scottly 475 Posted October 16, 2015 Hey guys, this is one for the panel beaters and spray painters. I have just bought a air speed file and I am wondering when I oil it and use it will spit oil out on my panel I'm working into shape is there a particular oil to use? It is un-used at the moment I'm waiting to get the right size paper but I'm keen to give it a test run. Share this post Link to post Share on other sites
ando76 4,354 Posted October 16, 2015 any oil you put into the tool will exit through the exhaust of the tool and should not cause and issue on the job 1 scottly reacted to this Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted October 16, 2015 Yeah I have one of them works well the sanding dust also sticks to the oil on the exhaust and sokes some up, just oil a little at a time if you try and give it a glug of oil it will squirt it out the exhaust. Just uses air tool oil. Best way is to get a inline oiler just fill it up set the rate. 2 PRO250 and scottly reacted to this Share this post Link to post Share on other sites
PRO250 1,506 Posted October 16, 2015 what garth saidI hate oiling air tools I use on body work but what do you do 1 scottly reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted October 17, 2015 Just stay away from silicone and use prepsolv before adding filler/paint/ect 1 scottly reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted October 17, 2015 A thicker oil like Viscotene or chain lube might hang in there before being blown through. Vegetable oil might dissolve better when you prepsol it later. Any lube is better than none, and I've never seen an air tool damaged from the "wrong" lube being used. 1 scottly reacted to this Share this post Link to post Share on other sites
blu xe 825 Posted October 17, 2015 Proper air tool oil is the go and only a drop any more gets blown out the exhaust. I've had cheap shit air tools last for years being pretty slack with keeping them oiled. So my way of thinking is they can't need to much at all. 1 scottly reacted to this Share this post Link to post Share on other sites
judgetread 758 Posted October 17, 2015 as blue xe says, the smallest amount is all that is need. It shouldnt even really come out the exhaust if you use the right amount. But saying that we flog the crap outta alot of panel based air tools and they maybe get oiled once a year :S 1 scottly reacted to this Share this post Link to post Share on other sites
scottly 475 Posted October 19, 2015 Thanks for the replys fellas, it didn't make sense to me oiling a tool to use on panel work when primer,paint and filler is down on the panel considering your not ment to touch it with clean bare hands. from now on I might do one drop of oil run the air tool for 1 minuet full song away from the panels im working I might even hold a price of paper near the exhaust and see how much oil comes out. I'm surprised there isnt oil catching filters or a better system 1 judgetread reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted October 20, 2015 Wax and grease remover and tack cloth should be the last step before paint anyway Share this post Link to post Share on other sites
