CHESTNUTXE 7,311 Posted December 13, 2017 according to the compression calcuator if i put the 20cc pistons in it ,it would be about 9.6.1,thats with 47cc chamber but i must measure the chamber as some are saying 42cc and others 48cc so i will sus it out. 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted December 13, 2017 (edited) the good old.. I'll just re ring it.. rebuilt.. next minute $4000.. that's what mine ended up like Edited December 13, 2017 by deankdx added pics 2 slydog and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted December 13, 2017 I spent double that on the other crossy and still spending Share this post Link to post Share on other sites
deankxf 20,288 Posted December 13, 2017 20 minutes ago, CHESTNUTXE said: I spent double that on the other crossy and still spending it should be faster than a prius now though... 2 CHESTNUTXE and Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted December 13, 2017 Just the carby ,rocker cover and manifold and air cleaner was 2k Share this post Link to post Share on other sites
deankxf 20,288 Posted December 13, 2017 2 minutes ago, CHESTNUTXE said: Just the carby ,rocker cover and manifold and air cleaner was 2k i should have gone EFI.. mine was Gas research. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,873 Posted December 13, 2017 1 hour ago, deankdx said: i should have gone EFI.. mine was Gas research. LPG loves boost apparently... just needed a Turbo. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted December 13, 2017 Should i order 001 or std bearings ? Share this post Link to post Share on other sites
deankxf 20,288 Posted December 13, 2017 35 minutes ago, SPArKy_Dave said: LPG loves boost apparently... just needed a Turbo. it used to ping on gas and not premium.. was over 11:1 comp needed E85 before it was in servos... needed a bigger cam, would have offset the static comp ratio Share this post Link to post Share on other sites
SPArKy_Dave 8,873 Posted December 13, 2017 43 minutes ago, CHESTNUTXE said: Should i order 001 or std bearings ? Did you PlastiGauge the bearing clearance on the mains and big end bearings? Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted December 13, 2017 No ? I chuckd the bearings out already Share this post Link to post Share on other sites
Thom 6,651 Posted December 13, 2017 Rule no 1 never throw any part out until you have the replacement and know it fits 6 CHESTNUTXE, stockesp, SPArKy_Dave and 3 others reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,873 Posted December 13, 2017 2 hours ago, CHESTNUTXE said: No ? I chuckd the bearings out already I really hope that's a joke, LOL! If not, then you've just created a whole lot more work for yourself... You need to Plastigauge the bearing clearances, as a bare minimum. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted December 13, 2017 You need to measure the crank for size,buy bearings to suit then fit and measure then fit crank and measure. Or you could measure crank and buy bearings to suit and just deal with it co I know 95% of people building engines would do this. I'm not one of em. Most don't check end float just pull the crank forward and back and thats it LOL. 2 Valvebouncer and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted December 13, 2017 14 hours ago, deankdx said: the good old.. I'll just re ring it.. rebuilt.. next minute $4000.. that's what mine ended up like Is that a C2 Dean? Wow don't see em like that anymore LOL. I just had to purchase a C1A (with real money too!!!) and these things are starting to get hard to find. But the out come will be a very happy xflow for me Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted December 13, 2017 they are still in the bin i can fish them out, 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted December 13, 2017 1 hour ago, slydog said: Is that a C2 Dean? Wow don't see em like that anymore LOL. I just had to purchase a C1A (with real money too!!!) and these things are starting to get hard to find. But the out come will be a very happy xflow for me It was a cnc machined map of a C2 I think from the C1 also had cnc pocket porting . I can't remember anything about it other than the cam was was too small for revs but it had torque for days from idle to 4000 Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted December 13, 2017 what is it about that c2a head ? are they rare Share this post Link to post Share on other sites
SPArKy_Dave 8,873 Posted December 14, 2017 4 hours ago, deankdx said: It was a cnc machined map of a C2 I think from the C1 also had cnc pocket porting . I can't remember anything about it other than the cam was was too small for revs but it had torque for days from idle to 4000 What Cam did you have in it? Sounds like you need another crossflow as a daily! Share this post Link to post Share on other sites
deankxf 20,288 Posted December 14, 2017 2 minutes ago, SPArKy_Dave said: What Cam did you have in it? Sounds like you need another crossflow as a daily! gas research voodoo cam.. (probably an EFI spec.. with higher lift?) 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted December 14, 2017 gas research voodoo cam.. (probably an EFI spec.. with higher lift?)Block got a good clean and now painted also cam is in Sent from my SM-G570Y using Tapatalk 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,873 Posted December 14, 2017 1 hour ago, deankdx said: gas research voodoo cam.. (probably an EFI spec.. with higher lift?) And was it good? Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted December 14, 2017 You need to measure the crank for size,buy bearings to suit then fit and measure then fit crank and measure. Or you could measure crank and buy bearings to suit and just deal with it co I know 95% of people building engines would do this. I'm not one of em. Most don't check end float just pull the crank forward and back and thats it LOL. I’m waiting for them to bring out a digital tyre lever gauge It’s amazing what you can learn from the old blokes if you just shut your mouth and listen.A mate of mine is mad for minis, the real ones. They only have 3 mains caps compared to newer 4 cylinders with 5 therefore they are susceptible to crankshaft whip and cracking. The old school trick is to have a bigger clearance thrust bearing on the bottom compared to the top. I guess they know, considering they spin them to 10,500 rpm and they stay together! 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted December 14, 2017 I havent even bought the kero yet ,main bearings seem very expensive for a crossy compared to a windsor best i have found is $100 Share this post Link to post Share on other sites
deankxf 20,288 Posted December 14, 2017 1 hour ago, SPArKy_Dave said: And was it good? with 2.77 diff and auto it took off like a rocket.. would have been fine with a taller diff ratio. made 99.8RWKW on LPG, at 4000rpm.. would pull to 4500 but didn't have much up there. ideal tow engine if you wanted a 6, used as much lpg as a 351 though.. (but went as good as a good stock one..) 1 scottly reacted to this Share this post Link to post Share on other sites
