burnnotice1000 588 Posted April 28, 2022 Yes it's the same sump,I'm stokedSent from my SM-A125F using TapatalkDoing a lot of research on the 429 cj/scj and they are a very rare engine these days ,as prices for these original factory parts are crazy even in the USA,heads are near non existence to buy I guess that's why so many just build a 460 with spruced up 460 heads so I had another look at my 73 heads and turns out they are the last of the decent ones to play with at 91 cc chamber anything after these are 97cc and if you can find early castings they have even smaller 70 odd cc size these are starting to look good my new valves should lob up next week.Sent from my SM-A125F using Tapatalk 2 1 gerg, deankxf and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted April 28, 2022 also i read last night that my sump needs a police/cobra jet oil pump and pick up,as a std one has the wrong angle to fit,there is about 10 million different pumps and pick ups for the big block ,sumps as well. 3 burnnotice1000, gerg and Outback Jack reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted April 29, 2022 also i read last night that my sump needs a police/cobra jet oil pump and pick up,as a std one has the wrong angle to fit,there is about 10 million different pumps and pick ups for the big block ,sumps as well.My new std valve set came and cam bearings and plug set.yep the valves fit but the inserts are borderline and should be ok for a stocker,I will get the machine shop just to have a quick look at them before final assembly like maybe he can put some new guides in there or something Sent from my SM-A125F using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted April 29, 2022 My new std valve set came and cam bearings and plug set.yep the valves fit but the inserts are borderline and should be ok for a stocker,I will get the machine shop just to have a quick look at them before final assembly like maybe he can put some new guides in there or something Sent from my SM-A125F using TapatalkIn that photo of the pedestals, the one on the left doesn't look happy, like the head was dropped and landed on that. Is it still ok?I would do the valve guides, if they're sloppy they'll flog the seats out and also cause oil consumption. For the little extra, it's worth doing right.Sent from my CPH2197 using Tapatalk 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted April 30, 2022 In that photo of the pedestals, the one on the left doesn't look happy, like the head was dropped and landed on that. Is it still ok?I would do the valve guides, if they're sloppy they'll flog the seats out and also cause oil consumption. For the little extra, it's worth doing right.Sent from my CPH2197 using TapatalkHey why does there seem to be a bit more tiny gap on the locks ? Or is that the way single valve locks are ? I'm using std clevo spring and retainer as I thought the 460 uses the same ? For std factory set upSent from my SM-A125F using Tapatalk Share this post Link to post Share on other sites
burnnotice1000 588 Posted April 30, 2022 Hey why does there seem to be a bit more tiny gap on the locks ? Or is that the way single valve locks are ? I'm using std clevo spring and retainer as I thought the 460 uses the same ? For std factory set upSent from my SM-A125F using TapatalkDid a quick check with no spring and no retainer but still the same,they seem to fit up normal to the head just that gap or maybe need a retainer to suit those locks ?Sent from my SM-A125F using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted April 30, 2022 There should be a little gap, on single groove valves. The multi groove don't have the gap so the valve can rotate. 3 gerg, burnnotice1000 and Outback Jack reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted April 30, 2022 There should be a little gap, on single groove valves. The multi groove don't have the gap so the valve can rotate.Ahh ok thanks bearSent from my SM-A125F using Tapatalk Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 4, 2022 Ahh ok thanks bearSent from my SM-A125F using TapatalkI found a cheap new old stock plain 460 sump in Brisbane for $100 and gave it a clean and light coat of ford dark blue,ahh need another can or 2 for block and heads.Sent from my SM-A125F using Tapatalk 3 2 deankxf, CHESTNUTXE, Outback Jack and 2 others reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted May 4, 2022 there is also good news on the heads,olm8 is machining them and cutting the seats to seal better,he did just 1 seat while i was there and the difference was incredible from what they were. 3 1 Outback Jack, deankxf, burnnotice1000 and 1 other reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted May 4, 2022 Did they already have inserts or just factory hardened iron?Sent from my CPH2197 using Tapatalk 2 CHESTNUTXE and burnnotice1000 reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted May 4, 2022 you mean the valve stem or seats ? as it was they are untouched from new he reckons and still ok to use there is very little if any wobble from side to side,but the seats just needed a spruce up,being a 1973 or 74 engine its possible this is a unleaded engine ,i think they started using or introduced it in 1971 ?. 2 Outback Jack and burnnotice1000 reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted May 4, 2022 you mean the valve stem or seats ? as it was they are untouched from new he reckons and still ok to use there is very little if any wobble from side to side,but the seats just needed a spruce up,being a 1973 or 74 engine its possible this is a unleaded engine ,i think they started using or introduced it in 1971 ?.Sorry I meant seats. I was lucky when I got mine done up, someone had done inserts before. Guides needed doing though.Sent from my CPH2197 using Tapatalk 2 burnnotice1000 and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted May 4, 2022 On 4/29/2022 at 3:40 PM, burnnotice1000 said: Looks like cast iron from this shot. 2 burnnotice1000 and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted May 5, 2022 yes i would say you are correct bear,i also havent had the dredded phone call from him saying arrr we need to fully reco these heads cause it aint gunna happen,if im going to go animal on a set of big block heads they will be pro comp or other alloy castings. 2 Outback Jack and burnnotice1000 reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted May 5, 2022 Pro comp... Nooooooooo!Sent from my CPH2197 using Tapatalk 2 Outback Jack and burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 5, 2022 Pro comp... Nooooooooo!Sent from my CPH2197 using TapatalkThey have upped their quality on alloys from recent u tube vids from independent head placesSent from my SM-A125F using Tapatalk Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 5, 2022 They have upped their quality on alloys from recent u tube vids from independent head placesSent from my SM-A125F using TapatalkI got the heads back and they look ok I also gave em 3 coats of ford dark blue and tomorrow if the valve stem seals arrive we can assemble them Sent from my SM-A125F using Tapatalk 3 Outback Jack, gerg and deankxf reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,892 Posted May 5, 2022 460 in the billy cart? 2 burnnotice1000 and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 5, 2022 460 in the billy cart?Actually 472 I forgot to mention after he checked the block it was already 030 over,so it's Gunnar get a 060 bore which these blocks handle fine ,some even bore them to 4.500,but 060 over is 4.420.Sent from my SM-A125F using Tapatalk 3 CHESTNUTXE, Outback Jack and SPArKy_Dave reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted May 5, 2022 I can still see some putting on those seats, I hope your head guy is confident that they'll lap in like thatSent from my CPH2197 using Tapatalk 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 5, 2022 I can still see some putting on those seats, I hope your head guy is confident that they'll lap in like thatSent from my CPH2197 using TapatalkThey are a lot better than what they were,he used a round stone cutting type thing with a 11/32 fitting that slides into head where the valve goes ,or pay $600 to set it up on the valve seat cutting machine arr no thanks this will be fine for a stock engineSent from my SM-A125F using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted May 5, 2022 Maybe you could give them a lap in yourself? Sent from my CPH2197 using Tapatalk 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
deankxf 20,315 Posted May 6, 2022 1 hour ago, gerg said: I can still see some putting on those seats, I hope your head guy is confident that they'll lap in like that Sent from my CPH2197 using Tapatalk i was thinking same, then thought.. how many kms is someone going to do in a 460 these days? be $40 per 100km to drive it probably 2 burnnotice1000 and gerg reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 6, 2022 i was thinking same, then thought.. how many kms is someone going to do in a 460 these days? be $40 per 100km to drive it probablyLooks pretty good to me and he just called to say the block is ready to pick up after hot tank and rust dip and the crank is ready tooSent from my SM-A125F using Tapatalk 2 deankxf and Outback Jack reacted to this Share this post Link to post Share on other sites
