93xf 2 Posted June 23, 2013 Does anyone know if the motor and t5 can be removed as one from an XF by dropping the fan and radiator etc? Or does the motor have to come out of the car separate of the gearbox?? Thanks. Share this post Link to post Share on other sites
Thom 6,651 Posted June 23, 2013 You can remove them as one quite easy Share this post Link to post Share on other sites
SLO247 1,713 Posted June 23, 2013 I've only ever pulled them out complete. Easy as. Share this post Link to post Share on other sites
revhead 1,392 Posted June 23, 2013 just remember to remove the gear stick and fit a dumby shaft to the rear of t5 ,also unhook hand brake cable as itl snag the rear of the box,yes i know a lot of you dont do this but i do bc as i stated,plus it help when you go for the 75 degree lift angle 1 deankxf reacted to this Share this post Link to post Share on other sites
adrianphu123 73 Posted June 23, 2013 dont forget the ground strap from body to bellhousing too 1 revhead reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted June 23, 2013 Yep completely doable but for the sake of 4 bolts on the gearbox I'd just separate them. Otherwise, you need some serious angle and height on the engine/box to clear everything, not easy with some smaller engine hoists and with the front end up on ramps/stands. Share this post Link to post Share on other sites
revhead 1,392 Posted June 23, 2013 easy as ,take off the front wheels if your hoist doesnt go that high and let the car down on stands ,theres a whole world of pain spliting it ,get it up on stands ramps ,then the bellhousing is useally to tall to pull out under the xmember so you need to jack the car up ,then you drag the box out then need to remove the stands ramps 2 starter motor bolts 4x cross member bolts, inspection cover bolts x4, ,,4 or 6 bellhousing bolts ,to much ,do it on the floor later lol while having a beer or bourbon,or 3 1 Thom reacted to this Share this post Link to post Share on other sites
P100_Ute 460 Posted June 23, 2013 i just stick front wheels on 2 pavers high to clear the legs of crane under the lower controll arms. This was in my garage and i didnt have any height issues getting it out. Undid the 2 bolts on gearstick for the T5 and left the plate and short stick still bolted to the top of box. Used tailshaft yoke to bung the rear up and i got a spare speedo cable cut to block the speedo hole as oil will leak out of there also when you tilt it back. and voilah out she came. Falcons have bigger bays so you should get it out peice of piss. 1 revhead reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted June 23, 2013 thats the ticket right there^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Share this post Link to post Share on other sites
dizzy616 183 Posted June 23, 2013 yes next time im doing it. im removing them both. i made the shitty decision of splitting it. Share this post Link to post Share on other sites
