Panko 2,480 Posted May 15, 2020 Hi guys, a bit of setback in my crossflow engine build, I will need to replace the retainers and locks. What is the best valve spring tool, so that can do the job with the head still on the engine? TIA Panko Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted May 16, 2020 I copied what I saw on Ford Forums, made a valve spring compressor from a old standard rocker, cut out the contact center where is pushes the valve down, & bent out the sides a bit. then welded a pipe to the side of it could always weld the pipe on so it goes vertically for if in car, which I might end up doing to the other end of the pipe on mine. OR weld a old socket to it & use a breaker bar. Also made a air fitting from a old spark plug, to hook up to the air compressor to pressurize the chamber & keep the valves closed. 2 bear351c and scottly reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted May 16, 2020 @slydog made his own also from memory. Share this post Link to post Share on other sites
Panko 2,480 Posted May 17, 2020 this is what i cam up with... very basic, but i believe it will work. the only thing i still need to do is cut the top side open more so i can actually stick a magnet or screw driver down there to get the locks out, otherwise it seems to work ok. Share this post Link to post Share on other sites
bear351c 10,270 Posted May 17, 2020 These work well, (with air in the cylinder) 3 Panko, macman and Slow250XC reacted to this Share this post Link to post Share on other sites
Panko 2,480 Posted May 17, 2020 Yeah i had a look at them Bear. I dont mind them. I found a video of guy in the US using this kit below, on an old i6 US Ford Fairmont. Blew me away. No idea how it works, but pretty bit of kit. So if i cant get my thing to work, ill look at buying a tool of some sort https://www.kincrome.com.au/valve-keeper-remover-and-install Share this post Link to post Share on other sites
bear351c 10,270 Posted May 17, 2020 Yeah, seen them, looks like you tap down on the retainer, and the magnets draw the collets out. Must be a hole in the side of the tool, somewhere, as you get stubborn keepers sometimes. 1 Slow250XC reacted to this Share this post Link to post Share on other sites
Slow250XC 1,513 Posted May 19, 2020 I have not used compressed air in years for doing stem seals. Length of thin poly rope fed through the sparkplug hole. Wind it up to tdc and your sorted.The wind down style clamp above works well but buy a good one as tough springs can open the fingers.Sent from my SM-J330G using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
