Mr Polson 10,214 Posted August 10, 2014 I've never used or seen silastic used on that external head bolt. Also, don't forget it doesn't get tightened as much as the rest. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted August 10, 2014 Those EGR pipes are cunts to do, if you've got a blow torch or an oxy set, heat the bastard up then try and crack it with a spanner. If to no avail use other means necssary Share this post Link to post Share on other sites
Ando81 2,949 Posted August 10, 2014 I've been able to get the head off leaving both manifolds on so the egr pipe stayed in place, I tried to crack it but was only going to round the nut. I found a small piece of corrosion on the back of the head which may have caused the leak. Pics to follow. Share this post Link to post Share on other sites
Ando81 2,949 Posted August 10, 2014 <br />Has anyone used that spray on copper gasket stuff from repco. A mate of one suggested using a light spray of it as well as the gasket to hopefully fill in some of the gap. Share this post Link to post Share on other sites
bear351c 10,271 Posted August 10, 2014 Yep, works OK. The gasket should take up any imperfections in the surface, the spray wont hurt anything. 2 Ando81 and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted August 10, 2014 Ok mate thanks for that. Share this post Link to post Share on other sites
XFGHIA747 76 Posted August 10, 2014 Hey mate, yeah probs already said make sure the out side head bolt with the earth clamp is only tightened to second tention spec not final, and it doesnt hurt to put a bit of permatex on that bolt due to that bolt going into the water pump jacket.. cheers jake 1 Ando81 reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted August 10, 2014 Well after 8 hours I'm still no better off than I was this morning. Had put it back together and torqued down to the 75pound stage, started on the first bolt at 88 pound and snap. Snapped the stud off at just above the block so off came the head and the gasket was rooted, had to clean all surfaces and will start fresh tomorrow with new gasket and new bolts. Don't know if my tension wrench is dodgy or if I had some crap in the stud holes which jammed the thread and snapped the bolt. So much for trying to learn a bit and save some cash Share this post Link to post Share on other sites
Gravelrash 36 Posted August 10, 2014 are you setting the tension wrench to pounds per sq inch or Newton meters? are you reading the right scale? Share this post Link to post Share on other sites
Ando81 2,949 Posted August 10, 2014 Yeah pounds. But I am doubting the wrench. Will be borrowing a better one tomorrow to start fresh. Share this post Link to post Share on other sites
bear351c 10,271 Posted August 10, 2014 Just to be safe, you could set it at 25, then 50, then 75 etc........Do all the bolts up in sequence 1 Ando81 reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted August 10, 2014 Thanks lads but I'm very retarded. I've torqued the shit out of these bolts. I had it set at ft/lbs instead of nm. So the second tension was pulled down to almost 120nm 1 bear351c reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted August 11, 2014 Ended up getting the head gasket fixed this time. Turns out that my tension wrench was only sometimes releasing at the right point. Borrowed one off a mate and his worked much better. I used some head studs out of a virgin block because I couldn't wait for new ones to be posted out, wasn't going to trust my old ones that had been tensioned a few times. Seems to be running fine so far, thanks for all the helpful advice fellas 2 Thom and bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,271 Posted August 11, 2014 Way to go, fella. Glad to hear it, and you did it all yourself. Nice feeling, isn't it? Share this post Link to post Share on other sites
Ando81 2,949 Posted August 11, 2014 Cheers mate, seemed like the light had almost gone out at the end of the tunnel for a bit but I just had to battle on and get it done. Lost a day's work but who enjoys working on Monday anyway Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted August 11, 2014 Sounds like things went well for you Justin. Did you use coolant or straight water when you filled the radiator back up? Glycol can ruin a new head gasket from what i've been told so i always use straight water for 500 km's then dump it and fill with the green stuff!! 1 Ando81 reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted August 11, 2014 Cheers Mark, I'm just running with plain water so I can give it a flush in a few days time. Thanks for the tip mate, never heard it before. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
