XFGHIA747 76 Posted May 30, 2014 Simple question can a ef xr6 diff go onto my xf ghia? Brake lines and such aint an issue just phisical bolt in part what arms need to be used bushes etc mounts need to be moved ? Or cant be done ? Cheers lads Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted May 30, 2014 All the same mate, pick up points "n" all!! As for the brakes i "think" the EA-EB-ED calipers will bolt onto the EF-EL diff.... 1 XFGHIA747 reacted to this Share this post Link to post Share on other sites
XFGHIA747 76 Posted May 30, 2014 Thanks mate thats all I wanted to know Share this post Link to post Share on other sites
Campo 869 Posted May 30, 2014 Easy as conversion! Just press in ef/el lower trailing arm bushes into your xf arms at the diff end (can buy the diff end bushes on their own too) Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted May 30, 2014 How does the XF Hand brake cable mount up on the XR6 Diff? Share this post Link to post Share on other sites
Campo 869 Posted May 30, 2014 And use ef tailshaft 2 Mr Polson and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted May 30, 2014 Steve... im fitting an ef diff into my ute at the momment and it will be very similar if not the same as your xd if u want to compare notes. Ill be running the ef rotors, calipers and handbrake. Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted May 30, 2014 Steve... im fitting an ef diff into my ute at the momment and it will be very similar if not the same as your xd if u want to compare notes. Ill be running the ef rotors, calipers and handbrake. Awsome n00bs. I know when fitting the EF/EL hand brake lever you can use the existing handbrake stuff on the diff but with the XF handbrake lever under the dash and running 2 cables how do the guys go about getting around that? was my concern. Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted May 30, 2014 Ive worked out a way to adapt the XG handbrake lever and twin cables onto the EF hand brake mech at the wheel, i havent welded it all up and operated it yet but i think it will be a winner. As i cut all the ugly hand rake cables and mounts off my diff i was intending on welding them back onto the front face so they would be hidden from the back view but it was getting to complicated with the swaybar mounts and also shock positions so i worked out another way. Ill grab pics for you soon mate, they will be in my build thread soon. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted May 30, 2014 And use ef tailshaft Look you remembered to mention the tailshaft this time 2 Campo and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted May 30, 2014 Look you remembered to mention the tailshaft this time Sedan and ute/wagon's use different length tailshafts though.Sedan is shorter and ute's/wagon's use longer.I'd suggest finding a early EA style tailshaft as they used a smaller rubber damper and fit in lowered cars easier.Well thats what I did when I fitted a ED wagon diff and EA tailshaft to my xf ute.Some people swap the front flange plate to a u style set up to use the standard tailshaft though. P.S Just thinking,are the sedan shafts steel or alloy? For a performance use it is advised to use steel as the alloy ones are a risk over 180kph and when used on big HP cars. Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted May 30, 2014 Ive got an EB wagon shaft in mine, aluminum and no rubber dampener to be seen. Share this post Link to post Share on other sites
wagoon 2,429 Posted May 30, 2014 P.S Just thinking,are the sedan shafts steel or alloy Tailshafts come in both alloy and steel for sedan as well as wagon. Share this post Link to post Share on other sites
slydog 7,873 Posted May 30, 2014 Tailshafts come in both alloy and steel for sedan as well as wagon. Yep got a XG/H steel unit for the ute a few weeks back...Cheers to Thom for the info on that... 1 Thom reacted to this Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted May 30, 2014 For a performance use it is advised to use steel as the alloy ones are a risk over 180kph and when used on big HP cars. Tickford fitted alloy shafts to everything they built running 3.45 gears and 5,500rpm redlines, and then removed the factory set 180kph speed limiter in their tunes. Cant see them being an issue, especially if you are going to compare stock steel for stock alloy at 200kph with 600hp+ under the hood. Then again whoever builds something like that and runs a stock tailshaft is cutting corners. Share this post Link to post Share on other sites
slydog 7,873 Posted May 30, 2014 Tailshafts come in both alloy and steel for sedan as well as wagon. Hows your's coming along bro? Share this post Link to post Share on other sites
wagoon 2,429 Posted May 31, 2014 Which one? Haha I'm picking up a steel tailshaft today for my sedan(be end of year before sedan is running) Wagon will be registered in a month or two 1 slydog reacted to this Share this post Link to post Share on other sites
