djjase 10 Posted November 23, 2015 Hi all Thinking of going a 460 BB stroked to 554 in the coupe, so looking at brakes. Was thinking of going the Wilwood upgrade like a 4 or 6 spot front and 4 spot rears for the 9" diff. Has anyone done this upgrade? is it a straight replacement or need a bit of modifications to get them on? These for the back: http://www.ebay.com.au/itm/WILWOOD-DYNALITE-4-SPOT-REAR-BRAKE-KIT-FORD-9in-DRILLED-BLACK-WB-140-7140-D-/161751350233?hash=item25a921bbd9:m:mWYpYTVqyg2sUNt2dYTN1yg These for the front (4 spots): http://www.ebay.com.au/itm/FORD-XY-BRAKE-KIT-FRONT-4-SPOT-DRILLED-SLOTED-XR-XD-WILWOOD-140-101072-D-DB-/321772142658?hash=item4aeb1d4042:m:mYQKeSlqb5WbX9VXBwre7Gg Share this post Link to post Share on other sites
Thom 6,654 Posted November 23, 2015 Be careful what set of wilwoods you get as many of them don't pass adr's due to having no dust boot 1 Outback Jack reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted November 23, 2015 Yeah agree with Thom, I don't know of a wilwood setup that is ADR compliant. So any brake upgrade using bigger discs is probably just as good. Keep in mind people doing circuit racing use a standard good condition girlock caliper with a grooved disc and good brake fluid is enough that they don't see brake fade. If this setup is good enough to pull up a clevo powered x series on the track it would be plenty for other application 3 NZXD, SirkWhyXF and Outback Jack reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted November 25, 2015 So, is there an aftermarket/different rotor that bolts to an X series, which is larger diameter, and possibly grooved/slotted?? Any FPV/XR8 gear bolt on, HSV stuff, or do we have to look at Hoppers, or Wilwood? Just for info..... Share this post Link to post Share on other sites
JETFTR 508 Posted November 25, 2015 CRS were advertising wilwoods that were adr compliant when i was at motorex a 2 years ago. They may have only been the dynalite series.I know of wilwoods that are on xseries cars. There is a kit that does fit.i have them on my xe but umm, unless you want to run a hq stubaxle and buy 67-69 camaro kit i kinda cant help lol. I have your top link on the rear of mine. Both front and rear on my car dont have the dust boots. 1 bear351c reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted November 25, 2015 Rebuilt girlock caliper with QFM pads and DBA T2 rotors. 3 bear351c, Outback Jack and Mr Polson reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted November 25, 2015 I have the same as you wagoon but with Bendix pads, stops my ute great. 2 wagoon and Outback Jack reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted November 25, 2015 I have the same as you wagoon but with Bendix pads, stops my ute great. I haven't got there yet as my sedan is still a work in progress. But this will be the setup of my solid roller crossy powered track car. If it's good enough for sikxe351 and his clevo powered sedan that sees the track alot it will be fine for just about if not everybody here. Share this post Link to post Share on other sites
SirkWhyXF 1,533 Posted November 26, 2015 Rebuilt girlock caliper with QFM pads and DBA T2 rotors. When you say rebuilt girllock calipers, do you mean the stock calipers?Btw how much are those t2 rotors and Qfm pads, and where do you get em? Share this post Link to post Share on other sites
wagoon 2,429 Posted November 26, 2015 Yep standard rebuild of standard calipers. Those T2 rotors can be had from a few places, just shop around for a good price. As for the QFM pads these guys sell them http://www.brakesdirect.com.au/Qfm They have an ebay store as well as through their website. They also sell the T2 rotor and superpro bushes as well. 1 SirkWhyXF reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted November 26, 2015 Those T2 rotors are good. Run em on my xg ute. Rebuilt stock calipers and bendix pads. I dont like the pads too much so maybe try those QFMs. Bendix advance are what I run.. find the bite a bit lacking. Jack. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted November 26, 2015 When you say rebuilt girllock calipers, do you mean the stock calipers? Btw how much are those t2 rotors and Qfm pads, and where do you get em? For my mechanic to rebuild my calipers, buy and fit the rotors, new pads and new front wheel bearings was around $450/$500, so the rotors can't be too expensive. If I find my original bill it will list how much the rotors were. 1 SirkWhyXF reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted November 27, 2015 QFM pads offer bite when cold unlike pads like EBC green stuff and red stuff pads but are of the same level of performance as the EBC ones. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
SirkWhyXF 1,533 Posted November 27, 2015 A brake upgrade for the xf is inevitable, this combo looks like a good prospect. Share this post Link to post Share on other sites
