Banno 479 Posted May 11, 2015 Does anyone know the bolt size for the tailshaft flange to diff is. Putting an e-series diff into the xe and thought replace bolts with new ones Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted May 12, 2015 What E-series is it? Flat flange or yoke type? Share this post Link to post Share on other sites
Banno 479 Posted May 12, 2015 Sorry flat flange and also add that I dont have the bolts for the the flange. Otherwise I would take one into the bolt shop to measure. Share this post Link to post Share on other sites
gerg 10,871 Posted May 12, 2015 Sorry can't be sure about that one but maybe M10 x 1.5... Anyone? Share this post Link to post Share on other sites
Banno 479 Posted May 12, 2015 THanks Gerg, All I know is that its a 15mm nut and 18mm bolt. Pitch wise or size I am not sure. But I will found out and post it so this dosent become a dead end thread with no answer to it. Add to the ozfalcon library of answers. Just need some time, as flat out with work. 1 Lord_fahrquhar reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted May 12, 2015 I think you'll find that you'll have to go factory with those bolts as you want a snug fit on the shank to take up the slack. You don't want any rotational movement there. These bolts handle full tailshaft torque unlike the little 1/4" ones on the yoke type which just hold the straps in place. Share this post Link to post Share on other sites
slydog 7,873 Posted May 12, 2015 TBH I'd be very happy with the factory piece. I use STOCK ED bolts in my ute and they don't come loose let alone break. 2 Thom and NZXD reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted May 12, 2015 I went to ford when I wanted some, but they didn't stock them at all. Got some second hand. Share this post Link to post Share on other sites
Banno 479 Posted May 12, 2015 Well I got hold of 2nd hand set that were rather good nick considering some I seen that were looking rather rusted. Ford eb ed are getting rather thin on the ground these days for decent parts. Ford ef el au are common. Anyway I find out at what they are at a bolt shop in geelong they have been rather good for things like this that are at correct specs as factory. I will be using the factory set though. Got them now. 1 ricktewagon reacted to this Share this post Link to post Share on other sites
