS (not even sure the photos are even still there) but it was done on a COUPE(much more room under the gaurds) it wasn't THAT hard to fit, but naturally not a bolt in.. ooh, recent ish updates, and some pics showing.. i haven't come across it being done other than this one.. consensus was it's super heavy, doesn't work well and not needed. https://fordforums.com.au/showthread.php?t=11242449 https://fordforums.com.au/attachment.php?attachmentid=49466&d=1231420958 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted March 23, 2021 Cheers Dean, I'll check it out.I don't need the diff, just the axles and suspension set up with wheel hubs etc.Sent from my S21 using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,874 Posted March 23, 2021 Ford did a watts-link coil spring EA wagon prototype, which I have pic's of. The IRS suspension ages badly IMO - think Ford Territory, but not quite as bad. When they age, they develop very unpredictable handling. Ford has obsoleted the AU IRS suspension bushes. They weren't available aftermarket either, being special void bushes. (may be available now, not sure) In my experience the Ford leaf spring rear's, age 100 times better compared to IRS, and are much more controllable in the event of lost traction - ie, wagons around corners, in wet weather. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted March 23, 2021 Cheers Sparky, I don't particularly want IRS , it just makes the mods I want to do easier.I will keep searching for a solution...Always something.Sent from my S21 using Tapatalk Share this post Link to post Share on other sites
SPArKy_Dave 8,874 Posted March 23, 2021 22 minutes ago, Outback Jack said: Cheers Sparky, I don't particularly want IRS , it just makes the mods I want to do easier. I will keep searching for a solution... Always something. Sent from my S21 using Tapatalk Even the watts-link suspension in XE-AU, handles un-predicably once the bushes wear, although not quite as bad, as the IRS. Replacement bushes are available aftermarket, I believe? Maybe a B-series or FG IRS rear? I think bushes are available those still also. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted March 23, 2021 Even the watts-link suspension in XE-AU, handles un-predicably once the bushes wear, although not quite as bad, as the IRS. Replacement bushes are available aftermarket, I believe? Maybe a B-series or FG IRS rear? I think bushes are available those still also.It's ok Sparky, after a bit of brain crunching I found a way to make it work with a live axle rear.Just needs a bit of engineering but doable. I will reveal all later in the year or early next year....hehehe. I may still need to go IRS but at least I know now to get it from a later model if I do. Thanks for your help. Sent from my S21 using Tapatalk 2 deankxf and SPArKy_Dave reacted to this Share this post Link to post Share on other sites
XCeed 205 Posted March 24, 2021 I believe SuperPro offer a full bushing rebuild kit for the AU IRS. https://www.ebay.com.au/itm/F-R-Superpro-Suspension-Bush-Kit-for-FORD-FALCON-AU-Series-I-II-III-IRS-98-02-/132514895354 Dream BIG Jack, that's what put us on the moon. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
XCeed 205 Posted March 24, 2021 Whoops, or this, just the rear IRS bushes. https://www.ebay.com.au/itm/SUPER-PRO-Full-Rear-Suspension-Bush-Kit-suits-AU-Falcon-Models-with-IRS-SUPERPRO-/333270443238 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Panko 2,480 Posted March 24, 2021 It has been done! I have a photo, buried somewhere deep in my phone or laptop, or an XH panelvan with AU IRS fitted to it. It was surprisingly easy apparently to make the subframe fit. 1 1 deankxf and Outback Jack reacted to this Share this post Link to post Share on other sites
Panko 2,480 Posted March 24, 2021 found it. Can see on the left there the block/chassis mount made to mount the subframe into the car. no idea how they have done the front of the subframe though. 1 1 deankxf and Outback Jack reacted to this Share this post Link to post Share on other sites
2redrovers 21,400 Posted March 24, 2021 Is that the pick up point at the front? It looks like a bolt through the rail to a link for the cradle?I've got a guess for what you're thinking about but maybe I'll just wait and see if I got it right 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Panko 2,480 Posted March 24, 2021 8 minutes ago, 2redrovers said: Is that the pick up point at the front? It looks like a bolt through the rail to a link for the cradle? I've got a guess for what you're thinking about but maybe I'll just wait and see if I got it right yeah you might be right. the pickup is bolted through the rail. 2 2redrovers and Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted March 24, 2021 Cheers Fellas, it's an idea I have but it's a very expensive idea, but requires an IRS to make it work properly.That looks quite doable. Maybe be the cheapest part.I don't need the diff just the shafts,arms, coil overs ,stub axles,hubs/brakes and sub frame.I've been pricing everything else up and it is double what I thought it would cost, just trying to decide if its worth doing when I could buy a fairly new car for the same money.Would be a bitchin project though......Cheers for all your help on the IRS fellas. Sent from my S21 using Tapatalk 2 1 Panko, 2redrovers and deankxf reacted to this Share this post Link to post Share on other sites
Kiwi-E 731 Posted March 27, 2021 Pretty sure the first version of the XDRIFT XD sedan with IRS used an AU IRS setup. From memory there was some good detailed pics of it back over on xfalcon....Sent from my SM-A315G using Tapatalk 2 Outback Jack and 2redrovers reacted to this Share this post Link to post Share on other sites
Jdean 16 Posted July 2, 2021 Hi everyone. I have done this swap into an xf wagon. The front leaf mounting points can be used for the front pickups of the IRS. And all that needs to be made is the rear cradle mount. And the strut mount. The way I did this was very fabrication heavy. I had clearance issues between the strut and the chassis. I'll include a photo to show what I did to make it work. 1 1 deankxf and Thom reacted to this Share this post Link to post Share on other sites
Jdean 16 Posted July 2, 2021 1 1 2 deankxf, bear351c, Thom and 1 other reacted to this Share this post Link to post Share on other sites
Jdean 16 Posted July 2, 2021 3 Thom, bear351c and deankxf reacted to this Share this post Link to post Share on other sites
Jdean 16 Posted July 2, 2021 1 1 deankxf and Thom reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted July 2, 2021 33 minutes ago, Jdean said: that's one of the better first posts i've seen lately is that an XG/XH ute/pano fuel tank fitted Share this post Link to post Share on other sites
Jdean 16 Posted July 2, 2021 I only made an account to share this with you all. I had trouble finding info when I started this project. Yep xg fuel tank. Barra up the front as well as au front subframe, steering rack, etc. Ba steering column. I might post a full build once it's completely finished. 2 deankxf and Outback Jack reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted July 2, 2021 11 minutes ago, Jdean said: Barra up the front as well as au front subframe, steering rack, etc. Ba steering column. I might post a full build once it's completely finished. I'd love to see a build thread on it, there was an XE sedan(done in XF panels) in Tassie that had a full BA subframe graft with the boss 260? (one of the V8s) it was on another forum that is no longer active. that was engineered, but never got to see it finally finished Share this post Link to post Share on other sites
Jdean 16 Posted July 2, 2021 All that's left with mine are coilovers, wheels, tyres, a little bit of panel work and a turbo. Then I might post the whole build. Interesting, I'm in TAS too. It would be good to see that thing and ask about how he went with engineering. Share this post Link to post Share on other sites
