Campo 869 Posted April 6, 2014 I've just gone from 2.92 to 3.45 in my XF. Speedo was perfect with the 2.92's and now reads about 12-14kmh above what i'm actually doing. Anyone got any idea how to rectify this problem? Cheers Share this post Link to post Share on other sites
Ando81 2,949 Posted April 6, 2014 Here's a diagram off eBay I saw that has ratios and gearbox type which tells you what colour gear to suit the speedo to correct it. Sorry it's not really clear. 1 PH351 reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted April 6, 2014 I think for 3:45 gears it says a grey gear with 22 teeth. Share this post Link to post Share on other sites
Campo 869 Posted April 6, 2014 Thats the go, i'll try that! They sell them on ebay then im gathering? Share this post Link to post Share on other sites
Mr Polson 10,214 Posted April 6, 2014 Yeah eBay or parts stores, I'm pretty sure you can get them new from Ford still too. Share this post Link to post Share on other sites
Campo 869 Posted April 6, 2014 Just ordered a grey 22 tooth gear off ebay, thanks fellas 1 Ando81 reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted April 6, 2014 I should get one for my ute, went from 2:92 to 3:23 gears so it reads 10km higher than actual road speed. I'm tempted to leave it though coz if I sneak up to 120 on the freeway I'm still only doing the legal speed ha ha Share this post Link to post Share on other sites
Campo 869 Posted April 6, 2014 Yeah its a bit annoying sometimes though. Haha. Was driving along earlier doing 75 on the speedo and was only just doing 60 haha Share this post Link to post Share on other sites
Ando81 2,949 Posted April 6, 2014 I must be getting old, I'd prefer to be on the safe side instead of getting camera fines for being 4km over the limit. Share this post Link to post Share on other sites
Campo 869 Posted April 6, 2014 I prefer to know what speed im actually doing rather than trying to remember that it always reads higher haha Share this post Link to post Share on other sites
Mr Polson 10,214 Posted April 6, 2014 What's the difference between 5spd H/D and L/D, anyone know? When I went from 3spd to T5 I kept the green (I think) gear from the 3spd, and put it in my T5. Speedo is still dead accurate so I'd say I have the 5spd L/D, whatever that means. Share this post Link to post Share on other sites
Ando81 2,949 Posted April 6, 2014 I wonder if the l/d might be the light duty Borg Warner box like a single rail box from an xf 3.3lt motor. Share this post Link to post Share on other sites
nickd 111 Posted April 6, 2014 Just ordered a grey 22 tooth gear off ebay, thanks fellas Do you mind if I ask where you bought it from and how much it cost? I need one aswell. Share this post Link to post Share on other sites
Campo 869 Posted April 6, 2014 Just ordered a grey 22 tooth gear off ebay, thanks fellas Do you mind if I ask where you bought it from and how much it cost? I need one aswell. http://bit.ly/1inecuc 1 nickd reacted to this Share this post Link to post Share on other sites
BigCav 464 Posted April 7, 2014 the gears are still available from any ford dealer for mid 20's Share this post Link to post Share on other sites
Ando81 2,949 Posted April 7, 2014 Cheers cav, that's handy to know! Share this post Link to post Share on other sites
Mr Polson 10,214 Posted April 7, 2014 I wonder if the l/d might be the light duty Borg Warner box like a single rail box from an xf 3.3lt motor. My box is a T5 though. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted April 7, 2014 But with a 3.23 diff and green speedo gear my speedo is spot on. According to that chart I'd need a pink one (if h/d meant T5) Share this post Link to post Share on other sites
gerg 10,871 Posted April 7, 2014 Maybe your worm gear is the earlier type with 7 instead of 8 teeth. Mine has 3.27s and uses the light green one and is spot on. That chart doesn't make any sense because 2.92 and 3.23 use a 19 tooth but 3.27 diff uses 21-tooth? Yet the other charts have the 3.23 and 3.27 both using 21-tooth. I guess you could just get a size up/down from your current one and just try it Share this post Link to post Share on other sites
Ando81 2,949 Posted April 7, 2014 Here's an idea fellas, if your diff ratio increases by say 20% then maybe the transducer gear needs to increase by 20% also. Just a thought. Simple maths might give you a guide as to how many extra teeth you may need on your gear. 1 gerg reacted to this Share this post Link to post Share on other sites
wookie 45 Posted April 7, 2014 hi guys, if you change your rims to a larger diameter tyre, going from 14" to 15" do you need to go down teeth on the cogs? scored a nice set of 15 csa globe copies and definitely want to fit them on the XC since 14" tyres are getting pricey in WA and limited sizes i think ive got a pink cog in my single rail box atm, for the 2.92 diff ratio [pretty sure i pulled out a green one from the three speed manual with the 2.77 diff, honestly cant remember, too many sleepless nights with a newborn] Share this post Link to post Share on other sites
gerg 10,871 Posted April 7, 2014 If you've gone with a lower profile tyre, say from 195/65/r14 to 205/60/r15 then the rolling diameter should be pretty close, and not worth worrying about. If on the other hand you've changed it by more than 5% then there might be an issue. I'd check your speedo against a GPS first before losing sleep over it. Share this post Link to post Share on other sites
gerg 10,871 Posted April 7, 2014 Here's an idea fellas, if your diff ratio increases by say 20% then maybe the transducer gear needs to increase by 20% also. Just a thought. Simple maths might give you a guide as to how many extra teeth you may need on your gear. That's the approach I took going from 2.92 to 3.27 and it was spot-on. Was 19-tooth and now is 21. 1 Ando81 reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted April 7, 2014 Just as gerg says, I would sit the 14 inch rim with a tyre fitted, beside the 15 inch with a tyre fitted and see the height difference is. If it is not much taller than fair chance you will not need to change the speedo gear but if it is a lot taller then you will need to look at altering it to suit. Share this post Link to post Share on other sites
