SPArKy_Dave 8,890 Posted December 14, 2017 4 hours ago, deankdx said: with 2.77 diff and auto it took off like a rocket.. would have been fine with a taller diff ratio. made 99.8RWKW on LPG, at 4000rpm.. would pull to 4500 but didn't have much up there. ideal tow engine if you wanted a 6, used as much lpg as a 351 though.. (but went as good as a good stock one..) What torque did it make? It's all in the torque... Are you feeling the x-series crossflow love enough yet, to get another one? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,890 Posted December 14, 2017 Triple weber Crossflow FTW! 2 CHESTNUTXE and Ando81 reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted December 14, 2017 Has anyone seen those tripple webber copies for a grand on the internet exact copy Share this post Link to post Share on other sites
SPArKy_Dave 8,890 Posted December 14, 2017 Pretty nice sound, for a Crossflow here - 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted December 14, 2017 Imagine the kid put into drive while running Share this post Link to post Share on other sites
slydog 7,873 Posted December 14, 2017 5 hours ago, Valvebouncer said: I’m waiting for them to bring out a digital tyre lever gauge It’s amazing what you can learn from the old blokes if you just shut your mouth and listen. A mate of mine is mad for minis, the real ones. They only have 3 mains caps compared to newer 4 cylinders with 5 therefore they are susceptible to crankshaft whip and cracking. The old school trick is to have a bigger clearance thrust bearing on the bottom compared to the top. I guess they know, considering they spin them to 10,500 rpm and they stay together! Craig Smith builds all his race engines this way. His engines have actually won Bathurst a few times so may know what he's on about. 2 Valvebouncer and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted December 14, 2017 Xflow with webbers... 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,890 Posted December 14, 2017 Running 10's, on a crossflow, built 15yrs ago! Eat that, turbo Barra's. Share this post Link to post Share on other sites
LJDB 103 Posted December 14, 2017 i ran a vf marloo the other day in my basic turbo xflow corty and left him for dead both times. At the next set of lights he ask's whats in it? i reply just a turbo 6 and he looked at me stupidly waiting for me to say barra. Then said yeah but what. I said just an XF motor. Ha Ha the look on his face was priceless 3 SPArKy_Dave, Valvebouncer and stockesp reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted December 14, 2017 Craig Smith builds all his race engines this way. His engines have actually won Bathurst a few times so may know what he's on about. I assume you mean the different thrust bearing clearances, not the tyre lever thing? 1 slydog reacted to this Share this post Link to post Share on other sites
deankxf 20,313 Posted December 14, 2017 1 hour ago, SPArKy_Dave said: What torque did it make? It's all in the torque... Are you feeling the x-series crossflow love enough yet, to get another one? made MORE torque than the lexus V8 until 2000rpm.. then.. less to 4000, then a lot less to 6200 i had wondered if i could buy the crossflow back and then find something to put it in.. like an XR ute.. would be cheaper than a lexus conversion that i'd prefer... the lexus V8 is the perfect engine for a falcon if you ask me(if the budget was $10k).. light as the xflow.. sounds better.. similar fuel economy 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted December 15, 2017 made MORE torque than the lexus V8 until 2000rpm.. then.. less to 4000, then a lot less to 6200 i had wondered if i could buy the crossflow back and then find something to put it in.. like an XR ute.. would be cheaper than a lexus conversion that i'd prefer... the lexus V8 is the perfect engine for a falcon if you ask me(if the budget was $10k).. light as the xflow.. sounds better.. similar fuel economy I bought the kero and will leave stuff in it to soak i also cleaned and painted the sump and balancer and other stuffSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted December 17, 2017 I bought the kero and will leave stuff in it to soak i also cleaned and painted the sump and balancer and other stuffSent from my SM-G570Y using TapatalkI painted some brackets and bolts and also noticed not much gunk in piston ring slots?Sent from my SM-G570Y using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted December 17, 2017 hopefully today bearings will come so i can start the bottom end,i also orderd a new endurotech factory chain as the other one was like a rubber band. Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted December 18, 2017 hopefully today bearings will come so i can start the bottom end,i also orderd a new endurotech factory chain as the other one was like a rubber band.A bit more done ,i painted every nut and breacketSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted December 18, 2017 A bit more done ,i painted every nut and breacketSent from my SM-G570Y using TapatalkHey is there an adaptor for this manifold to suit a 350 holley ? Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted December 19, 2017 Hey is there an adaptor for this manifold to suit a 350 holley ? Sent from my SM-G570Y using TapatalkThe timing chain cameSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
deankxf 20,313 Posted December 19, 2017 i'm fairly sure there is a holley adapter for it(there is.. but a manifold to suit would be better? and probably cheaper?) https://www.ebay.com.au/itm/ADM-XF-XE-WEBER-STUD-PATTERN-CARBURETTOR-TO-HOLLEY-350-2BBL-CARBY-ADAPTOR-PLATE-/161802394047 there are some on gumtree.. this one might be same upside down? https://www.gumtree.com.au/s-ad/toowoomba/engine-engine-parts-transmission/34-adm-webbers-and-adapter-plate/1164621838 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted December 19, 2017 yup ,when i sold the webber i gave the guy the spacer under the webber i now need it,does anyone have a spare one off a xe or xf please as my studs are very long without it and im sure this kc adaptor and others are made as a bolt on item to the spacer. Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted December 19, 2017 i cleaned and painted the exhaust manifold.just need to block that pipe off. Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted December 20, 2017 yup ,when i sold the webber i gave the guy the spacer under the webber i now need it,does anyone have a spare one off a xe or xf please as my studs are very long without it and im sure this kc adaptor and others are made as a bolt on item to the spacer.I was wondering why you wanted a Holley. There is a really good thread somewhere on this forum on how to get the Weber carb to flow better and what the biggest restrictions were. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted December 20, 2017 i just always wanted that little 350 with a small or std cam,plan is with this engine is too just have a back up engine for the ute and/or if i sell it down the track i can put the matching numbers block back in it,as the holley will line up with the current throttle and air cleaner set up i hope. 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted December 20, 2017 i just always wanted that little 350 with a small or std cam,plan is with this engine is too just have a back up engine for the ute and/or if i sell it down the track i can put the matching numbers block back in it,as the holley will line up with the current throttle and air cleaner set up i hope.I dropped the crank down to the machine shop to get linished i just couldnt place it on new bearings without a tidy up cost me $50 Sent from my SM-G570Y using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted December 22, 2017 I dropped the crank down to the machine shop to get linished i just couldnt place it on new bearings without a tidy up cost me $50 Sent from my SM-G570Y using TapatalkCrank looks good ,he also lent me the hone to clean up the bores im just waiting for bearings to come then start the reassembly Sent from my SM-G570Y using Tapatalk 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted December 25, 2017 its not too late to put a very mild cam in it,as i have a little crissmas spending money left,the stock cam is low 400 lift,i was thinking a stage 1 efi cam which is a tad bigger or 477 lift ,precision do a cheap hyd for $203 ,or tow cam ? just something better than std. Share this post Link to post Share on other sites
