mltezr 2 Posted December 7, 2014 I currently have an el xr6 manual and recently purchased an xd 3.3L to use as a daily. however the xd is the 3 speed auto. So I am thinking of putting the t5 from the xr6 into the xd. My question is what would I need? I have read that I might need the bellhousing from an xf, however apparently the xf are the same up to the eb, and since the gearbox im looking at putting in is from an el xr6, does anyone know what I would need? Cheers. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted December 7, 2014 Bellhousing for T5 behind a crossflow are unique and were only found behind XFs. You'll need a XF T5 bellhousing, XF T5 gearbox crossmember and a late XF clutch cable. 2 mltezr and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted December 7, 2014 You need to modify the XD gear box cross member for the T5 to bolt in. The XF gear box cross member dont fit, they are to short. Ive got pics some where of it but cant find them right now. Think of an EA gear box cross member with XD cross member ends welded to it and presto. You need a pedal box of cause and the small clutch cable support that bolts to the firewall, yours being an auto has a blanking plate over the hole. Clutch and a cable and you should be right. Oh yeah and as polson says you need a bell housing off a XF T5. And a new flywheel, and bolts. 2 mltezr and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
deankxf 20,346 Posted December 7, 2014 i'd be surprised if a 3.3 could pull 5th gear on a T5 even at 100kmh with 2.92 diff gears it probably has.T5 has a 0.72 ratio 5th, the 3.3 XE 5 speed (rubbish one same as a sigma used) had a 0.85 ratio 5th. 2 XTREME KARTS XF and mltezr reacted to this Share this post Link to post Share on other sites
mltezr 2 Posted December 8, 2014 Sweet. I was thinking of even puting the diff from the el xr6 in. If the 3.3 still won't be able to pull 5th gear, I was thinking of puting the 4.1 from an Xe I have. So basically the 4.1 from an Xe, a t5 gearbox and the diff from an el xr6. Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted December 8, 2014 The XR6 diff would need big mods to fit your XD, would be to costly. Perhaps as its a daily, just keep the auto and the car the way it is. Share this post Link to post Share on other sites
blackxt 699 Posted December 8, 2014 May as well just put the whole xr6 motor in it and carby it. Share this post Link to post Share on other sites
wagoon 2,429 Posted December 9, 2014 I have a factory 3.3 4spd xe wagon and I cant understand why everyone says they have no power. Granted I wouldnt say it has heaps of power but mine is completely standard and it holds it own. There is a slight possiblity that my car has had a small camshaft upgrade as I bought it off a guy who bought it off a guy but the cam would be no bigger than a towing cam. And the fact that I have standard exhaust manifold and drinking straw size exhaust it would kill any benefit of the cam. A standard 4.1 wont set any speed records either but will have a little more poke than the 3.3 I would say if you just want to have a cheap runner then stick with the 3.3 and if you want put the 5 speed in as the auto would be killing the power and adding to fuel usage. The parts required has been covered above. Unless the diff is from a ute or wagon you cant use it in your xd as all E series sedans are coil spring and your xd is leaf spring like the utes and wagons. But if you want the lsd and gears go and buy a complete open centre e series diff for $50 from a ute or wagon and swap the lsd and gears over 1 steve mcqueen reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted December 9, 2014 Yeah everyone goes on about red motor 202s in Toranas, etc and they're not even the best red motor. I reckon 186s are nicer. I drove a 2M-powered Crown for a while which was a 2.3 litre six. Even when it was clapped out and running on 4-1/2 cylinders with Toyoglide auto behind it, it still managed to reach 80 mph. Cubes help to make horses but only up to a point. You start going backwards as stroke gets longer So 3.3 litres of crossy goodness is nothing to sneeze at and I'd love to see what someone can squeeze out of an NA one screaming to 7 grand with a bunch of triples strapped to it 1 wagoon reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted December 9, 2014 Yeah everyone goes on about red motor 202s in Toranas, etc and they're not even the best red motor. I reckon 186s are nicer. I drove a 2M-powered Crown for a while which was a 2.3 litre six. Even when it was clapped out and running on 4-1/2 cylinders with Toyoglide auto behind it, it still managed to reach 80 mph. Cubes help to make horses but only up to a point. You start going backwards as stroke gets longer So 3.3 litres of crossy goodness is nothing to sneeze at and I'd love to see what someone can squeeze out of an NA one screaming to 7 grand with a bunch of triples strapped to it Sounds like your up for a challenge Gerg. 1 gerg reacted to this Share this post Link to post Share on other sites
78xcgxl 241 Posted December 18, 2014 3.3s are dangerously slow haha, i could never bring my self to drive one on a daily basis. If i was you i would try to buy a cheap XF with a 4.1 and T5 and transplant all the running gear into your XD. XF cross flows are much nicer and better on fuel with the weber carby. Share this post Link to post Share on other sites
