Raymond Daley 4 Posted July 20, 2015 Ok just just wanted to ask if anyone knows this cam maker.. on the back of the cam its stamped.. CM250*S and also has WRC.. any thoughts.. Share this post Link to post Share on other sites
ando76 4,354 Posted July 20, 2015 Wade perhaps (wade racing cam - WRC). Nah - I've got nothing. You can send it to one of the many cam manufactures and they can run it up on their 'cam doctor' and tell you exactly what the specs are. Share this post Link to post Share on other sites
Raymond Daley 4 Posted July 20, 2015 well after using my diel gauges I have the cam at lift Ex 501' lift In 496 Duration @50 Ex 226 Duration @50 In 249 and Lobe sep 114.. I can't see that being right tho.. Share this post Link to post Share on other sites
PRO250 1,506 Posted July 20, 2015 its a dynotech cam cm250 I thort was a 214 214@50 495liftI have a few in the shed ill take a look tomorrow at the spec sheet and part number 4 Raymond Daley, wagoon, steve mcqueen and 1 other reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted July 20, 2015 Well I had a nice witty reply all typed out then Pro comes a long and makes it all irrelevant. Oh well better that you have the correct info from someone that knows stuff than some comment from a halfwit that knows fuckall. 4 dougie77, ando76, steve mcqueen and 1 other reacted to this Share this post Link to post Share on other sites
Banno 479 Posted July 20, 2015 214/214 is CM251. Don't know what CM250 specs are but is a standard camshaft replacement Share this post Link to post Share on other sites
Raymond Daley 4 Posted July 20, 2015 its a dynotech cam cm250 I thort was a 214 214@50 495lift I have a few in the shed ill take a look tomorrow at the spec sheet and part number so would the S at the end mean a solid cam? Share this post Link to post Share on other sites
PRO250 1,506 Posted July 20, 2015 zero idea mate and banno may be right I think I have a list in the shed for the dynotechs ill see tomorrow Share this post Link to post Share on other sites
gerg 10,871 Posted July 20, 2015 For the same duration at 0.050", solid will have a longer ramp-up than a hydraulic, so the advertised will be much longer. The specs you measured don't make any sense. A split-pattern cam always has a longer/bigger exhaust. Share this post Link to post Share on other sites
slydog 7,873 Posted July 20, 2015 Ring Surecam for a cam that suits your needs. 1 Raymond Daley reacted to this Share this post Link to post Share on other sites
Raymond Daley 4 Posted July 21, 2015 I think I will just get a sure cam.. I have had his cams before and they are great.. Share this post Link to post Share on other sites
Raymond Daley 4 Posted July 24, 2015 ok so after look at it and thinking about i redone the cam.. and this is what i got. lift Ex 574 lift In 498 Duration @50 Ex 280 In 280 cam centerline Ex 250 after TDC or 70 before TDC In 105 after TDC or 75 before BDC but I can't work out the Lobe sep.. can anyone help with that? Share this post Link to post Share on other sites
Raymond Daley 4 Posted July 24, 2015 Oh and just to let everyone know that the cam numbers stamped on the back " CM250S " stands for " CM250 " is to suit a 250 xflow and the " S " stands for a unfinished cam so its just a blank cam that other cam makers buy like wade cams or sure cams or cam tech.. Share this post Link to post Share on other sites
Raymond Daley 4 Posted July 24, 2015 sorry had a brain fart.. its 107.5 lobe sep.. Share this post Link to post Share on other sites
gerg 10,871 Posted July 24, 2015 Yeah that sounds right it's in cam degrees, not crank. but the 280 duration at 0.050 sounds way too big. Most performance street cams having that much lift have around 280 advertised and around 215 at 0.050. Share this post Link to post Share on other sites
Raymond Daley 4 Posted July 24, 2015 it was made for a speedway car.. Share this post Link to post Share on other sites
