udidca302 2 Posted June 18, 2016 I saw on here ages ago in part of someone's build up a section on repairing rust in the fire wall. I have searched for it and am unable to find the thread. Has anyone done this with photos or better yet know of the thread I am looking for? Share this post Link to post Share on other sites
FOMOCOHO 882 Posted June 18, 2016 I know the one you're thinking of... where the top panel gets cut off completely right? SXE did some repairs on the "reaper" ... http://www.ozfalcon.com.au/index.php?/topic/5030-xe-the-reaper/page-2 Share this post Link to post Share on other sites
hendrixhc 10,921 Posted June 18, 2016 Recon XM221 has done that repair in one of his projects to. Share this post Link to post Share on other sites
dvfalcon 352 Posted June 19, 2016 I did plenum repairs to my xe. Thought I had a little repair on lhs only . Once that was repaired discovered it was worse on the RHS. To repar Rhs I removed halp the top. If I was doing another car any small rust in this area I would remove the the whole top, big job but peace of mind. Dale 3 gerg, stockesp and bear351c reacted to this Share this post Link to post Share on other sites
udidca302 2 Posted June 19, 2016 How do you go about removing the top part Share this post Link to post Share on other sites
bear351c 10,273 Posted June 19, 2016 Spotweld drillbit. Windscreen out. Checkout 1969-70 Mustang cowl removal on U-tube. Cupla vids on there. 1 2redrovers reacted to this Share this post Link to post Share on other sites
2redrovers 21,404 Posted June 19, 2016 When you drill out the welds, take it slow and easy, only go through the layer you are removing and keep the drill speed down. You want it to spin fast enough to see it cut the chips of steel away but slow enough that it doesn't overheat the bit. Will last longer as they are a pain to sharpen without the right grinding tool. When you clean it up to go back in, spray the overlapping edges with either zinc primer or epoxy. Line up the panel, then clean the spot where you need to weld for good conductivity. I usually weld with the wire feed a little lower than normal to get a slightly hotter weld with a bit less build up to clean. 2 gerg and blu xe reacted to this Share this post Link to post Share on other sites
dvfalcon 352 Posted June 19, 2016 Udidca302 As bear and 2redovers said, I cut out and replaced wher I could, carefully welded up the pin holes this is a very complex area a lot of valleys and different shapes. I I ground and sanded back, coated in POR15 but could also use KBS and welded back together. I swear by Por15 and KBS rust paints and after using bit here used it on the rest of reapirs, in cabin and boot. If you have a look at the second photo you can see the shiney round circles. They are were the spot welds were. Very time consuming job and and if a decent car wasn't so hard to find this car would have been binned. Would I do it again. Yes! In fact if I was putting any money into another I would pull the top off coat it and it will last for ever Dale 4 Crustydog, bear351c, blu xe and 1 other reacted to this Share this post Link to post Share on other sites
udidca302 2 Posted November 6, 2016 Well I have started the repairs. Hopefully it will not be a hard job. I will be taking my time on this one because I only want to do it once and do it right first time around 1 2redrovers reacted to this Share this post Link to post Share on other sites
