xfish 20 Posted August 6, 2019 I've been wondering why my battery is a bit flat after sitting 2 days in the garage and just discovered by boot light in a EL xr8 ( 98 ) is staying on. I've searched for the switch around the hinges and cant locate it......where is it hidden? Also, while in the boot, will a amp bracket from an NL fit into the EL? My current amp is mounted under the parcel shelf and hope to relocate it to above the rear wheel arch use the bracket from the NL to hide the amp..... Share this post Link to post Share on other sites
Demmo 295 Posted April 18, 2020 bump how did you go did you find the location of switch and how did you fix???? cheers demmo Share this post Link to post Share on other sites
gerg 10,875 Posted April 19, 2020 Are they built into the lock mechanism?Sent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
xfish 20 Posted May 14, 2020 nope , I didnt find or fix the problem. I've just pulled the bulb Share this post Link to post Share on other sites
bear351c 10,433 Posted May 14, 2020 I thought they were on top of the hinge, near the rear parcel shelf. Share this post Link to post Share on other sites
SPArKy_Dave 9,344 Posted May 14, 2020 E-series have a micro-switch in the boot/liftgate latch mechanism from memory. XD-XF sedans have a push-button switch (same as the door switches) underneath one of the boot lid hinges. 2 roKWiz and gerg reacted to this Share this post Link to post Share on other sites
