XES 859 Posted May 18, 2013 Look it up bud. You won't find much good at all. Share this post Link to post Share on other sites
slydog 7,873 Posted May 18, 2013 A mate runs ProComp heads on his 10 sec Falcon but I must stress the BARE CASTINGS and nothing else is ProComp. Share this post Link to post Share on other sites
Ants 6,370 Posted May 18, 2013 Procomp is awesome thanos go for it. 3 staids, slydog and xcsam reacted to this Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted June 6, 2013 dude that power level can be made so easily now with off the shelf bits. just order the pieces yourself and give it to a builder. won't even need a solid cam..... or order a pavtek short and throw a top end on, even easier Share this post Link to post Share on other sites
nickd 111 Posted June 6, 2013 Hi Thanos, These eBay adds are like an impulse buy for someone who wants to buy an easy optioned motor. I have done it myself and I would not recommend it to anyone as I bought someone else's (engine build) motor complete with $18k worth of receipts it was too good to be true as it was stated to be a Hydrolic 560HP as It happened to be 500HP solid motor which I ended up parting away as it wasn't a good built engine combo. My recommendation would be to go and see and an engine builder if your after a 450-500HP motor. He will ask you want you want from your engine? Do you want to drag it? Do you want a cruiser? What gearbox and diff gears do you have in your car and what will suit the engine, you have options that you will be able to choose what you want from your combo These are just some of the questions you will be asked from an engine builder as once you start its something you will think long and hard, it not an easy change over as I've just completed my engine build project after the car has been off the road for 6 years. This is from my experience, if you have any questions just ask. Cheers Nickd Share this post Link to post Share on other sites
gerg 10,871 Posted June 6, 2013 Procomp is awesome thanos go for it. My knockoff Bosch dizzy has a "speed hole" in the vac advance diaphragm, only took 500 k's of driving to get this awesome feature working. I didnt buy the dizzy, It already came with the engine... Bonus! Thanks P--C--p! Share this post Link to post Share on other sites
luckyone 0 Posted June 9, 2013 Pro comp I would not recomend .......I personally used there products just for the excercise and nothing measures up.......we used the rotating assembly and heads for a young bloke and nothing but inferior products with no warranty or costomer service ........this was apaid job but people dont take the correct advice.... It all sounds good when you read up such as 408 stroker alloy heads hbeam rods etc and has no name brand . A bit like buying a set of tyres.....brand name or no name . If a standard 351 cost to reco approx 2500 to 3000 dollars thats assembled and has a mark up ofabout 30% how do you build 450 hp for 8000dollars the maths dont add up. Do this qoute parts alone from rocket vpw summit etc ....then qoute up boaring block balancing etc...then you can make a decission.. good luck cheaper isnt always better Share this post Link to post Share on other sites
