IVC434 65 Posted June 26, 2021 Hi again. We removed the leaking fuel pump from the XC today and it's going to be thoroughly cleaned and rebuilt. Can anyone please direct me to the best place to purchase a seal/rebuild kit? Share this post Link to post Share on other sites
deankxf 20,288 Posted June 26, 2021 @Mr Polson would repco do a seal kit for these, assume it would be a fuel miser brand if so? 1 IVC434 reacted to this Share this post Link to post Share on other sites
IVC434 65 Posted June 26, 2021 1 hour ago, deankdx said: @Mr Polson would repco do a seal kit for these, assume it would be a fuel miser brand if so? I'll check them out. Thank you. Share this post Link to post Share on other sites
deankxf 20,288 Posted June 26, 2021 7 minutes ago, IVC434 said: I'll check them out. Thank you. not likely to be easy going by this thread. i haven't read it again, but sparkydave linked something might be worth looking into.. wonder if you can repair it with some universal neoprene gasket sheet and cut it out? Share this post Link to post Share on other sites
Mr Polson 10,214 Posted June 26, 2021 [mention=21]Mr Polson[/mention] would repco do a seal kit for these, assume it would be a fuel miser brand if so?Not off the shelf, can possibly source one but kits are pretty uncommon now, most people just put new fuel pumps on these days. 1 deankxf reacted to this Share this post Link to post Share on other sites
Slow250XC 1,513 Posted June 27, 2021 Part number is on the box in that thread. I got the last one from the nz supplier years ago (so they said anyway). Still sitting on my shelf.Sent from my SM-A217F using Tapatalk Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted July 27, 2021 Yeah i have searched high n low for a rebuild kit for these and to no luck. If it was the Holden Glass bowl fuel pump, it wouldn't be a prob, heaps on ebay but Ford Glass bowl fuel pumps, bugger just cant get em. Another question without starting a new thread..... The Fuel pump gasket on these things on early Falcon engines, you no between the block and the pump, why is it like 5mm thick? Does it act like a spacer and have less wear on the cam lobe to operate the fuel pump?? Share this post Link to post Share on other sites
IVC434 65 Posted July 28, 2021 4 hours ago, steve mcqueen said: Yeah i have searched high n low for a rebuild kit for these and to no luck. If it was the Holden Glass bowl fuel pump, it wouldn't be a prob, heaps on ebay but Ford Glass bowl fuel pumps, bugger just cant get em. Another question without starting a new thread..... The Fuel pump gasket on these things on early Falcon engines, you no between the block and the pump, why is it like 5mm thick? Does it act like a spacer and have less wear on the cam lobe to operate the fuel pump?? I can't answer your gasket question I'm afraid, but I DID manage to find a fuel pump repair kit and the pump has been completely rebuilt and is ready to go back on the car again... I found it at a place called Auto Surplus in Croydon South, Victoria.. www.autosurplus.com.au The kit was $64 or so and everything fitted perfectly. With the new, flexible diaphragm, that pump will suck a golf ball through a garden hose now... Bear in mind though, that the pump on my XC is for the 6 cylinder engine. If you're after a V8 model, I can't guarantee they'll have one, but they're definitely worth a try... Good luck.... 1 1 deankxf and Outback Jack reacted to this Share this post Link to post Share on other sites
IVC434 65 Posted July 28, 2021 ...and this is the cleaned and rebuilt fuel pump.... 3 1 steve mcqueen, omgwizards, Outback Jack and 1 other reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted July 28, 2021 2 minutes ago, IVC434 said: found it at a place called Auto Surplus in Croydon South, Victoria.. www.autosurplus.com.au that joint is awesome, I've bought from them several times. 2 Outback Jack and IVC434 reacted to this Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted July 28, 2021 2 hours ago, IVC434 said: I can't answer your gasket question I'm afraid, but I DID manage to find a fuel pump repair kit and the pump has been completely rebuilt and is ready to go back on the car again... I found it at a place called Auto Surplus in Croydon South, Victoria.. www.autosurplus.com.au The kit was $64 or so and everything fitted perfectly. With the new, flexible diaphragm, that pump will suck a golf ball through a garden hose now... Bear in mind though, that the pump on my XC is for the 6 cylinder engine. If you're after a V8 model, I can't guarantee they'll have one, but they're definitely worth a try... Good luck.... Your a legend. Yep mine is for a 6 cylinder, its a 200ci in an XP. Ill go have a captain cook now. 1 1 IVC434 and Outback Jack reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted July 28, 2021 XP.......?? 1 steve mcqueen reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted July 28, 2021 I believe the gasket is a heat barrier between the pump and the block. 2 IVC434 and Outback Jack reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted July 28, 2021 Yeah i have searched high n low for a rebuild kit for these and to no luck. If it was the Holden Glass bowl fuel pump, it wouldn't be a prob, heaps on ebay but Ford Glass bowl fuel pumps, bugger just cant get em. Another question without starting a new thread..... The Fuel pump gasket on these things on early Falcon engines, you no between the block and the pump, why is it like 5mm thick? Does it act like a spacer and have less wear on the cam lobe to operate the fuel pump??I was going to say Auto Surplus, would've thought you'd know of them through work, we use them all the time for old rarer parts 1 1 IVC434 and steve mcqueen reacted to this Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted July 29, 2021 On 7/28/2021 at 5:01 PM, bear351c said: XP.......?? Its a ute 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted July 29, 2021 Sweet.! 1 steve mcqueen reacted to this Share this post Link to post Share on other sites
IVC434 65 Posted July 31, 2021 On 7/28/2021 at 5:01 PM, bear351c said: I believe the gasket is a heat barrier between the pump and the block. One more question for you regarding the gasket please. I'm just about ready to reinstall the newly refurbished fuel pump and I'm not sure if I should use a gasket sealant for it, or is it not as critical as something like the thermostat housing or water pump for example? 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted July 31, 2021 Normally not required if the 2 faces are square, true and flat... but, after 25 years, smear a little on with your finger, both sides. It will piss you off later when it starts weeping oil. 1 1 IVC434 and Slow250XC reacted to this Share this post Link to post Share on other sites
IVC434 65 Posted July 31, 2021 3 hours ago, bear351c said: Normally not required if the 2 faces are square, true and flat... but, after 25 years, smear a little on with your finger, both sides. It will piss you off later when it starts weeping oil. Thank you. It might be good insurance, for sure... Share this post Link to post Share on other sites
