XTREME KARTS XF 1,212 Posted January 27, 2014 Hey fella's I've been wanting to do the Vac Advance distributer conversion for a while now so i've figured that its about time, now my question is (and its a dumb one so bear with me) but all i have to do is run 2 wires from the distributer to the coil right? I want to ditch the EST setup as it doesn't like the cam i put in when i rebuilt the engine. Share this post Link to post Share on other sites
PRO250 1,506 Posted January 27, 2014 2 wires put both on the coil and peg the est dissy donenote check the power to the coil is still 12 volts 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Perky 8 Posted January 27, 2014 As pro said.......:-) 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted January 27, 2014 send me your est dizzy - I love them. lol. Share this post Link to post Share on other sites
slydog 7,873 Posted January 27, 2014 The EST dizzy is a good thing and works well if tricked right.Take your 2nd coolant sensor from the head, plug the head and drop the sensor in the wind screen washer bottle.That will keep the timing wound up on it and give you performance all the time not just when cold. Or go to a streetfire msd for $170 and wire up your est dizzy to and watch the difference in the car. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted January 30, 2014 Cheers fellas!! send me your est dizzy - I love them. lol. Nahh i'll keep it lol The EST dizzy is a good thing and works well if tricked right.Take your 2nd coolant sensor from the head, plug the head and drop the sensor in the wind screen washer bottle.That will keep the timing wound up on it and give you performance all the time not just when cold.Or go to a streetfire msd for $170 and wire up your est dizzy to and watch the difference in the car. Hmmm i like the sound of that!! Share this post Link to post Share on other sites
winton 399 Posted January 31, 2014 Or go to a streetfire msd for $170 and wire up your est dizzy to and watch the difference in the car. I did this about 2 weeks ago. Works good. 2 slydog and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted January 31, 2014 Or go to a streetfire msd for $170 and wire up your est dizzy to and watch the difference in the car. I did this about 2 weeks ago. Works good. Sorry to sound stupid fellas but what does this upgrade improve and involve ? I have an est distributor and wouldn't mind a bit of improvement. 2 XTREME KARTS XF and slydog reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted January 31, 2014 I think I found a post about this by slydog. Is this the streetfire control box that leaves the timing locked on the marks that are set on the motor? 2 XTREME KARTS XF and slydog reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted January 31, 2014 It just means you have NO advance curve so you set the timing as total or @ the crank as it is known.Never seen or found a car that went backwards when they did this conversion...never.Clint,McFly and others have done it for the same results,it just works.You are not limited to a Street fire CDI...you could use a 6AL,6AL2,7AL or Digital 6 or 7 or a 6AL2 programmable if you really want a timing curve but I have found it's just not needed TBH.A street fire is cheap and works awesome on a street car so I would stick to that. Thanks to Jase Stoodley for the hook up. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted January 31, 2014 Cool, I'm learning all the time from you fellas! Thanks Share this post Link to post Share on other sites
