dizzy616 183 Posted August 6, 2013 good day i was wondering if there is any other clutch pedal set ups that fit xf. because i noticed x series manuals are a bit hard to find at the local wreckers. seems that if there is one someones got it allready.unless someone has one they might want to trade a e series pedal for a x series pedal set up Share this post Link to post Share on other sites
deankxf 20,329 Posted August 6, 2013 if you dont mind paying you can buy a pin that bolts on to the auto pedal box... if you are handy you can make one. http://www.malwoodauto.com.au/innovations.htm Share this post Link to post Share on other sites
dizzy616 183 Posted August 6, 2013 hmm i actually like that idea is it true you need to remove the dash too to fit a clutch pedal set up? i might have to fork out for it if it saves a bit of time. also can you use that with the ea lines? so i can just get the pedal and pin set up Share this post Link to post Share on other sites
deankxf 20,329 Posted August 6, 2013 E series you need to remove the dash..XF you can do with the dash in, i leave the steering column in.. remove the steering wheel, lower the column and rest it on the seat(2 nuts hold that to the pedal box from memory) worst part is undoing the nuts on the booster for me.. you still need to unplug the wires on the column, still a prick of a job.. if you have to buy a pedal box anyway.. i'd buy the pin kit, if the pedal box cracks(manual ones do still anyway) finding an auto one is far easier. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
dizzy616 183 Posted August 6, 2013 one of those pin and pedal kits? would it work with e series clutch cable? Share this post Link to post Share on other sites
deankxf 20,329 Posted August 6, 2013 think so.. pretty sure the cables dont vary much compare to XG.. try it and see.. Share this post Link to post Share on other sites
revhead 1,392 Posted August 6, 2013 get a black bolt nylock nut and a clutch pedal and your set ,need not pull anything apart, and put the grinder through the auto pedal Share this post Link to post Share on other sites
dizzy616 183 Posted August 6, 2013 i seen that on some build thread cant remember what one it was but could be on old site Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted August 6, 2013 would it work with e series clutch cable? Yep. I use an EA clutch cable in my XD with T5 set up, seems to work fine. Also ive never had issues with the clutch pedal set up cracking but have read some others do. (touch wood it stays like that) Share this post Link to post Share on other sites
deankxf 20,329 Posted August 6, 2013 Yep. I use an EA clutch cable in my XD with T5 set up, seems to work fine. Also ive never had issues with the clutch pedal set up cracking but have read some others do. (touch wood it stays like that) i've had heaps crack..well 5... same with firewalls. but thats on 15yr old car. wonder how long they take? my firewall is still good 30,000kms later as you'd expect(auto to manual converted) having rooted clutch cable doesnt help. wonder if thats half the issue(about $100 new for that too) Share this post Link to post Share on other sites
Gaz 1,085 Posted August 6, 2013 E series cables are shorter than X series. You can use it no problems, but it won't reach if you route it through the crossmember as per spec. You can still run it through if you drill a new exit hole. Or do what every other cunt does and leave it swinging in the breeze. 3 Ants, XTREME KARTS XF and deankxf reacted to this Share this post Link to post Share on other sites
dizzy616 183 Posted August 6, 2013 yeh i was going to fit a 4.0 when i do this conversion. couldn't you tie it to something instead of leaving it swinging Share this post Link to post Share on other sites
deankxf 20,329 Posted August 6, 2013 E series cables are shorter than X series. You can use it no problems, but it won't reach if you route it through the crossmember as per spec. You can still run it through if you drill a new exit hole. Or do what every other cunt does and leave it swinging in the breeze. i ziptied my my XF one under the x member to keep the curve nice.. i would do this regardless of E series cable or the correct one Share this post Link to post Share on other sites
deankxf 20,329 Posted August 6, 2013 yeh i was going to fit a 4.0 when i do this conversion. couldn't you tie it to something instead of leaving it swinging zip tie it to the cross member Share this post Link to post Share on other sites
dizzy616 183 Posted August 6, 2013 zip ties aye i like zip ties. Share this post Link to post Share on other sites
BBS XE 160 Posted August 6, 2013 I use an EL clutch pedal in my XE, atached to the XE auto pedal box with a big nut and bolt with spacers etc (was on the pedal I got out of the EL). The EL pedal is pressed metal and looks a bit different cosmetically but physically they are the same as the earlier ones. I cut the bump stop plates off mine but I don't think it was really necessary. Share this post Link to post Share on other sites
dizzy616 183 Posted August 6, 2013 are you able to get a picture of this bbs xe i kind of get the idea would like some visual confirmation too but Share this post Link to post Share on other sites
BBS XE 160 Posted August 7, 2013 Can't get a pic of it sorry bud, the car's stored at a relatives place at the moment. The pin kit looks like this: http://www.ebay.com.au/itm/Ford-EA-EB-ED-EF-EL-Falcon-Manual-Clutch-Pedal-Pin-Kit-XR6-XR8-Fairlane-/261252592361 Mounted with standard mount: http://t3.gstatic.com/images?q=tbn:ANd9GcTdOhHUUUxp7G6ToiWBFiVANdciIz8-WeM02RvCRPCZg5ff3QyiHg The pedal looks like this: http://www.ebay.com.au/itm/Ford-Ea-Eb-Ed-Ef-El-Xh-Manual-Clutch-Pedal-May-Suit-Au-Xr6-Xr8-Tickford-/290957014914 I'm sure if you can make something that will do the same job as the pin kit without paying $100 for it. Share this post Link to post Share on other sites
dizzy616 183 Posted August 7, 2013 so what just drill a hole in the side of the auto pedal box and attach a clutch pedal too it? Share this post Link to post Share on other sites
deankxf 20,329 Posted August 7, 2013 so what just drill a hole in the side of the auto pedal box and attach a clutch pedal too it? the hole is already there Share this post Link to post Share on other sites
xdfairmont79 135 Posted October 4, 2013 I have an x series pedal box I'd trade for an eb one, (apparently Ed is different..) that's if your interested. Otherwise could I do the pin on the side of these series auto pedal box? Share this post Link to post Share on other sites
revhead 1,392 Posted October 5, 2013 xe to el pedal boxes are the same ,ive welded up heaps of them Share this post Link to post Share on other sites
Gav 616 Posted October 5, 2013 Same in what respect? Cos they all break sooner or later? Physically, they are different beasts as far as I've observed. E-series ones have the flange with three fixing points up behind the dash meaning you have to move the entire dash assy forward around 5cm to get at the bolts at those points. X-series don't have those making dash assy. re-positioning unnecessary. Share this post Link to post Share on other sites
revhead 1,392 Posted October 5, 2013 ive got an el pedal box in my XE bolted straight in, also bolted my old xe pedal box into my mates eb a few weeks back, yes to look at they seem diff but there basically all the same Share this post Link to post Share on other sites
