ricktewagon 39 Posted October 14, 2014 As the title suggests, my Turbo 250 Crossy has suddenly developed the symptoms of no Power and a quiet but hard intermittent Clicking/ banging, only under acceleration. Like it will idle good, beautiful, rev it a bit and the clicking comes, it has no power on the road but if just changing down and letting it rev a bit, no noise. I haven't driven it since it happened. I wasn't driving it hard at the time but do occasionally. but the engines only done 2000K's +/-. Its a fairly powerful car but now it's just absolutely dead, porbably drove it 25-30K's home after the noise developed. Didn't seem to get worse or louder. Thanks in advance. Share this post Link to post Share on other sites
wagoon 2,429 Posted October 14, 2014 What compression are you running? How much boost are you running? What fuel are you running? Is it possible the sound is pinging? Have you checked the head gasket? Share this post Link to post Share on other sites
ricktewagon 39 Posted October 14, 2014 Compression - waiting for a reply from the guy who built the motor, Boost - 16psi Fuel- was always BP98 but on this tank I put some Mobil 98in.... Havent checked head gasket. Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted October 14, 2014 whip off the inlet pipe of the turbo (engine off) and see how free play is in the shaft. hopefully its just the turbine hitting the housing but hopefully not a turbine wheel thats come off. Share this post Link to post Share on other sites
wagoon 2,429 Posted October 14, 2014 16psi is high for pump fuel unless the compression is quite low and/or fordged pistons are used. Are the piston's dished or flat top? I have known people to get better dyno results using BP98 so going to mobil may have made it ping and caused an issue. Share this post Link to post Share on other sites
XPT 673 Posted October 14, 2014 Hey bud does it make boost at all? From what I can understand it has the symptom under load and when free revving? Share this post Link to post Share on other sites
ricktewagon 39 Posted October 14, 2014 I don't have a boost gauge at all. Would need to plug the laptop in & check it out. It was just pretty sudden to. Yeah it seems relative to acceleration. Idle sounds fine, sounds like it's going to die getting up to 80K's (just from noise from the engine) but whenever your foots of the gas it sounds okay. Even changing down with revs sounds okay. Ill check out the Compressor Wheel in the next day or two. Pistons not sure, am waiting for replys from the guy who built the engine. Nice Crossy though, made 253KW. Yeah it was tuned on BP and the tuner said don't run it on anything else but I was real low and close to Mobil... Share this post Link to post Share on other sites
dougie77 789 Posted October 14, 2014 Has it blown a cooler pipe off somewhere Cortina for life Share this post Link to post Share on other sites
ricktewagon 39 Posted October 16, 2014 Had a look today, all the Cooler pipes look fine, Im going to pull the Rocker cover tomorrow and have a look sounds like its coming from under there at the back somewhere. Compression is 9.0:1 Share this post Link to post Share on other sites
wagoon 2,429 Posted October 16, 2014 Some more questions for you Is the valve train standard? like standard valve spring, standard valves and standard rockers? Does the engine have a "decompression head gasket"(extra thick head gasket)? Does the engine have 2 head gaskets to acheive the desired compression ratio? How often did your drive it hard and what rpm's would the engine see? When it was rebuilt was standard parts used like lifters, camshaft, pistons? Have you checked the timing? Have you rechecked the head bolt tension? Should always been done within a 1000kms of running a rebuilt engine. Share this post Link to post Share on other sites
ricktewagon 39 Posted October 16, 2014 Has normal Head Gasket. Has stock Rockers but better springs & Valves. I work a month on month off roster so In about a year its done 2000K's. Never revved over 6. Camshaft is custom to the fuck, bottom end is lightened balanced etc. Unfortunately I didn't build the engine & the guy who did cant remember fuck all. Havent check Timing or head bolt tension. Ill check what I can as soon as I get a chance. Unfortunately in the process of moving & the Mrs is about to pop our second kid so wont have much time to play with the car. Share this post Link to post Share on other sites
wagoon 2,429 Posted October 16, 2014 I only ask so many queations cause it may trigger an answer from yourself or someone else. So here's some more question :-) Do you know the camshaft specs, specifically the total lift of the cam? When you say there's a clicking noise, does it have a rhythm to the sound? How fast is the sound? Is it a metallic sound like metal on metal? Mate hope the move is an easy one. Hope that everything goes well with the birth. Best of luck on all fronts 1 ricktewagon reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted October 16, 2014 broken rocker - bent pushrod or all of the above. Share this post Link to post Share on other sites
ricktewagon 39 Posted October 17, 2014 Theres my Cam specs & Pushrods I pulled today, all looked like the bottom one except Cylinder 6 Exhaust which was the top one. Length looks the same but maybe a mis-matched Pushrod? Pushrods dont look bent (that I can see) Can I determine Pushrod length for new ones by the Cam Specs? No real rhythm to the sound at idle, but if I revved it up you could hear it was definitely internal. It didnt wanna drive, but changing down gears or with no acceleration sounded normal. Springs, Lifters & Cam are all performance items from Cam-tech. Just normal Rockers & Pushrods. Share this post Link to post Share on other sites
ando76 4,354 Posted October 17, 2014 Roll the pushrods along a known flat surface - that should tell you if they are bent. Share this post Link to post Share on other sites
wagoon 2,429 Posted October 17, 2014 Have done as Lord suggested and tested the wheel/shaft for play? What sort of turbo is it? Does it have internal or external wastegate? Squeeze your piping as it may have a split or crack. Also tighten all clamps as one maybe loose but looks ok. With checking your pushrods, roll them on a piece of glass. When checking the length it needs to be accurate as I had a worn rocker causing a racket and it was worn no more than 3 thou. Share this post Link to post Share on other sites
PRO250 1,506 Posted October 17, 2014 spun bearing?where does that cam run out? almost the same as mine less 50thou numbers but Share this post Link to post Share on other sites
ricktewagon 39 Posted October 18, 2014 Chinese T70 Turbo External Wastegate, Pushrods good but when back together & tightened to spec no.6 Exhaust Rocker is Loose as a goose, tried different rocker & Push rod, same. Could this mean Lifter is fucked? uploading a video now Share this post Link to post Share on other sites
ricktewagon 39 Posted October 18, 2014 Heres the vid http://vid1101.photobucket.com/albums/g425/ricktewagon/IMG_02561_zpshym4kwvw.mp4 Share this post Link to post Share on other sites
ando76 4,354 Posted October 18, 2014 did you try a different rocker post as well as the rocker itself? There is something not right there. You will need to check that the rocker bolt is not actually bottoming out in the head before it gets tight - i.e. the thread is too long. If you remove the rocker bolt and have a look at the last couple of threads they will tell a story. if they are shiny and looked pulled the bolt is to long? Share this post Link to post Share on other sites
gerg 10,871 Posted October 18, 2014 The fulcrum seems to sit still while the rocker wiggles, that tells me it's all tight up top. Could be a collapsed lifter, which is (sort of) reparable, just need a way of getting it out through the pushrod gallery. If it's burred over on the face, you're in a world of poo. Also could well be a wiped lobe and/or stuffed lifter. My Clevo did this exact same thing early on and I had to do cam and lifters. Share this post Link to post Share on other sites
PRO250 1,506 Posted October 18, 2014 It does look like the rockers not done up as you can move the pedastool as well? right bolt in there? Share this post Link to post Share on other sites
ricktewagon 39 Posted October 18, 2014 Bolts are right & tightened to spec. Tried a few different combos this arvo, all the same, must be lifter or Cam Fucked Share this post Link to post Share on other sites
wagoon 2,429 Posted October 18, 2014 For pulling lifters out through the pushrod gallery I made this little tool. worked a bloody treat 2 Outback Jack and gerg reacted to this Share this post Link to post Share on other sites
