GoofyBuddah 10 Posted June 24, 2018 Hello there (general Kenobi) any one know the measure ments of the radiator mounting pins for an Au falcon.My XG ute has been Frankensteined by previous owner. And cut away the xg radiator mounting points. And welded in what i think is an AU lower bracket. And i dont have the inclination or time or engineering skill to return it to stock.Can anyone help me please Sent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
SPArKy_Dave 8,875 Posted June 25, 2018 The stock XG mounts are still hiding underneath I can see. I'm sure they did it, because proper XG radiators are about $400, and AU ones cost half that. 1 GoofyBuddah reacted to this Share this post Link to post Share on other sites
GoofyBuddah 10 Posted June 25, 2018 The stock XG mounts are still hiding underneath I can see. I'm sure they did it, because proper XG radiators are about $400, and AU ones cost half that.The top mounts have been completely cut out. Which is why i gotta use an AU radiator. I don't know why it was done.Sent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
deankxf 20,288 Posted June 25, 2018 the top XG mounts bolt on/in . got a photo of whats been cut? you'd need to chop an awful lot out to make it gone i'd think 3 351XD_Fairmont, SPArKy_Dave and Outback Jack reacted to this Share this post Link to post Share on other sites
GoofyBuddah 10 Posted June 25, 2018 the top XG mounts bolt on/in . got a photo of whats been cut? you'd need to chop an awful lot out to make it gone i'd think Excuse the dodgy workmanship but i had to make do with what i had at hand.Sent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
deankxf 20,288 Posted June 25, 2018 the top left is missing it's bolt in mount, that side is easy. that's for an XG radiator.. for AU, no idea sorry... i remember test fitting one 15yrs ago approx and it was easier to get a new correct XG one for some reason the top right(drivers side) i'd just make a plate and put a bolt through whats there and another through the radiator 3 Outback Jack, Valvebouncer and GoofyBuddah reacted to this Share this post Link to post Share on other sites
GoofyBuddah 10 Posted June 25, 2018 the top left is missing it's bolt in mount, that side is easy. that's for an XG radiator.. for AU, no idea sorry... i remember test fitting one 15yrs ago approx and it was easier to get a new correct XG one for some reason the top right(drivers side) i'd just make a plate and put a bolt through whats there and another through the radiatorThanks. Yeah i paid through the nose for the xg radiator. I have the top support bolts... are there supposed to be rubber bushes for these?Sent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
GoofyBuddah 10 Posted June 25, 2018 Thanks. Yeah i paid through the nose for the xg radiator. I have the top support bolts... are there supposed to be rubber bushes for these?Sent from my SM-G930F using TapatalkOh and theres no bolts for them iether Sent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
deankxf 20,288 Posted June 25, 2018 there is a rubber grommet that goes in the radiator, just so it has a little give for vibration. then the bolt goes through that into the brackets. there are nut and bolt shops that could give you nuts for those ford bolts easily if you were making your own mounting plate I don't have access to an XG, @SPArKy_Dave @Outback Jack @hendrixhc may be able to take a photo of the top mounts for you maybe.. from experience, i'd say any exhaust shop could make up a suitable mount in about a slab of beer time.... but in Tassie, not sure what's there @Mr Polson might be able to give some guidance depending where you are. if it was here, i'd have it mounted using push bike parts i found on hard rubbish with a bit of fuel hose for a grommet.. but then, for $50 odd you could probably buy the parts missing from a wrecker and have an exhaust shop weld in a patch for the drivers side hacked out section(exhuast shops are more likely to do small jobs compared to a panel shop for eg) 2 Outback Jack and GoofyBuddah reacted to this Share this post Link to post Share on other sites
hendrixhc 10,920 Posted June 25, 2018 sorry im out. My XG is on a holiday and i just checked and have no photos of that area. 1 deankxf reacted to this Share this post Link to post Share on other sites
GoofyBuddah 10 Posted June 25, 2018 there is a rubber grommet that goes in the radiator, just so it has a little give for vibration. then the bolt goes through that into the brackets. there are nut and bolt shops that could give you nuts for those ford bolts easily if you were making your own mounting plate I don't have access to an XG, [mention=27]SPArKy_Dave[/mention] [mention=1138]Outback Jack[/mention] [mention=34]hendrixhc[/mention] may be able to take a photo of the top mounts for you maybe.. from experience, i'd say any exhaust shop could make up a suitable mount in about a slab of beer time.... but in Tassie, not sure what's there [mention=21]Mr Polson[/mention] might be able to give some guidance depending where you are. if it was here, i'd have it mounted using push bike parts i found on hard rubbish with a bit of fuel hose for a grommet.. but then, for $50 odd you could probably buy the parts missing from a wrecker and have an exhaust shop weld in a patch for the drivers side hacked out section(exhuast shops are more likely to do small jobs compared to a panel shop for eg)Cheers for the assist. Hunting around now for what i need. I'll i pester the local mechanic to see if he's got some spare bolts.Sent from my SM-G930F using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted June 26, 2018 Here, this may help.Mine also had the wrong radiator and hoses when I bought it too so ignore those but it does show the brackets and placement. 2 GoofyBuddah and deankxf reacted to this Share this post Link to post Share on other sites
GoofyBuddah 10 Posted June 26, 2018 Here, this may help.Mine also had the wrong radiator and hoses when I bought it too so ignore those but it does show the brackets and placement.Sweet cheers mate. That helps a bundle. Now i know what they look like. Could i trouble ya for the dimensions. So i can get the bracket made up pleaseSent from my SM-G930F using Tapatalk 2 Outback Jack and Valvebouncer reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted June 26, 2018 I’ll have a dig around, I may have a spare step. Otherwise I’ll measure up the ones on my ute 1 Outback Jack reacted to this Share this post Link to post Share on other sites
GoofyBuddah 10 Posted June 26, 2018 I’ll have a dig around, I may have a spare step. Otherwise I’ll measure up the ones on my uteCheers bud. Itll be a great helpSent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted July 2, 2018 Sorry for the late reply, I couldn’t find your thread for a while!Passenger sideDrivers sideHonestly though, I’d keep the au radiator if it fits. Mine had some weird bogandore radiator that didn’t have the right side inlet and outlets. 1 GoofyBuddah reacted to this Share this post Link to post Share on other sites
GoofyBuddah 10 Posted July 3, 2018 Sorry for the late reply, I couldn’t find your thread for a while!Passenger sideDrivers sideHonestly though, I’d keep the au radiator if it fits. Mine had some weird bogandore radiator that didn’t have the right side inlet and outlets.Thanks bud it helps loads. The au radiator was wiped out by roo. And without checking got one for xg. So ill have the plates.built in the next few weeks.Sent from my SM-G930F using Tapatalk 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted July 3, 2018 Thanks bud it helps loads. The au radiator was wiped out by roo. And without checking got one for xg. So ill have the plates.built in the next few weeks.Sent from my SM-G930F using TapatalkNo worries. I searched everywhere, I couldn’t find the spare brackets I had. Share this post Link to post Share on other sites
