Valvebouncer 2,389 Posted September 3, 2018 A bit late now but yes, you just tap the valve stem seals on. Use a pin punch with no burrs on itand use it to guide it on straight otherwise it won’t seal for long 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 3, 2018 A bit late now but yes, you just tap the valve stem seals on. Use a pin punch with no burrs on itand use it to guide it on straight otherwise it won’t seal for longI painted the balancer and did a mega clean up ready for the o2Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 5, 2018 hey whats the go with the ed sump it has the dipstick coming out the side then up and around the exhaust,as where older windsors have a normal dipstick,does my block have a hole for the older style dipstick ? or do you drill one or just stick with the ed style one ? Share this post Link to post Share on other sites
Thom 6,651 Posted September 5, 2018 Use the dipstick to suit the sump you have, early windsor's had the dipstick in the timing cover 2 bear351c and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 5, 2018 thankgod for thom ,i couldnt find anything about the later sumps,but does that mean i can only use a later timing cover ? Share this post Link to post Share on other sites
Thom 6,651 Posted September 5, 2018 thankgod for thom ,i couldnt find anything about the later sumps,but does that mean i can only use a later timing cover ?You can use an earlier timing cover just plug the dipstick hole Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 6, 2018 My timing chain,1 piece seal and head dowls came just waiting for the block and hot wash bits to be finished then start the painting of the block then assembly of the bottom endYou can use an earlier timing cover just plug the dipstick holeSent from my SM-G570Y using Tapatalk 2 bear351c and deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 6, 2018 The block is ready and im pickin it up at 9.30am all done crank just needed a polish so bearings will be std i cant waitMy timing chain,1 piece seal and head dowls came just waiting for the block and hot wash bits to be finished then start the painting of the block then assembly of the bottom endSent from my SM-G570Y using TapatalkSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 7, 2018 The block is ready and im pickin it up at 9.30am all done crank just needed a polish so bearings will be std i cant waitSent from my SM-G570Y using TapatalkI picked up the block and other bits $580 Sent from my SM-G570Y using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 7, 2018 First few pics after giving another few scrubs and some block numbers for sparky dave to sus outI picked up the block and other bits $580 Sent from my SM-G570Y using TapatalkSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 7, 2018 i painted the block and some nuts,dip stick,ect. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 8, 2018 First snag =the replacement chain dont fit im gunna have to buy a complete new kit i think unless someone knows the size of the one i have i painted the block and some nuts,dip stick,ect.Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
bear351c 10,270 Posted September 8, 2018 Bugger... Is that the original cam gear.?? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 8, 2018 good question bear i thought they had a big single morse type but anything is possible ,might just have to bight the bullet and buy a good rollmaster set or something. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 8, 2018 08 ak i just found stamped on the old double roller and the new one has a 06 part number i will have to look into this good question bear i thought they had a big single morse type but anything is possible ,might just have to bight the bullet and buy a good rollmaster set or something.Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
bear351c 10,270 Posted September 8, 2018 Aaahh...... yep, the 06B2 is the pitch/size of the chain. (3DR58 is the part number) Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted September 8, 2018 It looks like the block was cast, on the 16th July 1991. I think the sumps were painted black on the E-series windsor motor's. F-truck windsors were all grey. Share this post Link to post Share on other sites
bear351c 10,270 Posted September 8, 2018 E3AE-A3A is the roller Windsor cam gear from the Cloyes kit. According to Google. Cloyes was apparently standard fitment from Ford USA. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 8, 2018 Ok cheers for that E3AE-A3A is the roller Windsor cam gear from the Cloyes kit. According to Google. Cloyes was apparently standard fitment from Ford USA.Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted September 8, 2018 just a few questions if i was to fit my single rail behind this engine is there a 50oz 164 tooth flywheel which is 11 inch i think,cause i see many 157 tooth 50 oz models available ? what would be the best route ,i assume using the v8 rail bellhousing.I went down this route, you can get a 164t 50oz flywheel, I got mine from summit racing. they fitted 164t 50oz to broncos and f150 with the roller 302/351w. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 8, 2018 im trying to find where i can get a replacement cloyes chain but im not having much luck. Share this post Link to post Share on other sites
NZXD 2,328 Posted September 8, 2018 Speaking of Windsor’s, I put a 289 into the Territory the day. I’m only going to use the crank and block. Will then have forged rods and pistons to suit about 8.5:1 comp, AFR heads...Sent from my iPhone using Tapatalk 4 Valvebouncer, bear351c, CHESTNUTXE and 1 other reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 8, 2018 awsome put pics up on this thread 1 NZXD reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted September 8, 2018 awsome put pics up on this thread That’s as far as I have got haha. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 9, 2018 Rings are on and part number says holden 4.9 and 5.oL That’s as far as I have got haha. Sent from my iPhone using TapatalkSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
