deankxf 20,316 Posted March 30, 2020 i am envious of the last random drive/thrash.. i still haven't got My gemini fixed.. and now although a good time to be fixing it, won't be able to go further than the local shops pretty much.. although, i might be able to go for a "Job interview" somewhere possibly or something.. take a pet with you and go to the "VET" perhaps Share this post Link to post Share on other sites
Panko 2,482 Posted March 30, 2020 3 minutes ago, deankdx said: i am envious of the last random drive/thrash.. i still haven't got My gemini fixed.. and now although a good time to be fixing it, won't be able to go further than the local shops pretty much.. although, i might be able to go for a "Job interview" somewhere possibly or something.. take a pet with you and go to the "VET" perhaps TBH, its not going to stop me from going for little drives here and there as i test things out. Im not going to lie. but yeah whilst we are in lockdown, ill be smashing out as much work on my cars as i can, within the restraints of my bank account of course I will be trying to smash out this wiring and heater box fix up as fast as i can, so i can go onto finishing the buggy thats been in bits for yonks. 1 deankxf reacted to this Share this post Link to post Share on other sites
Panko 2,482 Posted March 31, 2020 what have i gotten myself into? haha wait its not so bad.... Parcel shelf out. This is getting a little more complex Kick panel off, ok now its getting serious interestingly the colour behind the kick panel is actually darker, much like another factory green that is darker... it still amazes me how clean this is. no matter where i look, no rust. ok now you've done it Panko. the passenger seat has been removed, and there is wires everywhere. So much for a simple rewire of the radio *facepalm* Enter snowball affect Ok Ok ill explain. I realised that there was some dodgy wiring going on with the radio. then there was my rushed wiring when i installed the sub and amp, and the tacho. The resolve? TO REPLACE IT ALLLLLLL!!!! The tacho feed wire - too short to run it properly, and to its potential new location Amplifier constant power supply - too short to run it properly Signal cable from radio to sub amp - too short for radio to go into its new location Speaker wires - no joins from radio harness to speakers in the doors - cut and put plugs in line I cant wait to have this finished and all tidied up. I have an oil pressure gauge and volts gauge here. they are Veglia Bortelli brand. turns out they are from a Jaguar XJ6. But i do not have a pressure sender unit, but know the part number for the jaguar sender unit, that this gauge would have been installed in. SO, i wonder if an XJ6 sender would fit the escort block? They are both british, and 70s cars. 1 winton reacted to this Share this post Link to post Share on other sites
Panko 2,482 Posted March 31, 2020 these are the gauges 2 bear351c and deankxf reacted to this Share this post Link to post Share on other sites
hendrixhc 10,921 Posted March 31, 2020 That wiring is about 1/2 as untidy as my XCs. I have some sort of fault in there that when i put the indicators on the ignition system cuts out with each flash of the blinker. Something i have to fix still. 1 1 bear351c and Panko reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,892 Posted March 31, 2020 I like the bit about there being no rust... that's the best part. Share this post Link to post Share on other sites
bear351c 10,273 Posted March 31, 2020 Oil sender from a Jag, worth more than an Esky..?? Share this post Link to post Share on other sites
Panko 2,482 Posted March 31, 2020 25 minutes ago, bear351c said: Oil sender from a Jag, worth more than an Esky..?? not terribly expensive actually. less than $100. i was surprised to see these gauges selling in NOS form for about $100. i would have thought they'd be worth more than that Share this post Link to post Share on other sites
deankxf 20,316 Posted March 31, 2020 25 minutes ago, Panko said: not terribly expensive actually. less than $100. i was surprised to see these gauges selling in NOS form for about $100. i would have thought they'd be worth more than that if you can get the resistance RANGE for it in spec, you should be able to look up a NARVA equiv with the right thread for the escort, i had to do similar for the oddball engine swaps over the years (would be more like $25 if so) Share this post Link to post Share on other sites
Panko 2,482 Posted April 1, 2020 5 hours ago, deankdx said: if you can get the resistance RANGE for it in spec, you should be able to look up a NARVA equiv with the right thread for the escort, i had to do similar for the oddball engine swaps over the years (would be more like $25 if so) Yeah i agree. problem is i have tried and tried to find that info on google with no luck Share this post Link to post Share on other sites
deankxf 20,316 Posted April 1, 2020 4 hours ago, Panko said: Yeah i agree. problem is i have tried and tried to find that info on google with no luck a job for @SPArKy_Dave and @Mr Polson Share this post Link to post Share on other sites
Mr Polson 10,214 Posted April 1, 2020 if you can get the resistance RANGE for it in spec, you should be able to look up a NARVA equiv with the right thread for the escort, i had to do similar for the oddball engine swaps over the years (would be more like $25 if so) a job for [mention=27]SPArKy_Dave[/mention] and [mention=21]Mr Polson[/mention]VDO, Fuelmiser or Speco maybe, but I've never seen a Narva oil pressure sender. Share this post Link to post Share on other sites
Panko 2,482 Posted April 1, 2020 19 minutes ago, Mr Polson said: VDO, Fuelmiser or Speco maybe, but I've never seen a Narva oil pressure sender. So while you're at work, can you see if you have a part number cross reference for an Oil pressure sender for a Series 3 Jaguar XJ6? Cheers Share this post Link to post Share on other sites
Panko 2,482 Posted April 1, 2020 More (slow) progress today. I had to (nervously) drill a new hole into the firewall to run some 8 gauge wire, and a lighter signal cable for the tacho feed. there was a factory pressing directly below the main wiring harness, so it was perfect to drill out. then i found this grommet in the garage, and figured that would neaten it up, but it did also meaning making that hole a 17mm hole to get the grommet in almost looks factory made the new amplifier constant power supply cable. yes its + but i used black cable to make a little more discrete. and run it through my new hole. I also fed the new (black) tacho signal cable through as well. then this happened trying to remove the nut to remove the spade and put a double spade on there for tacho signal, and the thread snapped clean off. new coil ordered. play the waiting game until next week got the centre panel in to test fit, and see how it would look. took a little big of minor trimming here and there but im happy with it. working out where the radio will go Share this post Link to post Share on other sites
Panko 2,482 Posted April 1, 2020 thinking about the gauges today, as well as not having the oil pressure sender unit, i also realised im missing the mounting brackets. So i started thinking ill just replace them with new ones, complete with everything i need. Should I just bite the bullet, and splurge on a set of VDO cockpit gauges? Volts, Oil pressure, water temp. If i got this path, I will be swapping the volts and oil pressure gauges with the ones in the XF because they ones in the XF are a little more period correct (i think) to the 70s, than the new cockpit range are. these are the new VDO Cockpit gauges https://www.ebay.com.au/itm/VDO-COCKPIT-VISION-12v-GAUGE-SENDER-KIT-OIL-100psi-WATER-TEMP-VOLT-350010021/323420623620?epid=12028920503&hash=item4b4d5f1304:g:Q-cAAOSwXB1bf20k photo purely for reference. But you can see in this, my XF VDO Volts and Oil Pressure have the coloured warnings. I think they would suit the Escort more maybe? and the plain black gauges suit the wagon a bit more? Share this post Link to post Share on other sites
deankxf 20,316 Posted April 1, 2020 10 minutes ago, Panko said: I also fed the new (black) tacho signal cable through as well. looks like you could pick up the power wire from that starter relay? would make it much more neat/discreet at the battery post end if that's what you wanted. as for the gauges, they are dear, but if you can justify it.. i actually prefer the plain black faces. Share this post Link to post Share on other sites
Panko 2,482 Posted April 1, 2020 5 minutes ago, deankdx said: looks like you could pick up the power wire from that starter relay? would make it much more neat/discreet at the battery post end if that's what you wanted. as for the gauges, they are dear, but if you can justify it.. i actually prefer the plain black faces. good point i hadnt thought of that. But, i think im happy to go straight from the battery than off a 45 year old starter cable. They are dear yes. I was looking at cheap chinese gauges. less than $100 for a set of 3, but its that whole, "do it once, do it right" thing. 1 bear351c reacted to this Share this post Link to post Share on other sites
deankxf 20,316 Posted April 1, 2020 Just now, Panko said: was looking at cheap chinese gauges. less than $100 for a set of 3, but its that whole, "do it once, do it right" thing. the cheap chinese ones are garbage, not accurate at all i think.. i got them for My gemini just to fill holes. I'd like more VDO ones, but not paying the premium Share this post Link to post Share on other sites
Panko 2,482 Posted April 1, 2020 there you go. I hadnt seen or heard any reviews. but i trust you. the first negative comment about them ill take. the vdos are proven and trusted Share this post Link to post Share on other sites
Mr Polson 10,214 Posted April 2, 2020 So while you're at work, can you see if you have a part number cross reference for an Oil pressure sender for a Series 3 Jaguar XJ6? Cheers 4.0L six or 5.3L V12 or 6.0L V12? 1 Panko reacted to this Share this post Link to post Share on other sites
2redrovers 21,402 Posted April 2, 2020 S3 xj6 would mean only the six cylinder variations, so the 4.0L? Yes? Otherwise it would be xj12 Share this post Link to post Share on other sites
Panko 2,482 Posted April 2, 2020 Finally feels like I am making some headway with this little project haha I spent today working on the centre panel. getting the radio mounted etc. home made aluminium mounting tabs next was working out the mounting. I decided it would be nice to able to remove the cradle at any point without having to remove the entire dash to get to nuts on the back side of it. So, i went with rivet nuts again. mounted. now due to some odd shapes of the aftermarket dash and the cradle not matching those odd shapes, i did have to space the back 2 tabs upwards to make it work. this is the plan with the gauges and switch layout... Heater fan switch, gauge, gauge (centre of car), gauge, switch. Tacho next to radio Rivet nuts for the tacho Im starting to like this layout...a lot the hope is tomorrow ill have the dash panel in tomorrow, and so i can finalise the wiring lengths, and finish off the wiring. The i will be able to start putting the interior back together again. I think ive convinced myself to just buy the VDO gauge set and be done with it, which means when they arrive, another round of wiring to do Share this post Link to post Share on other sites
SPArKy_Dave 8,892 Posted April 2, 2020 4 hours ago, 2redrovers said: S3 xj6 would mean only the six cylinder variations, so the 4.0L? Yes? Otherwise it would be xj12 I once helped my uncle convert an S1 XJ12, to Chev V8. So to be fair on Polson... you never know. Share this post Link to post Share on other sites
SPArKy_Dave 8,892 Posted April 2, 2020 Can you still get Smiths gauges?... they'd go nicely with the whole British/ XJ6 theme, etc? Share this post Link to post Share on other sites
