Dane1616
Xh ute bad fuel economy
Recommended Posts
Hey
I've recently brought a xh ute 4.0l auto I'm getting 260-280km to 50liters of fuel.
So far I changed coolant, thermostat, temp sensor, O2 sensor, injectors, fuel filter and plugs and leads.
There has been no change in the fuel economy
If anyone can help would be great.
Cheers Dane
Share this post
Link to post
Share on other sites
Yer just going off the odo it reads accurate. Ive have tested for codes though the obd plug with test light only code is a running rich. I will try getting a tps switch tomorrow.
Thanks mate
Share this post
Link to post
Yer I was running cold all the time when I got it found the thermostat was stuck open I then changed the thermostat and flushed engine and put coolant it. Temp runs about half on the gauge since i changed thermostat and coolant.
Share this post
Link to post
Hey
What about the IAT sensor?
Also, I would be picky about what O2 sensor I used.
NTK is supposed to be the most accurate for the OHC falcons.
Some of the others have been known to have poor tolerances out of the box.
I would also suss out the Fuel Pressure Reg.
Share this post
Link to post
It will be that thermostat, now its fixed try do a new fuel economy test.
If the ute is not at full operating temp when your doing your fault code test that will be your 'rich at idle'.
Do you do a throttle goose before you test anything?
Also run your code reader 3 times just to check codes re occur the same.
My ute gets about 14L/100km real world economy. About 700km to 100L.
Bridge out test pin and earth under dash on left of test plug and check your base timing is at 10 degrees..... just to be sure...
Jack.
Share this post
Link to post
Yer done all that just changed IAT sensor and TPS. I'm currently doing a fuel economy test I have checked timing and triple checked codes and logs the running rich code.
Cheers
Share this post
Link to post
Jack.
XG's are 10degrees BTDC,
but I know EL's (and possibly XH's) are 0degrees BTDC base timing.
Share this post
Link to post
Worth a check. Sorry if Im wrong Dave.
I always though xh was same as xg as was same obd system.
If everything checks out may want to look for clutch slippage or brake/wheel bearing drag.
I will say though... if you like driving with a heavy right foot the fuel economy of these motors goes downhill fast. Lol.
I should get 1000km from my duel tanks...126L ....
Never even been close.
Jack.
Share this post
Link to post
Definitely worth checking.
If it's auto, also check the transmission engine braking is working properly.
The C4 clutch can sometimes drag in the transmisson - causing slight issues/slugishness etc.
The main effect, is loss of engine braking when going down hills and such.
Share this post
Link to post
Hey yer I fill up at same servo every time.
Dave there is no sign of transmission engine brake and is real sluggish taking off is there a way to check / test?
it also slips or drops out of gear between 3rd and 4th I have to back off the throttle or it just revs and goes no where.
Cheers
Share this post
Link to post
How hot does it run, if it's not warming up properly it will be stuck in cold start mode and run rich all the time
What temp should these engines run at? My ed has a set thermo switch in it (tridon one) and runs on the colder side of the guage..
and uses shitloads of fuel lol
AFAIK everything else is all good. i havnt scanned it for codes though
Share this post
Link to post
Hey mate it runs on the lower side as well around the "m" and "a" on the "normal" writing.
Is the different temp sensors.
I will let you all know how I go.
Cheers
Share this post
Link to post
Ideally you want it running right around 90 degrees
Share this post
Link to post
Got to be a little careful when going off guage position for actual temp.
That is the sender and the actual reading of the temp for the computer is from the coolant temperature sensor. (The big one).
Sometimes it could be wrong sender installed for guage.
Mine runs in the normal box just above the lowest line of the box..... but has been tested in workshop and by me on code reader and ute checks out A OK.
Also a tip..... NO thread seal tape on sender or CTS. Just use sealant.
Can be a bit tricky to pin down but worth doing.
Jack.
Share this post
Link to post
Yer temp is fine tested with second test temp gauge and still no change in fuel economy.
The Ute might be up for sale soon as it's costing me to much to get to work and can't find the problem.
Cheers
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
