ando76 4,354 Posted May 30, 2017 So your going to rev your crossflow harder than this? That's 6200 plus. 5/16 bolt on roller rockers, no guide plates!!!! get the valve springs right and you don't need any of that fancy arse bullshit. That engine did 5 years of speedway before being flogged in the skid car for another 3. Never once did it pull a thread on a 5/16 bolt on. 3 Valvebouncer, Slow250XC and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted May 30, 2017 nice sound to that engine,i just had these roller rockers i bought some time ago and want to use them up,they are new,ok well maybe a bit more than 6000rpm,will see .i have to buy a cam soon ,ive got my eye on a tighe solid 240 @50thou , Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted May 31, 2017 he has done some port work looks good Share this post Link to post Share on other sites
351XD_Fairmont 604 Posted May 31, 2017 Has he welded up some coolant passages in that photo? What's the reasoning behind this, not needed or better flow like this? Share this post Link to post Share on other sites
broken-wheel 659 Posted May 31, 2017 those middle ones get close to the edge when they corrode which they do Share this post Link to post Share on other sites
broken-wheel 659 Posted May 31, 2017 don't be scared to go bigger valve as those valves have quite a thick stem see below with 1.9" Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted May 31, 2017 i think he said he is gunna take 0.025 off the exhaust to 1.575 Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted June 1, 2017 old m8 has {radiused } the seats or what ever this means i no its as smooth as all hell,took 5 hours to turn all the valaves down and when i asked what size did we end up with in the intakes he told me to go fk myself and laughed. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted June 1, 2017 the tool as used on the old DJR mill Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted June 1, 2017 nice curve on it Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted June 1, 2017 some of clark's alloy products Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted June 3, 2017 i was going thru one of wagoons box's he gave me and i found gold check these chunky trend pushrods ,only thing is will they be the correct ones ? Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted June 3, 2017 another 6 trend but these are 080 wall still beefy Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted June 3, 2017 getting a good collection of alloy products Share this post Link to post Share on other sites
broken-wheel 659 Posted June 3, 2017 those lifters are crap specially for a solid lifter but if you're gong to flip it then don't drive it more than 5k Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted June 3, 2017 what lifters,i havent bought any yet Share this post Link to post Share on other sites
broken-wheel 659 Posted June 3, 2017 seen the shity brand on that box and though they were lifters, carry on Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted June 4, 2017 what dizzy is the go with crossy's ,not much on the market,i was gunna get my xe dizzy re bushed and use new dizzy gear to suit cam,also a blaster 2 coil,and get the dizzy tricked up to suit the cam.or just buy a cheap e bay one ? Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted June 4, 2017 Nason fuck me had no end of dramas with those fucking things in 4.0's theyre a lifter with a built in tick from new 2 Bigflop and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted June 4, 2017 so what brand should i get Share this post Link to post Share on other sites
broken-wheel 659 Posted June 4, 2017 everything nason make is utter rubbish the XE locked dizzy is a good place to start i guess, find an old one and re-bush it, most don't even need it Share this post Link to post Share on other sites
CHESTNUTXE 7,354 Posted June 4, 2017 ok im not sure what you mean but is like total advance locked in at all times ? Share this post Link to post Share on other sites
broken-wheel 659 Posted June 4, 2017 yeah it's locked, if it's a manual it won't matter, if auto with a good stall same same, if you're rally after a good ignition then get the MSD programable and don't look back Share this post Link to post Share on other sites
