wagoon 2,429 Posted March 30, 2015 I wasnt worried about the walls being sucked in more the vibration created by the engine which would move the walls thus creating turbulance inside the box. But as you said Ando if you strengthen the wall it wont flex. Sly I did remember you notched the tower but though the trumpets still sat fairly close. As for heat soak I dont think there is much you can do about that but the trumpets would probably get just as hot now as the box would get. Share this post Link to post Share on other sites
slydog 7,873 Posted March 30, 2015 Well the carbs are cold to touch atm when running thanks to a spacer from Jase and AvGas running cooler then petrol. Share this post Link to post Share on other sites
hendrixhc 10,922 Posted March 30, 2015 So is the theory behind the airbox so you can get cool air from the front of the car? Excuse my ignorance but what is its exact purpose? Share this post Link to post Share on other sites
wagoon 2,429 Posted March 30, 2015 Well if the trumpets and carbies are cool to touch you would think it would have to keep the box cool as well. henderixhc my understanding is the box should will feed the same temp air into each runner, as well as a more stable airflow due to the air no long rushing past the ports. 1 hendrixhc reacted to this Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted March 31, 2015 What about zoomies? Right through the hood. Same with exhaust. Look like its a fuckin v12! Kidding. Share this post Link to post Share on other sites
broken-wheel 659 Posted May 29, 2015 keep this in mind, when designing the air box 2 matt_lamb_160 and Thom reacted to this Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted May 29, 2015 If you're looking to pressurise the airbag... Better than using an ls1 on a leaf blower to pressurise the airbox. 1 wagoon reacted to this Share this post Link to post Share on other sites
broken-wheel 659 Posted May 29, 2015 is that the HX40? i reckon one of these would work nice on a xflow and they're nice and cheap with gate edit: wait never seen that Holset before, what is it? weird outlet Share this post Link to post Share on other sites
gerg 10,871 Posted May 29, 2015 Probably for a truck application Share this post Link to post Share on other sites
broken-wheel 659 Posted May 29, 2015 nah the HX40 is perfect for the crossflow or any 3L - 4L engine, don't forget the crossflow don't rev much so the thing will flow to 500HP and those things are bulletproof, I got an EB manifold coming and will be playing with one later in the year Share this post Link to post Share on other sites
