adrianphu123 73 Posted March 20, 2014 Hey guys, My crossmember is buckling up and backwards when i jack it up, im looking to replace the bottom plate, as well as beat the side of the crossmember forward so its perpendicular to the ground. Just wondering if i can replace the bottom of the crossmember with the crossmember plate designed for an XW and XY. The link below is what im looking to replace with. http://www.fordmuscleparts.com.au/shop/products/show/id/4988 thanks adrian Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted March 20, 2014 This reminds me of the epic 'Tuckers Sump' thread on xfalcon. LOL! http://www.xfalcon.com/forums/index.php?/topic/26193-87da-eseries-sump/ I don't see why XW/XY wouldn't fit. 1 Mr Polson reacted to this Share this post Link to post Share on other sites
dvfalcon 352 Posted March 20, 2014 The cross member on my mums XD got damaged years ago. It was repaired using a 6mm plate welded in.it was rock solid after that. Dale Share this post Link to post Share on other sites
Gaz 1,085 Posted March 20, 2014 XW/XY had a couple of different types but I couldn't imagine they would repo anything but a 54H type but who knows? Don't forget that XA onwards had a wider shock tower spacing so that might have a bearing on the width of the crossmember. I'd just weld a chunk of eighth or quarter plate in there. (See how old I am? 3 mil. or 6 mil. plate then) 2 XTREME KARTS XF and slydog reacted to this Share this post Link to post Share on other sites
Ants 6,370 Posted March 20, 2014 XW/XY had a couple of different types but I couldn't imagine they would repo anything but a 54H type but who knows? Don't forget that XA onwards had a wider shock tower spacing so that might have a bearing on the width of the crossmember. I'd just weld a chunk of eighth or quarter plate in there. (See how old I am? 3 mil. or 6 mil. plate then) No it's not the tv Gaz,no one can see you. Share this post Link to post Share on other sites
gerg 10,871 Posted April 28, 2014 Yeah I second the comments above, as long as the repairs are of equal or greater strength than the original, and done by a competent person, there's nothing anybody can say or do. I replaced the sills in my Corty with twinned 40mm square tubes welded together. It was as strong as an ox after that, and passed 5 regos without anyone even questioning them. I guess if you can make it look normal, nobody will give a shit. Share this post Link to post Share on other sites
