XTREME KARTS XF 1,212 Posted August 18, 2014 Any reason why the water pump castings are different? The top pic is the engine out of the wagon and the bottom pic is the engine thats going into the XD. I will be replacing the water pump on the good engine but i dont understand why the casting are differ and the alternator bracket wont bolt up. Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted August 18, 2014 second one is alloy.... aftermarket. whats the bracket hitting? Share this post Link to post Share on other sites
PRO250 1,506 Posted August 18, 2014 mine has 2 washers under them 1 Outback Jack reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted August 18, 2014 second one is alloy.... aftermarket. whats the bracket hitting? The cast boss trev, i guess it was added for strength?? For a water pump for a standed engine, Alloy or Cast Iron? mine has 2 washers under them Any problems with belts lining up? Share this post Link to post Share on other sites
BigCav 464 Posted August 18, 2014 there is about 3 or 4 variations on the alloy pumps and when you buy one off the shelf you should really take in a sample of the old pump i have come accross this issue before as not all water pump brands sell the correct pump for cars, some list the same pump as suiting all clevelands where as i have seen differences in these boss's between cleveland fitted f trucks and broncos etc i dare say its just the wrong water pump 2 gerg and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted August 18, 2014 there is about 3 or 4 variations on the alloy pumps and when you buy one off the shelf you should really take in a sample of the old pump i have come accross this issue before as not all water pump brands sell the correct pump for cars, some list the same pump as suiting all clevelands where as i have seen differences in these boss's between cleveland fitted f trucks and broncos etc i dare say its just the wrong water pump I second that cav, the pump thats on the good motor is getting thrown in the bin anyway, i'll take the one off the motor that was in the wagon, looks to be the original Ford one i reakon. Share this post Link to post Share on other sites
PRO250 1,506 Posted August 18, 2014 nope just bolted on Share this post Link to post Share on other sites
SPArKy_Dave 8,895 Posted August 18, 2014 If you have an original correct Cast Iron clevo water pump, you can get them rebuilt. There are dudes who specialise in it. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted August 18, 2014 My Clevo picks up one of the pump bolts as an alt bracket mount. Maybe a long bolt and spacer is needed? 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted August 18, 2014 If you have an original correct Cast Iron clevo water pump, you can get them rebuilt. There are dudes who specialise in it. Interested to know more Share this post Link to post Share on other sites
SPArKy_Dave 8,895 Posted August 18, 2014 Interested to know more AUTO COOLING 5 Hall Street Yarraville, Melbourne Ph: 9362 7799 and speak to Peter. This mob cast their own larger impeller for more water flow. 2 XTREME KARTS XF and Outback Jack reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted August 18, 2014 My Clevo picks up one of the pump bolts as an alt bracket mount. Maybe a long bolt and spacer is needed? Cast or Alloy water pump? Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted August 18, 2014 AUTO COOLING 5 Hall Street Yarraville, Melbourne Ph: 9362 7799 and speak to Peter. This mob cast their own larger impeller for more water flow. Cheers Dave!!! Share this post Link to post Share on other sites
gerg 10,871 Posted August 18, 2014 Cast or Alloy water pump? Cast stocker mate, but dunno how that extra gusset on your alloy one interferes with your bracket without having seen it. I'd say it's there for extra strength because alloy isn't as strong as iron so needs reinforcing. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
