Mr Polson 10,214 Posted December 19, 2014 So in my attempts to get my wagon running I've discovered that I'm not getting power to the fuel injectors. I have fuel pressure, but after removing the rail and having someone else crank the motor, no fuel was being injected by any of the injectors. Anywhere specific I should look? All the plugs in the engine bay are connected. Share this post Link to post Share on other sites
Thom 6,655 Posted December 19, 2014 Did you check if your getting a pulse signal from the distributor? Have you earthed the injectors? Share this post Link to post Share on other sites
Mr Polson 10,214 Posted December 19, 2014 How do I check if getting pulse from dizzy? What do you mean by earthing the injectors? Don't they just earth via the wiring? I'm a noob when it comes to the EFI side of the motor, I understand the mechanics and the basics but that's about all :/ Share this post Link to post Share on other sites
Mr Polson 10,214 Posted December 19, 2014 When I rotate the dizzy without cranking I hear what sounds like the fuel pumps priming more... Share this post Link to post Share on other sites
Thom 6,655 Posted December 19, 2014 Should be a little earth wire in amongst the injector wiring near the back of the head, usually bolts to an intake bolt from memory Share this post Link to post Share on other sites
Mr Polson 10,214 Posted December 19, 2014 I'll have to double check when I get home after work but I don't remember seeing an earth wire... Share this post Link to post Share on other sites
Mr Polson 10,214 Posted December 19, 2014 Checked the injector loom and there's no earth on it, just three wires and it's a three wire plug. Checked the wiring diagram and definitely no earth. Runs via the EFI engine relay though, maybe that's faulty, or there's a break in the wires somewhere between that and the injectors? Share this post Link to post Share on other sites
Crazy2287 1,886 Posted December 19, 2014 3 wires, 2 are switch earths for bank 1 and 2 and one should be 12v live when ign is on (From memory... could be wrong :S ) Pull your fuel return line off from the fuel regulator and run it into a container, then turn ign on, when the pump primes you should develop pressure. prim again and fuel should bypass into the container. If it does not then check you fuel lines, In tank and external, and your fuel pump. Disconnect one of your injectors and put a multimeter across the contacts. Turn the ign on and you should see the voltage on the multimeter fluctuate during the priming pulse. If it does no then it might not be switching and you might have an electrical issue. 1 Thom reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted December 19, 2014 I have pressure at the injectors, the fuel is getting there no problem at all. Will check the priming pulse tomorrow and see what I get. Share this post Link to post Share on other sites
Outback Jack 6,352 Posted December 19, 2014 Might be ya fuel pump relay Polson, other wise bank 1 goes to PIN 58 on the ECU and bank 2 goes to PIN 59 on the ECU, but they both trigger from the Fuel pump relay. Fuel pump relay resistance should be around 60 ohm. Injectors individual 16.2 ohm Bank 1 or 2 tested as a bank 5.4 ohm(3 injectors in Parallel) Also check K.O.E.O voltage should be 12V for injectors thats measured at Pin 58 and Pin 59, Vpower relay is pin 57. Can only be a relay, wiring harness or ECU. Jack. 1 Crazy2287 reacted to this Share this post Link to post Share on other sites
SLO247 1,713 Posted December 19, 2014 No injector pulse from the sounds. Try another TFI module or complete dizzy. Could possibly be ecu or damaged wiring too. Considering it all ran OK in the other car I'd try another tfi or dizzy. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted December 20, 2014 Stupid fucking bloody LPG and LPG wiring!!! Found the problem after closely looking at the loom off the injector plug, followed a few wires and found two that ran off and just ended. Joined them together and used a test light on the injector plugs, had 12V, so cranked the motor and she started!! 4 Thom, XES, Outback Jack and 1 other reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted December 20, 2014 Well fuck my horse Share this post Link to post Share on other sites
