NZXD 2,328 Posted May 17, 2013 Right, I have thought about doing a Windsor thread for a bit, and now that I actually have something to write about its a good time. There aren't to many X series (XD- XF) on here that are running Windsor's, that I have read about. I have an AU3 XR 302 roller block std stroke, 60cc edlebrock alloy heads, rpm manifold, 600cfm quick fuel carb, hurricane headers, Mallory ignition, F303 cam, roller rockers, Gilmour drives, zero decked block and all balanced, apart from block, crank and rods, its all brand new. Since reading other threads such as Slydogs and pro250s with the NA and boost builds, I feel that I need to redo my combo. I have looked at the 331 stroker, going to bigger AFR 185 heads, more comp, cam and induction OR keeping the 302 and putting boost through it and converting back to EFI as I still have all the bits n pieces. Potential budget of an extra 5k. Any thoughts. Share this post Link to post Share on other sites
revhead 1,392 Posted May 17, 2013 ive just bought a 302 windsor for mine ,ive had alot of clevos, spent big money on them ,and they go hard ,but there fooking heavy ,a little windsor is much lighter and parts are more readily available gt40 heads add afew ponies Share this post Link to post Share on other sites
Thom 6,651 Posted May 17, 2013 Personally I'd go for the 331 over a 347, taller piston leads to longer engine life, problem is with a roller block if you start making more than 550 HP or want to spin it past 7000 rpm most factory blocks won't last before long before they call it quits although occasionally you will find one that will, what sort of power are you chasing?<br /> 1 gerg reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted May 17, 2013 ive just bought a 302 windsor for mine ,ive had alot of clevos, spent big money on them ,and they go hard ,but there fooking heavy ,a little windsor is much lighter and parts are more readily available gt40 heads add afew ponies I still have the au gt40p heads sitting in the shed, the first mod was the alloy edlebrock heads. This weighs less than a cast iron head xflow with all the alloy bits. Share this post Link to post Share on other sites
NZXD 2,328 Posted May 17, 2013 Personally I'd go for the 331 over a 347, taller piston leads to longer engine life, problem is with a roller block if you start making more than 550 HP or want to spin it past 7000 rpm most factory blocks won't last before long before they call it quits although occasionally you will find one that will, what sort of power are you chasing?<br /> I think I will need to keep the factory block as an after market one will suck half my budget, so that limits power, not keen on 347 due to rod angle at bottom of stroke, so 331 would be the most and to get over 500 HP with those cubes makes it pretty angry. I think 450 would be enough in a light xd. Share this post Link to post Share on other sites
xeeclipse 37 Posted May 17, 2013 you'll be lucky to hit 400hp unless you want to rev it past the danger zone..... 6,000 rpm Share this post Link to post Share on other sites
NZXD 2,328 Posted May 17, 2013 you'll be lucky to hit 400hp unless you want to rev it past the danger zone..... 6,000 rpm 6000 = danger zone? Share this post Link to post Share on other sites
xeeclipse 37 Posted May 17, 2013 All the toughest V8 box cars run windsor's cause their more inclined to hold together under RPM.....Stock block = <6000 Share this post Link to post Share on other sites
xeeclipse 37 Posted May 17, 2013 I think this is the windsor you seek........ Share this post Link to post Share on other sites
NZXD 2,328 Posted May 17, 2013 That would be a dream engine in my D. Share this post Link to post Share on other sites
NZXD 2,328 Posted May 17, 2013 So a bit of internet research on the American 5.0 mustang forums shows that with a 331 stroker, afr 185 heads, hyd roller cam around the 580 lift and 240@50 will get you into the 350rwhp territory in the factory block. Another idea is this: http://www.holley.com/types/Small%20Block%20Ford%20-%20174%20Series.asp The yanks have tested it and based on a 302, 170cc alloy heads (no further description), 264 cam (again no full description) and 750 carb plus 6.6psi made 490hp. Landed in NZ from Summit is $3600nz, plus taxes being 15%. 1 PH351 reacted to this Share this post Link to post Share on other sites
colin0933 40 Posted June 30, 2013 Most have seen my XF with a EL XR8 series 2 motor but thought I would show a couple of pics for those that haven't seen it. 4 PH351, XTREME KARTS XF, NZXD and 1 other reacted to this Share this post Link to post Share on other sites
Ocky 4 Posted August 6, 2014 Hi Colin0933. What model is your brake booster from. Share this post Link to post Share on other sites
gerg 10,871 Posted August 6, 2014 331 would be a sweet engine Share this post Link to post Share on other sites
colin0933 40 Posted August 11, 2014 Hi Colin0933. What model is your brake booster from. Hey mate, The brake booster is standard XF Falcon. The brakes are also standard XF 4 wheel discs. Completely legal & engineered 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
