CHESTNUTXE 7,312 Posted December 4, 2018 well i would say its the rate of advancing is why,you need to bring more timing in quicker just depending on what dizzy you have,plus std diff gears is gunna be slow as well. Share this post Link to post Share on other sites
Dane1616 9 Posted December 4, 2018 Yer I thought It might need to be advanced I have read that the au 5.0 run a base timing of 30 degrees but wasn’t to sure. I using a proflow (ready to run) dizzy and diff gears are 3.45 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 4, 2018 just give an exaple most people would say around 12 to 15 base timing but mine needs about 19 deg and total of 29 deg,which gives 10 deg advance ,all engines are different ,dont think a au std cam would be that big ,and 3.45 is heaps of gearing for that engine,that 30 deg base would be thru a ecu if correct,the dizzy you have is vac advance ? Share this post Link to post Share on other sites
Dane1616 9 Posted December 4, 2018 Yer that correct the 30deg is efi and yer vac advance dizzy ill bump the dizzy to 18-19 and see how I go thanks for the info 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 4, 2018 total timing is more important ,32,34 deg ,try 18 or so and bring revs up and check with timing light,then lay down a rubber road. Share this post Link to post Share on other sites
Dane1616 9 Posted December 4, 2018 To set total timing with the vac disconnected? And at what sort of rpm? Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted December 4, 2018 To set total timing with the vac disconnected? And at what sort of rpm? About 3000rpm at leastSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
Dane1616 9 Posted December 5, 2018 Hey mate worked out I had the idle timing at 5 deg not 15 so move it to 18 deg and runs like a dream cheers for the help 2 CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted December 5, 2018 Hey mate worked out I had the idle timing at 5 deg not 15 so move it to 18 deg and runs like a dream cheers for the helpMaxwell Smart:"Ahh... The old 10 degrees out trick.... That's the second time I've fallen for that this week"Sent from my CPH1607 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 20, 2019 hey i might just buy that nice au ltd engine ,i no for a fact it has only done 90,000km because i saw the car it came in,a mint LTD with a prang in the left front(probly repairable but too expensive for a insurance to fix,i have pictures of it somewhere here on oz falc,only thing i am concerned about is these gt 40p heads,lets say chuck it in a xf what headers do you need ,there is differance between normal 302 and gt40 heads some spark plug angle differance,maybe there is a trick . Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted September 20, 2019 30 minutes ago, CHESTNUTXE said: hey i might just buy that nice au ltd engine ,i no for a fact it has only done 90,000km because i saw the car it came in,a mint LTD with a prang in the left front(probly repairable but too expensive for a insurance to fix,i have pictures of it somewhere here on oz falc,only thing i am concerned about is these gt 40p heads,lets say chuck it in a xf what headers do you need ,there is differance between normal 302 and gt40 heads some spark plug angle differance,maybe there is a trick . Here's a pic of an engineered Windsor V8 conversion, in an XF - 3 gerg, CHESTNUTXE and FordRufus reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted October 1, 2019 hey i might just buy that nice au ltd engine ,i no for a fact it has only done 90,000km because i saw the car it came in,a mint LTD with a prang in the left front(probly repairable but too expensive for a insurance to fix,i have pictures of it somewhere here on oz falc,only thing i am concerned about is these gt 40p heads,lets say chuck it in a xf what headers do you need ,there is differance between normal 302 and gt40 heads some spark plug angle differance,maybe there is a trick .The P on gt40p heads stands for plug angle, I originally had gt40p heads on my AU spec 5.0 in my XD, dummy fitted hurricane 4-1 headers and with 90 degree (from memory) spark plug boots it all cleared. Sent from my iPhone using Tapatalk 3 bear351c, CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted November 14, 2019 looks like i scored a 5.0L v8 90,000km au 1999 LTD engine,it has been down the wreckers for about a year,i know it doesnt have a dizzy,can this all be converted back too carby spec easy enough ? it has the GT40P heads with the 3 cast lines on them,should be interesting when i grab it in the next few days. Share this post Link to post Share on other sites
NZXD 2,328 Posted November 14, 2019 looks like i scored a 5.0L v8 90,000km au 1999 LTD engine,it has been down the wreckers for about a year,i know it doesnt have a dizzy,can this all be converted back too carby spec easy enough ? it has the GT40P heads with the 3 cast lines on them,should be interesting when i grab it in the next few days.Yes a 302w dizzy drops straight in. From memory the gt40p heads had 4 lines. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted November 14, 2019 looks like i scored a 5.0L v8 90,000km au 1999 LTD engine,it has been down the wreckers for about a year,i know it doesnt have a dizzy,can this all be converted back too carby spec easy enough ? it has the GT40P heads with the 3 cast lines on them,should be interesting when i grab it in the next few days.gt40pSent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted November 14, 2019 yeah 3 or 4 lines,ok so a dizzy is no prob,what about getting rid of the crank trigger thing and buying a 50 oz balancer to suit or does that stuff just unbolt,i was thinking just normal style pulley set up. Share this post Link to post Share on other sites
NZXD 2,328 Posted November 14, 2019 yeah 3 or 4 lines,ok so a dizzy is no prob,what about getting rid of the crank trigger thing and buying a 50 oz balancer to suit or goes that stuff just unbolt,i was thinking just normal style pulley set up. You can get a standard style 50oz balancer easy for them. Sounds like you are doing what I did. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted November 14, 2019 If you go for a standard style pulley set up, you will have to consider the water pump as the efi motors run opposite rotation. What accessories will you run? Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted November 14, 2019 i dont really think it needs rebuilding,i saw the car b4 it came out,even there is a picture on here somewhere of it,usual story grandad let the kid take his mint ltd for a spin and he crashed it into a fence on the front qtr but the rest was mint,im even getting the headers and cats as i told them when taking it out 1 NZXD reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted November 16, 2019 i dont really think it needs rebuilding,i saw the car b4 it came out,even there is a picture on here somewhere of it,usual story grandad let the kid take his mint ltd for a spin and he crashed it into a fence on the front qtr but the rest was mint,im even getting the headers and cats as i told them when taking it out I got the roller 302 engine it has the 3 bars on the head and says P also looks complete with headersSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted November 16, 2019 It has the 4 bars dude. Good score, what did it set you back?Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted November 16, 2019 It has the 4 bars dude. Good score, what did it set you back?Sent from my iPhone using TapatalkWrecker is moving and he said come grab what you want so i loaded the low k engine and 1 saffron xe guard plus a in the box xf guard and going back to see what else i can grab we will work out a cheap price later hehehe started to strip it down has lots of potential Sent from my SM-G570Y using Tapatalk 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted November 16, 2019 Wrecker is moving and he said come grab what you want so i loaded the low k engine and 1 saffron xe guard plus a in the box xf guard and going back to see what else i can grab we will work out a cheap price later hehehe started to strip it down has lots of potential Sent from my SM-G570Y using TapatalkBy late afternoon i had it stripped down and i swear the heads were like new also crosshatch is still on boreSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted November 16, 2019 note how there is no dog bones this one has a drop in plastic thing Share this post Link to post Share on other sites
Thom 6,651 Posted November 16, 2019 why are you pulling it apart? are you planning to make any changes to it? if you want to use a larger cam you need to retrofit the e series dog bones as the plastic lifter guides have a limited amount of space for lifrt 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
