Ando81 2,950 Posted July 28, 2014 Hi all, just wondering if anyone can answer a question for me regarding a leaking head gasket on a crossflow in my ute. So 18 months ago I had the head gasket changed by my local mechanic and it's just started to leak again. It's not his fault that it is leaking because my LPG converter had been leaking gas into the cooling system and over pressurising the system and got hot a couple of times. A mate of mine said that I might be lucky enough to re- torque the head down to stop the gasket leaking but I'm not convinced. It is leaking coolant at the back of the head between the head and block. I would attempt the new gasket myself but am not confident putting the rocker gear back on and setting the clearances properly. So is it worth trying to just tighten the head bolts down again or take the head off again? Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted July 28, 2014 With the right tools its not too difficult, take the head off and get it machined. And it pays to send off the converter while your at it too!! You'll need a good quailty 1/2 drive Torque Wrench, with the rocker gear just torque them to spec. The lifters will be clacky on startup but they'll shut up once bled up. 1 Ando81 reacted to this Share this post Link to post Share on other sites
Ando81 2,950 Posted July 28, 2014 Right, so without sounding too retarded, the standard rockers aren't adjustable? Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted July 28, 2014 Correct, they are hydraulic lifters so zero lash. 2 steve mcqueen and Ando81 reacted to this Share this post Link to post Share on other sites
Ando81 2,950 Posted July 28, 2014 Ok well that makes it sound a lot easier. Cheers Mark 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted July 28, 2014 Would be cheaper to throw a bottle of this stuff in and see how she goes. Avalible in most parts stores including Repco. http://rislone.ca/catalog/view/37-liquid-copper-block-seal-intake-radiator-stop-leak-31109 Share this post Link to post Share on other sites
Ando81 2,950 Posted July 28, 2014 Always been paranoid of this stuff blocking up radiator tubes and affecting flow. Share this post Link to post Share on other sites
dizzy616 183 Posted July 28, 2014 if its stock crossy its easy as. i can do em blindfolded. well probably not but i feel like i could. after doing them so many times. lolallmost as easy as. sticking one of those bottles in the radiator. just a little bit more time involved. Share this post Link to post Share on other sites
Ando81 2,950 Posted July 28, 2014 Ha ha, yeah I might have a crack at it. My mate is always pulling them apart on his speedway xf so he offered to give me a hand. Share this post Link to post Share on other sites
PRO250 1,506 Posted July 28, 2014 Would be cheaper to throw a bottle of this stuff in and see how she goes. Avalible in most parts stores including Repco. http://rislone.ca/catalog/view/37-liquid-copper-block-seal-intake-radiator-stop-leak-31109 I second pooring that in it They leak somtimes its mostley cause of a little rust on the top of the block, thats where those old headgaskets rob and i talk about come into there own, they have a red ring around everything and it stops them from leaking. Its a shame they dont make anything good anymore. My v8 cortina is doing it atm im not lifting the right head to fix it its just water ill poor that in it as well. Its not the devil you poor it in run it till the leack seals up and flush it back out 1 steve mcqueen reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted July 29, 2014 As said, if its a stock crossy its a simple, two day job (I say two day so you can have the head machined). Just keep all your bolts sorted, put each pushrod and rocker back where they came from, and torque it all to specs. First major mechanical thing I done was the cam in my Ghia wagon, which involved removing the head, I done it with no major issues and the car ran fine afterwards. 3 XTREME KARTS XF, Ando81 and PRO250 reacted to this Share this post Link to post Share on other sites
PRO250 1,506 Posted July 29, 2014 As said, if its a stock crossy its a simple, two day job (I say two day so you can have the head machined). Just keep all your bolts sorted, put each pushrod and rocker back where they came from, and torque it all to specs. First major mechanical thing I done was the cam in my Ghia wagon, which involved removing the head, I done it with no major issues and the car ran fine afterwards. I have to ask if its only leaking water why are we machining the head? i poped 2 on my ghia and never once milled the head. Its not warped from over heating its just leaking water A little off topic why did you remove your head to do a cam change? was it just easyer? 1 nos2 reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted July 29, 2014 I have to ask if its only leaking water why are we machining the head? i poped 2 on my ghia and never once milled the head. Its not warped from over heating its just leaking water A little off topic why did you remove your head to do a cam change? was it just easyer? I've just always been told to machine the head whenever changing a head gasket. For what $80-$100 its good security. Good point though if its just leaking it might be alright. Took the head off to get the lifters out, number 1 lifter and number 12 lifter were the two I couldn't get out, and back in, with head on. Share this post Link to post Share on other sites
PRO250 1,506 Posted July 29, 2014 I just put a straight edge across the head if its good it goes back oni just did a cam swap in gumbys XE i did not pull the head off but that number 1 lifter is a little hard took me about 5 mins to get it in where all the rest took like 10 seconds 2 XTREME KARTS XF and steve mcqueen reacted to this Share this post Link to post Share on other sites
Ando81 2,950 Posted July 29, 2014 Yeah I reckon that sounds pretty fair Dave! My mechanic did valve stem seals last time it was off. Might just give it all a good clean and run a straight edge over it and do the gasket. Thanks for the input lads 1 steve mcqueen reacted to this Share this post Link to post Share on other sites
dizzy616 183 Posted August 2, 2014 1 day job if you know the dude at the machine shop. thats even if you bother machining it. ive gotten away without machining a couple times and no issues.not like its a steel gasket. unless head is warped to the shithouse.just tighten the bolts down in the right order. you will be right. 2 XTREME KARTS XF and Ando81 reacted to this Share this post Link to post Share on other sites
Ando81 2,950 Posted August 9, 2014 Just so I hopefully get it right, is there any tips I need to know about before I start the head gasket replacement. Was thinking of taking the easy way out and leaving the manifolds both on. Open for suggestions and won't be offended either way. Share this post Link to post Share on other sites
bear351c 10,276 Posted August 9, 2014 Take your time....... Take photos with your phone, or vid as you go. Then if you're unsure, check the vid. Place all your rockers and pushrods in order, make sure all gasket surfaces are clean and flat. Get a mate to help you, if ya can, 2 sets of eyes is better than one. And he/she must supply the beer. And lastly, take your time. 1 Ando81 reacted to this Share this post Link to post Share on other sites
Ando81 2,950 Posted August 9, 2014 Cheers mate, a mate of mine has told me to keep all of the rockers an pushrods etc together and in the right order. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 9, 2014 I'd take at least the exhaust manifold off. Normally fine leaving the intake on there. Remember to disconnect fuel line from carb/fuel pump. 1 Ando81 reacted to this Share this post Link to post Share on other sites
Ando81 2,950 Posted August 9, 2014 Ok, was worried about stuffing the flange gasket if I left the exhaust manifold on. And yeah thought the fuel line would be easier to take off once the air cleaner is out of the way, thanks for the input fellas. Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted August 9, 2014 And dont for get head bolt number 14, being on the outside of the cylinder head, where the earth strap connects to, ive seen people forget it and try and lever the head off to no avail, then realize and go 'oh, there's another bolt'... Funny as. I kid you not. The pipe that connects to the exhaust manifold and goes to the EGR valve, prolly gona be a biatch to? Id start now with some WD 40 on it and let it soak in. 2 Ando81 and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Ando81 2,950 Posted August 9, 2014 Cheers Steve, will give the egr pipe a soak overnight. And that earth bolt needs silastic on it too doesn't it? Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted August 9, 2014 narh, the earth strap bolt wont need silastic. If it already has it id say "the thread is damaged and somebody has used silastic on it to assist in it tightening it up", done that one myself in the past. See how it goes. Share this post Link to post Share on other sites
Ando81 2,950 Posted August 9, 2014 Ok, I thought I read it somewhere that it needed it but you would know more than me so I'll throw it back in without it. 1 steve mcqueen reacted to this Share this post Link to post Share on other sites
