xfish 20 Posted April 11, 2019 Hello people of oz falcon i have purchased a j3 chip over 4 years ago, ( Increased to the au MAF 70mm, while retaining the el xr8 MAF with ss induction) and have not had an issue's ever until recently.........my el xr8 2 has seem to develop a few annoying issues. Symptoms are when i put my foot down, it feels to hesitate before it accelerates, and if i stick to a consistent speed, i can feel it lightly hesitating, and have to accelerate to stop the hesitating. Hesitating in my terminology means, it feels like fuel is being restricted. And when i start the car on a cold morning, it starts up, but then have to push the accelerator to push the idle up before it stabilizers, because if i dont, the car will stall, but then i can fire it back up and she seems normal. I have replaced the fuel pump, fuel filter, air filter, brand new MAF and have a new isc on route to me currently. My fuel consumption has sky rocketed to 35 litres to 175km, where before i would get 400km to 60 litres ( 2 months ago ). I'm not really getting any higher rpm through the gears changes, but fuel consumption is killing me. Any ideas? Share this post Link to post Share on other sites
Thom 6,710 Posted April 11, 2019 you could have a dead fuel pressure regulator, if it's not doing its job you will have excessive amounts of fuel being dumped in and other times it will be too lean Share this post Link to post Share on other sites
xfish 20 Posted April 11, 2019 good point.........one ordered. thanks Share this post Link to post Share on other sites
macman 774 Posted April 11, 2019 Fuel pressure regulator sounds like a logical next item to replace. Keen to hear how you go with it. Also, EL2 XR8 - nice. Share this post Link to post Share on other sites
xfish 20 Posted April 29, 2019 Sorry, I've orded the fuel pressure regulator, and have ordered new injectors since i have to remove the top manifold.........they just havent turned up yet. Another problem has arisen on top or could be part of the same issue...... The 4 speed auto has worked fine and without issue.....and when ( on occasion ) i wanted a quicker start, I'd manually put it back to first and plant the foot. Today, I did this....and the car basically stood still. It eventually got to 50 kmph, though it took 12 seconds ( yes , i timed it ). The normal power between 2nd -4th was there, though there was absolutely no power in first..... a kid on a bike would kicked my ass............ any ideas? Share this post Link to post Share on other sites
deankxf 21,128 Posted April 29, 2019 1 hour ago, xfish said: The 4 speed auto has worked fine and without issue.....and when ( on occasion ) i wanted a quicker start, I'd manually put it back to first and plant the foot. Today, I did this....and the car basically stood still. It eventually got to 50 kmph, though it took 12 seconds ( yes , i timed it ). The normal power between 2nd -4th was there, though there was absolutely no power in first..... a kid on a bike would kicked my ass............ any ideas? @SPArKy_Dave has this issue now ? Share this post Link to post Share on other sites
SPArKy_Dave 9,344 Posted April 29, 2019 1 hour ago, deankdx said: @SPArKy_Dave has this issue now ? negative Share this post Link to post Share on other sites
wok 206 Posted May 3, 2019 Gday, have you checked the Oxy sensors ? or replaced them ? my ELXR8, had the hesitation when foot planted (say doing 80 and you wanted to go to100+), was the MAF changed it over, and its fine now, still unable to resolve the fuel starvation when the tank is low going around corners or you boot it, so I just fill up again at half tank !.. Share this post Link to post Share on other sites
macman 774 Posted May 3, 2019 On 4/29/2019 at 2:14 PM, xfish said: Sorry, I've orded the fuel pressure regulator, and have ordered new injectors since i have to remove the top manifold.........they just havent turned up yet. Another problem has arisen on top or could be part of the same issue...... The 4 speed auto has worked fine and without issue.....and when ( on occasion ) i wanted a quicker start, I'd manually put it back to first and plant the foot. Today, I did this....and the car basically stood still. It eventually got to 50 kmph, though it took 12 seconds ( yes , i timed it ). The normal power between 2nd -4th was there, though there was absolutely no power in first..... a kid on a bike would kicked my ass............ any ideas? Do you think it could have gone into Limp Home Mode (ie locked in 3rd) when you put it in "1" and took off? If manual shift in 1st put it into LHM, but in "D" it shifts 1-4th as normal, could be a faulty inhibitor switch. Just a thought. Share this post Link to post Share on other sites
macman 774 Posted May 17, 2019 How did you go @xfish? Share this post Link to post Share on other sites
xfish 20 Posted May 17, 2019 Hey all, Well, i took the car to another mechanic, and was told the spring in the distributor was broken, and had the wrong sparkplugs, cause there is a big difference between the 170kw vs the 185kw EL XR8. .......they replaced it, and the car has DISCOVERED full power again, and gear changing has returned to normal. Though it still has a miss ( rough idle ) every so often......so, we're going for an exchange ecu, fuel injectors, and fuel regulator in a few weeks, just to freshen things up a bit.. Yes, I'm throwing money at the car,( though it is over 20 years old ) and still is stock from factory, but a few pieces here and there. Hoping this will work.....because the mechanic and son have the same car as myself, and know the EL XR8 185kw backwards......will let you know the outcome after it's next visit. 2 deankxf and macman reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 9,344 Posted May 17, 2019 If your XR8 runs an EGR valve, (some do not) I would suggest to get it ultrasonically cleaned of carbon. Also suss out the O2 sensors. Both those can contribute to misfiring - especially at idle. (vacuum leaks can also cause this) The EFI Windsor dissy's don't have a spring-back centrifugal advance. The only spring in them is on the rotor button, to help contact the center point on the dissy cap. Share this post Link to post Share on other sites
xfish 20 Posted May 17, 2019 yes, thats what broke. The dizzy was still the factory fitted dizzy ( we believe ), with having replaced only a few components in the last few years. And yes, it has the annoying egr setup, and would like to erase it completely .....oxygen sensors have been added to the list. We'll be pulling the top manifold off when we replace the fuel injectors, fuel regulator, so all gaskets can be replaced. So, now we're just waiting for the new ECU to arrive. Also, I have a full top/bottom manifold from a ED sprint / throttle ,fuel rail etc ( i pulled it from a wreck 5 years ago, and has been sitting in my shed all that time ), which i would like mounted in place of the explorer manifold. Though i've searched high and low to see if there is any difference between the 2 manifolds, that putting it on the EL XR8 would/could cause issues. Visually, they look the same. Though i know the AU3 used the explorer manifold which was 220kw, as well the ED sprint was rated the same ( being known as the cheap GT ). Of course as stated before, we will replace all gaskets on the manifold before re-installing....just to assume if there is a leak on the manifold side of things. right now, I'm happy with the improved power on the factory side of things, though I have had a J3 chip ( stage 2 ) installed in the car for years, and that was pulled from the car when we started having issue's, and will be re-installing it after the gremlins have been squashed. thoughts on replacing the top manifold? Share this post Link to post Share on other sites
SPArKy_Dave 9,344 Posted May 18, 2019 15 hours ago, xfish said: thoughts on replacing the top manifold? The upper and lower may need to be done together. I don't think the cobra and explorer type uppers, will match up to the HO Mustang style lowers. Share this post Link to post Share on other sites
xfish 20 Posted May 20, 2019 sorry, that's what i meant. i should of said the top and lower manifold. my bad..... 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
xfish 20 Posted May 20, 2019 How dose someone bypass/remove the EGR set-up from the car? I've seen quite a few car's without it? Share this post Link to post Share on other sites
gerg 10,875 Posted May 20, 2019 sorry, that's what i meant. i should of said the top and lower manifold. my bad.....Unless you're having dramas with it, I would leave it as is. EGRs don't work at full throttle so don't affect power. Apart from reducing NOx, they actually increase part throttle efficiency by reducing vacuum and pumping losses. The computer is tuned with this function in mind so operates on the assumption that the engine is ingesting X amount of EGR at Y amount of throttle. Go blocking it and the computer won't know to compensate, but you'll possibly use more fuel due to increased throttle opening at a given load/rpm.If you don't understand all that jargon, basically don't fuck with it unless it's rooted.Sent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
