Banno
Ford eb tailshaft flange bolt
Recommended Posts
Does anyone know the bolt size for the tailshaft flange to diff is. Putting an e-series diff into the xe and thought replace bolts with new ones
Sent from my iPhone using Tapatalk
Share this post
Link to post
Share on other sites
Sorry flat flange and also add that I dont have the bolts for the the flange. Otherwise I would take one into the bolt shop to measure.
Share this post
Link to post
THanks Gerg,
All I know is that its a 15mm nut and 18mm bolt. Pitch wise or size I am not sure.
But I will found out and post it so this dosent become a dead end thread with no answer to it.
Add to the ozfalcon library of answers.
Just need some time, as flat out with work.
Share this post
Link to post
I think you'll find that you'll have to go factory with those bolts as you want a snug fit on the shank to take up the slack. You don't want any rotational movement there. These bolts handle full tailshaft torque unlike the little 1/4" ones on the yoke type which just hold the straps in place.
Share this post
Link to post
Well I got hold of 2nd hand set that were rather good nick considering some I seen that were looking rather rusted. Ford eb ed are getting rather thin on the ground these days for decent parts. Ford ef el au are common.
Anyway I find out at what they are at a bolt shop in geelong they have been rather good for things like this that are at correct specs as factory. I will be using the factory set though. Got them now.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
